Comparing Two Circulation Pumps: 25-60-180 vs 25-40-180 in Solid Fuel Boiler & Radiator Setup
tryba_max 16335 7
  • #1 16806914
    tryba_max
    Hello, I need help. The case looks like this: a solid fuel boiler. The installation is made of steel pipes. A year ago, an installation in the attic was added. Pump 25-60-180 for power supply. The new installation is inserted into the old one, about two meters from the boiler. Exit 5/4 ", then 40 plastic to the ceiling, 2 elbows 45 and passage to 32 to the manifold. From the pex 16 manifold in the floor to 8 radiators, aluminum Krakow aramatura. The installation was still air-tight, once a week it was necessary to vent the radiator and the radiators were hot, lower summer , very summer all along. This year I remodeled and put in a second pump 25-40-180 on a supply about 1.5 m from the manifold. The effect of the installation does not air, the radiators heats the entire surface the same. It is a fairy tale. When the pump is turned on, water overflows in the first and a little in the third radiator, looking from the supply side on the manifold, and some radiators on the lower floor heat up halfway from the top, as if the second pump took heat from the installation and gave everything up. The pumps are connected together with a cable controller - pump on the stove - pump at the manifold Both work on the 2nd range Where the cause of the problem Please help
  • #2 16806953
    lukasixthm
    Help: 60
    Rate: 381
    Try to put the old pump on the 3rd gear, and the new pump on the 1st, maybe 2. Turn off those radiators where the water doesn't overflow and vent the noisy ones.
  • #3 16807023
    gimak
    Help: 614
    Rate: 1678
    tryba_max wrote:
    some radiators on the lower storey heat up to half of the top, as if the second pump was drawing heat from the installation and giving everything up.
    Two pumps in circulation are like two mushrooms in borscht. You have reverse circuits on these heaters - you heat back up.
  • #4 16807028
    tryba_max
    So how? Because I do not understand. The second pump causes the heater to heat back? But the returns are cold in those heaters
  • #5 16807133
    gersik
    Help: 164
    Rate: 639
    I understood? One pump is pushing water into the other? Pumps should be connected in parallel. Draw a diagram as it is with you.
  • #6 16807147
    tryba_max
    Yes, one in the other, all in the description in 1 post
    • Comparing Two Circulation Pumps: 25-60-180 vs 25-40-180 in Solid Fuel Boiler & Radiator Setup 1510063221691-2130479360.jpg (384.27 KB) You must be logged in to download this attachment.
  • #7 16807190
    gimak
    Help: 614
    Rate: 1678
    It was me who misinterpreted the quote I made - sorry. In these half-warm radiators the circulation is correct, but it may be that it is a bit too small in relation to the needs - it is too cold in the rooms, since you are writing about it.
  • #8 16808711
    gersik
    Help: 164
    Rate: 639
    Pump 2 for lower gear.
The discussion revolves around the performance comparison of two circulation pumps, the 25-60-180 and the 25-40-180, in a solid fuel boiler and radiator system. The user describes an installation with a solid fuel boiler and steel pipes, where a second pump was added to improve heating efficiency. Initially, the system required frequent venting of radiators, but after installing the 25-40-180 pump, the heating performance improved significantly, with even heat distribution across all radiators. Responses suggest adjusting the pump speeds and ensuring proper parallel connection of the pumps to avoid reverse circulation issues. Some participants express concerns about the overall capacity of the system and the need for adjustments to optimize heating.
