Procedure for Pairing Universal Remote Control with Manta TV Set
Manta12345 52362 3
  • #1 17626199
    Manta12345
    Rate: 12
    Hello, someone will tell me how to pair this remote control with the Manta TV
    kindlar
    Help: 919
    Rate: 1622
    You have a TV model in the manual, then you enter its code in the remote control or a similar one. If the learning mode of the remote control does not work, it is necessary to carry out the training.
  • #3 17626364
    Manta12345
    Rate: 12
    I will look for the back of the TV because there are no instructions
    mieszaczwcz
    Help: 185
    Rate: 258
    There are universal remote controls which are paired by pointing it to the TV in Stby's shit and pressing "ON" each time it sends a different ON command from its base. At the moment of reaction to turn on, we check other buttons, if OK, we turn it off and the remote control remains on the current code.
    METHOD I
    If it has manuals from the code table:
    Find the correct code in the included code list.
    Press the SET and eg TVTXT1 buttons simultaneously until the red LED lights up.
    Enter a 3-digit code.
    Press POWER
    NOTE: Do not exceed 10 seconds between button presses.
    Sometimes the found code does not fulfill all functions. Try different codes for a given brand or use the second method - automatic search.
    METHOD II
    Automatic code search
    Turn on the device: TV, VCR, SAT, Audio
    Press SET again and release.
    Press the POWER button cyclically about 500 times to search through all the codes of the remote control.
    When the equipment shuts down, release the POWER button - the code has been found.
    To save, press the device button TVTXT1, TVTXT2, VCR1, VCR2, CBL / SAT, SAT / CBL or HIFI / CD / LD
    Sometimes the found code does not perform all functions. It is worth trying other codes in the automatic search further.
    The remote control can operate several devices at the same time.
    Switching between programmed devices on the remote control.
    Press TVTXT1, TVTXT2, VCR1, VCR2, SAT / CBL, CBL / SAT, HIFI / CD / LD and the keypad on the remote control performs the functions for the device.
