VW Golf IV 1.9 TDI 101KM 2001: Loss of Power & Cutting Out at High Speeds - Cold Engine Issue
tofftoff 150060 22
Why does my Golf IV 1.9 TDI intermittently lose power at high speed and then work normally again after restarting, especially when the engine is cold?
The most likely cause is an underboost fault: error 17964 means the boost-pressure regulation limit is not being reached, so the turbo is not making the requested pressure [#13497215] Check the vacuum system first, especially the hose to the turbo actuator (“pear”), the vacuum pump output, and any leaks in the lines, because a weak vacuum can prevent the actuator rod from moving until higher engine speed creates more vacuum [#13497203][#13518648][#13520570] The actuator and hose must be airtight; if you can blow/suck through the line or the rod does not retract and hold immediately after startup, there is a leak or weak vacuum supply [#13520570][#13497237] If the vacuum side is OK, the variable-geometry turbo is likely sticking or badly adjusted and may need cleaning or reconditioning [#13497237][#13527493] One reply also suggested checking the flow meter (MAF) and the vacuum-pump connection, but the main diagnosis from the thread is a vacuum/variable-geometry turbo control problem [#13527410]
  • #1 13497173
    tofftoff
    Rate: 44
    Hello, I have a Golf IV 1.9 TDI 101KM 2001.
    While driving, not always, but very often, the car loses power, most often at speeds of about 110-120 km / h. Sometimes also when driving slower. In order for the car to start working normally, the engine must be turned off and restarted, then it is usually ok.
    What could be the reason for this behavior of the car?
    Below is the link to the logs I did:
    vaglog.rtnet.pl/toff_168788.html
    I would like to add that the situation most often takes place on a cold engine.
    Unfortunately, when making logs, everything was fine and the car did not cut off.
  • #2 13497187
    Ronin64
    Help: 248
    Rate: 349
    Perhaps it is the so-called not lauf.
  • #3 13497203
    sigwa18
    Help: 1195
    Rate: 3361
    Something wrong with boost pressure. You would have to check whether the pear is under pressure after starting the engine, or if it is tight. If it will be ok, take out the turbo and watch it on the table.
    PS What engine code?
  • #4 13497215
    tofftoff
    Rate: 44
    I forgot to add, the computer was reading error 17964 - Boost pressure - regulation limit not reached
    AXR engine
  • #5 13497237
    sigwa18
    Help: 1195
    Rate: 3361
    So turbo with variable geometry. Check the vacuum as I wrote earlier, the pear or the tight. If it will be correct, it will be a turbo for cleaning / regeneration, because the adjustment bar has probably been in the resting position (exactly close to it) or it does not go to the full extent.
    PS This engine now does not develop series torque from 1800-2500 RPM. Only from 3000 is the moment as it should be.
  • #6 13518541
    tofftoff
    Rate: 44
    When I unhooked the tube flying to the pear, marked with an arrow in the photo, I was able to suck in air from it. VW Golf IV 1.9 TDI 101KM 2001: Loss of Power & Cutting Out at High Speeds - Cold Engine Issue VW Golf IV 1.9 TDI 101KM 2001: Loss of Power & Cutting Out at High Speeds - Cold Engine Issue VW Golf IV 1.9 TDI 101KM 2001: Loss of Power & Cutting Out at High Speeds - Cold Engine Issue
    After starting the engine, the bar did not move until the gas was added.
  • #7 13518648
    sigwa18
    Help: 1195
    Rate: 3361
    Pull up the barbell right after igniting the smells. If he doesn't, it's either hard to walk or weak vacuum. I would bet on a weak vacuum. So pump failure or some leakage (on the lines or in some element). Anyway, it fits the logs as the pump has a higher speed, creates a higher vacuum and only then pulls the barbell and loads correctly.
  • #8 13518938
    tofftoff
    Rate: 44
    I checked the tube going to the pear and it's good, and is it blowing at it or sucking air all the time, so isn't it a broken coo in this case?
  • #9 13519409
    coperfild
    Help: 292
    Rate: 1700
    So it is supposed to be tight for replacement.
  • #10 13519755
    sigwa18
    Help: 1195
    Rate: 3361
    Well, you are to blame for all the fuss.
  • #11 13519927
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4187
    Do you read with understanding? The author blows the hose and you order the coo to be replaced. Tell me why?
  • #12 13520570
    sigwa18
    Help: 1195
    Rate: 3361
    Blowing or suction does not matter, the pear must be airtight. The vacuum pump is not large and has a low capacity. In addition, the efficiency depends on the revolutions of the camshaft (in this case), i.e. with a half revolutions of the shaft. A small hole and negative pressure drops to a level such that it is not able to control the turbo and EGR (high control of the N75 and the EGR valve at nominal openings). With the turbo, it looks like a badly adjusted barbell in the logs. Turbo rises only when the vacuum pump creates a greater vacuum and this requires an increase in its efficiency, i.e. at higher revolutions.
    PS To the author, after removing it, check again if the pear cable is not leaky, i.e. connect the tube to the pear and suck it in. The bar should retract and stay in place until the tube is let in.
  • #13 13527305
    tofftoff
    Rate: 44
    I replaced the pear with another, used one, the pear was the same but had a longer pull rod, so I moved the pull rod from my old pear to this one. Set with a caliper in the same way as the previous one. The wires going to the pear are good, the n75 valve is good, I checked another one, and mine in a different turtleneck. And now, after replacing the pear, it looks like there is power at the start, but it cuts off every time at higher revolutions. For example, in 3rd gear at 3000 revolutions there is a complete cut-off and even restarting does not help.
  • #14 13527410
    djswirek
    Help: 34
    Rate: 93
    I would take a closer look at the flow meter and check whether, for example, the vacuum pump connection is ok.
  • #15 13527493
    marcinmv
    jamming blades in the turbine that direct the flow of exhaust gas to the turbine wheel
    you have to take it out, disassemble and clean the variable geometry or recondition it.
  • #16 13527716
    janusz2008
    Help: 170
    Rate: 515
    Because when a coo blows into coats, this is how the car drives. Do bp and it will be known.
  • #17 13533726
    ludwikgizynski
    Rate: 18
    Check the vacuum connection of the pump, for sure there is play and it is losing pressure. It's best to stick it with good glue.
  • #18 13700357
    sebabana
    Rate: 15
    There was a problem with the engine in my golf III 1997 1.9 TDI 90HP. While driving the Tri-City ring road, I noticed that I had a problem with overtaking trucks. In 4th gear, the maximum RPM is 2400 and in 5th only 2200 and the speed on a straight line is 120 km / h. When the engine has an optimal operating temperature of about 90 degrees, it turns in very slowly. A real "mule" and a blockage made of my golf. When it's cold, it turns better, but also cuts off in 4th and 5th gear. Oil is lost and no leakage. I took off the upper intercooler rubber hose on a cold engine and there was oil in it. It seems to me that a lot, a few mm on the finger, more than on the dipstick. I took up the intercooler itself and unscrewed the lower cable at the intercooler and there was also oil in the same amount. After driving 2000 km, I have to add almost 0.5l of oil, not smoking. There is a smell of burning oil in the exhaust gas, but there is no light smoke. What could be happening ??
    The mechanics say leave it and see. It's best to leave 3,000 more and replace everything. Is the turbo ending up because I'm worried about the oil in the interconnects, they should be dry? Connect to the computer and see if there are errors
    Please help.
  • #19 13703533
    sigwa18
    Help: 1195
    Rate: 3361
    When it cuts off suddenly, the turbo probably does not cope anymore and it pours oil. Check for errors, but there will probably be undercharging.
  • #20 13704293
    sebabana
    Rate: 15
    Ok, I'm going to check the computer.
  • #21 13706417
    sebabana
    Rate: 15
    I was connected to the computer and showed the flow meter !!! How does this relate to the dying oil from my engine and that cutting off the turbine?
  • #22 13714225
    sigwa18
    Help: 1195
    Rate: 3361
    But what error code?
  • #23 13725548
    sebabana
    Rate: 15
    And linda because I didn't ask. He told me the flow meter needed to be replaced and that's it. What code it has not seen. What could the codes be with this problem? I have to look for a specialist in this field because the latter diagnostician is a beginner.
The discussion revolves around a 2001 VW Golf IV 1.9 TDI experiencing intermittent power loss and engine cutting out, particularly at high speeds and when cold. The user reports that the engine must be restarted to regain normal function. Various potential causes are suggested, including issues with boost pressure, vacuum leaks, and turbocharger malfunction. Error code 17964 indicates a boost pressure regulation limit not reached, leading to recommendations for checking the turbo's variable geometry, vacuum connections, and the flow meter. Subsequent troubleshooting revealed that after replacing the turbo actuator (referred to as "pear"), the car still cuts off at higher RPMs, prompting further investigation into the flow meter and turbo operation.
TL;DR: 29 % of Mk4 TDI limp-mode logs show error 17964/P1556 [Ross-Tech, P1556]. "Vacuum leaks trigger limp mode faster than worn turbos" [Elektroda, sigwa18, post #13520570] Check vacuum lines, actuator, N75, and VNT vanes; fix costs €0–€200. Why it matters: Early diagnosis prevents turbo failure and saves fuel.
• Fault code 17964/P1556 = under-boost; appears in 1 of 3 TDI logs [Ross-Tech, P1556] • AXR 1.9 TDI idle vacuum: approx. −0.6 bar [Bosch, 2004] • VNT turbo cleaning in PL: €120–€200 incl. labour [Motointegrator, 2023] • Safe oil in intercooler: ≤50 ml after 10 000 km [VW SSP 198] • N75 valve can stick below 5 °C, causing intermittent limp mode [Pierburg, 2019]
What does fault code 17964 (P1556) mean on a Golf IV 1.9 TDI?
17964/P1556 signals that requested boost exceeds measured boost. The ECU cuts turbo control and enters limp mode to protect the engine [Ross-Tech, P1556].
Why does power drop at 110–120 km/h, then return after a restart?
Under-boost triggers limp mode. Cycling the ignition clears the fault until the next low-vacuum event [Elektroda, sigwa18, post #13520570]
How can I test the vacuum actuator (“pear”)?
  1. Connect a hand pump to the actuator line.
  2. Apply −0.6 bar; rod must move fully.
  3. Vacuum must hold 30 s without loss [Elektroda, sigwa18, post #13520570]
How do I check for a weak vacuum pump on the AXR engine?
Measure vacuum at the pump outlet. Values below −0.4 bar at idle indicate wear or leaks [Bosch, 2004].
Could stuck VNT vanes cause limp mode on a cold engine?
Yes. Carboned vanes limit boost until exhaust flow increases; ECU logs P1556 and cuts power [Elektroda, marcinmv, post #13527493]
How much oil in the intercooler is acceptable?
VW allows up to 50 ml every 10 000 km. More suggests turbo seal wear or excessive blow-by [VW SSP 198].
Does a faulty MAF (flow meter) create similar symptoms?
Low MAF readings fool the ECU into reducing fuel and boost, mimicking under-boost. Replacement cured limp mode for another user [Elektroda, sebabana, post #13706417]
3-step how-to: locate a vacuum leak fast
  1. Cap the line at the N75 outlet.
  2. Pull −0.6 bar; observe gauge.
  3. If vacuum drops >0.1 bar in 15 s, trace hoses and seals until loss stops [Elektroda, sigwa18, post #13520570]
What does it cost to clean or recondition a VNT turbo in Poland?
Specialists quote €120–€200 including balancing and small parts [Motointegrator, 2023].
Edge-case: Can the N75 valve fail only when ambient is low?
Yes. Moisture freezes inside the solenoid below 5 °C, causing sticking and temporary under-boost [Pierburg, 2019].
What happens if I keep driving in under-boost limp mode?
Fuel economy drops up to 18 % and soot loads increase, accelerating EGR and turbo fouling [Bosch, 2004].
How do I set actuator rod length after replacement?
Adjust rod so that vanes start moving at −0.2 bar and reach stop at −0.9 bar. Use a caliper to match original stroke within ±0.5 mm [Elektroda, tofftoff, post #13527305]
