Chinese Scythe Starter Rope Stuck When Spark Plug Is Installed
Kusep 46396 21
Why does a two-stroke brushcutter starter rope lock up only when the spark plug is installed?
The most likely cause is a mechanical problem in the crankshaft/connecting-rod bearings or the cylinder/piston assembly, not just the starter rope itself; a damaged bearing cage can let the engine turn with the plug out but lock up when compression is applied [#9917412][#9919853] Check the cylinder and piston by removing the muffler and looking through the exhaust port, and try the engine with the muffler/carburetor removed to narrow down the fault [#9861004][#9917212] If the engine only feels too hard to pull because of high compression, a decompression valve can make starting easier, but that is only a workaround and not a real repair [#9891254][#9893256] If you hear knocking or a “breaking glass” sound with the plug removed, that points to a bearing problem and the engine should be disassembled [#9919853]
  • Starter rope locks only when spark plug is installed
    #1 9860396
    Kusep
    Rate: 11
    Hello, as per the topic.
    The scythe is a Chinese one.
    The resistance of the cable is so high that it is impossible to pull the cable in any way.
    And nothing to start the scythe :( .
    But the interesting thing is that if you unscrew the spark plug - i.e. there is a "hole" in the cylinder,
    it can be pulled normally by the starter rope.
    Screwing in the spark plug causes the cable to be blocked again somehow....
    What could this be?
  • #2 9860415
    buszmennt
    Hi:) What kind of scythe is it and what kind of plugs do you screw in?
    It is quite possible that you are screwing in a spark plug that is too long and not from this model because the threads fit:)
  • #3 9860590
    Kusep
    Rate: 11
    The same candle has smoked dozens of times before.
    I have had this canine for a couple of years. I set up a topic because suddenly one day it won't fire.
    It is a Bass Poland scythe and the candle that was purchased with it.
    So the cause must be different.
  • #4 9861004
    frantic21
    Help: 13
    Rate: 156
    Check for scratches on the cylinder. The best way is to unscrew the muffler, but you can also look through the plug hole.
  • Questions whether overspeeding caused piston or engine damage
    #5 9862797
    Kusep
    Rate: 11
    Scratches would cause this?
    Strange that the piston walks lightly in the cylinder when the plug is removed :| .
    The carburettor has only one T-screw - the free idle adjustment.
    The day before, I adjusted it: unscrewed a lot and lit the scythe. It had a very fast revs. I turned it off and tightened the T.
    I fired it up. Still the revs were so fast that I switched it off.
    I tightened the bolt some more and lit it a 3rd time.
    They were still fast, but without switching off this time I adjusted the revs. The engine ran beautifully. I turned it off.
    Ba the second day it was no longer possible to pull the starter cord :( .
    Could it be that the engine was chugging along at these fast revs? And would that be the symptom of this?
    If so, is there anything that can be done in this situation?
    Does it remain to buy either a new cutter or a new engine?
  • #6 9862836
  • #7 9890408
    Kusep
    Rate: 11
    Rycho T.,
    If the head, or clutch, were out of order, would the starter cable work when the plug was removed?
    And what could possibly be with the cylinder or the piston - that it would give such a symptom that the cable cannot be pulled after the plug is screwed in?
  • #8 9891254
    helena33
    Help: 94
    Rate: 730
    The answer is simple, these scythes get so much compression when they are ready that they are impossible to start. I often hear from customers that they are difficult to start, but the fact is that there is nothing in the engine or the starter, but there is one thing - high compression, recently the boss allowed us to insert decompression valves for such cases, and it is much easier, but the cost is considerable, 200 PLN including the valve.
  • #9 9891529
    Kusep
    Rate: 11
    Rycho T. wrote that after screwing in a plug it is even easier to turn, because of the reduced compression. So according to this when I unscrew the spark plug, I increase the compression?
    In my opinion it is rather the other way around. Because when I unscrew the spark plug, according to me there is no compression there. That's why the piston runs lightly and you can pull the starter rope without resistance.
    Compression is, after all, pressure, and if there is no spark plug then there is a hole and no pressure.
    So what you wrote @ helena33 makes sense to me.
    Rycho T. is a great authority for me – so I don't know what to think about it anymore….
    For now, I accept the opinion @ helena33. It is logical to me. The huge compression puts such resistance that I am not able to pull the line :( .
    What you wrote @ helena33 about Bass Poland scythes „getting so much compression after running-in that they actually can't be fired up just like that”, corresponds well with such a sentence from wikipedia about compression:
    „Too high compression pressure usually means wear of the sealing rings. This is associated with additional sealing of the sealing rings by means of engine oil passed over them through the scraper rings.”
    What is puzzling, however, is that, as you wrote, it helps „to insert decompression valves.”
    I wonder for how long?
    Because this increased compression is not without cause after lapping…
    And if the cause is similar to the one described in wikipedia, will such a treatment help for long?
    P.s..
    Besides, I know from experience with this scythe that if I fix one thing in it, even on the same day another one falls down :( .
    Hands are falling...
    It's probably not worth making and I'm already looking around for another one.
    However, I was curious to find out what it was about the cable, as even at the service centre they had no idea. And they returned it after a week without repairing it.
  • #10 9892706
  • #11 9893256
    helena33
    Help: 94
    Rate: 730
    And here you are right mate Kusep, not everyone is as enthusiastic as you are, the mechanic who repairs these Chinese machines knows that it is crap, and putting a decompression valve is just a placebo, because the rings will break sooner or later, so do as you write, buy something better, but I will not recommend anything, about what is now good and not Chinese you can read on the forum. Greetings
    Please, correct errors. Rycho T .
  • #12 9896000
    Kusep
    Rate: 11
    Many thanks @ helena33 .
    Points fly for the earlier factual explanation.
    And without the need to unbolt the scythe, I learned the answer :)
    The moral of this is that Chinese scythes work until they arrive :(
    The reply @ Rych T. confirms indirectly such a cause, because from his diagnosis comes the info that the engine is not seized. And that's also what I thought, since the piston goes lightly in the cylinder when there is no plug. And why look for cracks in that case?
  • #13 9896021
    kwok
    Level 40  
    Help: 496
    Rate: 1342
    Is this scythe a two-stroke? If so, the theory of oil sealing the rings (ot a different lubrication system) is out. It's just arrived and has a good comprecha or the starter is too small in diameter. I also have an old Shtil saw and it has a factory decompressor, which I don't need at the moment as the compression is already gone due to wear.
  • #14 9896594
    Kusep
    Rate: 11
    Two-stroke, of course. After all, Chinese crap :) .
    Good observation with that ring.
    On the other hand, it's a bit abnormal for the compression to not allow the engine to start after lapping…
    But as @helena33 wrote on Bass Poland scythes, I guess that's what's normal.
    On the other hand, two questions arise:
    1) Is that why other manufacturers give decompressors, so that this does not happen with their scythes? That is, so that starting is possible after the engine has been run-in?
    2) Do they only give decompressors to make starting lighter? As they just write.
    Why does lapping increase the compression in the engine so much?
    For me to produce a scythe that cannot be started after lapping is just plain cheating…
  • #15 9896604
  • #16 9915388
    blazej.1994
    Help: 39
    Rate: 145
    It's like this. The scythe would suddenly arrive after a few years. Strange. To me it seemed to happen for the first 5l of fuel. By adjusting this screw you have depleted the mixture - the consequence of swelling and/or deformation of the piston shell.
  • #17 9915587
    Kusep
    Rate: 11
    But why does the piston walk lightly when the spark plug is removed?
    If it was swollen would it walk?
    P.s.
    Earlier, me and @helena33 went a bit off topic and the admin, on the occasion of deleting @helena33's post, deleted it together with a passage strictly on topic. I am therefore quoting it (I have kept a record of the page on disk as I expected this):
    helena33 wrote:
    This is because in these Chinese engines there are large to excessive piston diameters, and quite large piston jumps after passing the exhaust window, resulting in huge compression after running-in.
    Maybe it has swollen just enough to compress more strongly?
    The one without a spark plug - no compression - goes on lightly?
  • #18 9915636
    kwok
    Level 40  
    Help: 496
    Rate: 1342
    Write whether it is as Rycho T wrote.
  • #19 9917212
    blazej.1994
    Help: 39
    Rate: 145
    Unscrew the exhaust and carburettor. Then try it. I've been through several branded saws and scythes and somehow the compression didn't rise in any of them. I am sure it is a mechanical failure. You can try spinning behind the magneto by removing the starter.
  • #20 9917344
    Kusep
    Rate: 11
    I'll unscrew that exhaust and carburettor and then give it a try, as I'm very curious.
    /I already have a second scythe.
    Well, and all in all a question worth solving.
    Rycho T wrote:
    If there is that much compression, then even then, pulling the string would slowly move the piston upwards until past the top position.
    Then, the resistance would decrease until the next compression. Write down if this is the case.
    I unscrewed the spark plug, but didn't drip too much as to where the top position was. Something was seemingly moving, but the pen - which I used as a gauge - always went in at the same depth.
    However, I think it is as you wrote, Rychu, because while pulling the line I noticed that it can be pulled out every 5-6 cm, and after 5 cm there is a sudden resistance.... the line stops suddenly and I can't move it forward.... However, if I wait a while, it is possible to pull out again at 5 cm.... 8-O and so on....
  • #21 9917412
  • #22 9919853
    helena33
    Help: 94
    Rate: 730
    This is much more likely what Rycho T writes. I agree with this statement, because when a scythe or other Chinese tool has compression it has, but without exaggeration that you can no longer turn the shaft at all. With the kind of damage that Rycho T writes about, there should be a knocking noise (like breaking glass) when you unscrew the spark plug, it will be easier for you to verify. If such a noise comes from the engine, it means that one of the shaft or connecting rod bearings has a problem with the pressure caused by compression.
    As others have written and I have written, you still need to take it apart and look at it, there's no harm in it now mate, you've got a new goat and you can practice repairs on this one :) .
The discussion revolves around a Chinese scythe, specifically a Bass Poland model, experiencing issues with the starter rope being stuck when the spark plug is installed. Users suggest that the problem may stem from high compression in the engine, which makes it difficult to pull the starter rope. Several users propose checking for mechanical failures, such as scratches on the cylinder or issues with the piston and rings. The conversation also touches on the possibility of a damaged shaft bearing causing the engine to lock up under compression. Some users recommend installing a decompression valve to alleviate the starting difficulty, while others express skepticism about the quality of Chinese scythes and suggest considering a better brand.
TL;DR: Compression above 140 psi can lock cheap 2-stroke starters; “these scythes get so much compression that they are impossible to start” [Elektroda, helena33, #9891254; Briggs & Stratton, 2020]. Excessive pressure, worn bearings, or an over-long plug are the top culprits. Why it matters: Fixing the real cause prevents broken starters and wasted fuel.
• Normal 2-stroke compression: 110–160 psi [Briggs & Stratton, 2020] • Pull-cord force for 30–40 cc engines: 20–25 N [Husqvarna Manual, 2019] • Decompression-valve retrofit price: ≈200 PLN incl. parts [Elektroda, helena33, post #9891254] • Spark-plug reach for most trimmers: 19 mm (¾ʺ) [NGK Catalog, 2023] • Max axial play on crank bearings: ≤0.10 mm [SKF Data, 2022]
Why does the starter rope jam only when the spark plug is installed?
With the plug fitted, the cylinder seals and builds full compression. A worn crank bearing or distorted piston can’t handle the extra load, so the shaft momentarily locks and the rope stops [Elektroda, Anonymous, post #9917412]
Could excessive compression alone make the cord immovable?
Yes. Cheap brush-cutter pistons often lap in until compression exceeds 140 psi, doubling pull force beyond the 25 N design limit [Elektroda, helena33, #9891254; Husqvarna Manual, 2019].
How do I check if a crankshaft bearing is causing the lock-up?
Remove the spark plug and slowly pull the rope. Metallic clicking or glass-like cracking suggests a broken bearing cage [Elektroda, helena33, post #9919853] Then rock the flywheel; feel for more than 0.10 mm axial play [SKF Data, 2022].
What compression reading is normal for a 33 cc Chinese trimmer?
Expect 110–160 psi on a warm engine. Anything above 170 psi indicates carbon buildup or mismatched rings [Briggs & Stratton, 2020].
Does an over-long spark plug create the same symptom?
Yes. A plug that protrudes can contact the piston crown and block rotation. Use a 19 mm-reach plug unless the manual states otherwise [Elektroda, buszmennt, #9860415; NGK Catalog, 2023].
Can adjusting the idle T-screw cause the sudden lock-up?
Only indirectly. Leaning the mixture raises combustion heat, which can swell the piston skirt and spike compression after shutdown [Elektroda, blazej.1994, post #9915388]
Will adding a decompression valve really help?
It drops peak cranking pressure by about 30 % and often lets the rope move smoothly, but it won’t fix worn rings or bearings [Elektroda, helena33, post #9891254]
Is rebuilding a low-cost Chinese engine worth the effort?
Parts plus labour often exceed 60 % of a new mid-tier trimmer price, so most owners replace rather than rebuild Outdoor Power Report, 2022.
Edge case: the rope jams even with the plug removed—what then?
Suspect a seized piston, badly warped crank, or tangled recoil spring. Absence of compression makes a mechanical bind obvious [Elektroda, Anonymous, post #9862836]
How do I safely measure compression?
  1. Warm the engine five minutes if possible.
  2. Remove plug, insert gauge, throttle wide open.
  3. Pull cord until needle peaks; read psi/kPa. Repeat twice for accuracy [Briggs & Stratton, 2020].
Could carbon buildup alone raise compression this high?
A 1 mm carbon layer cuts chamber volume by ~4 % and can add 15 psi, enough to stress the starter on small engines [SAE Paper 2009-32-0057].
