STIGA SBC 252 D Brushcutter Won't Start: Troubleshooting, First Mowing Issues, Flooded Spark Plug
portier90 16698 17
Why does a STIGA SBC 252 D brushcutter start when cold but refuse to restart after a short 20-minute break, and how can I fix it?
After repeated restart attempts with choke and priming, the engine is most likely flooded, and you should clear the cylinder by removing the spark plug, turning the machine upside down, and pulling the starter to expel the fuel before reinstalling the plug and trying again [#17199573] The spark plug mixture ratio is not the main issue here: 160 ml of oil in 5 l of gasoline is about 31.25:1, which is richer than 40:1 but not enough to seize the engine [#17199615][#17199650] If starting problems continue, use fresh clean gasoline and make sure you are not over-choking the engine during warm restarts [#17199651]
  • #1 17199401
    portier90
    Hello. Please help. I bought a STIGA SBC 252 D brush cutter, today I did the first mowing, and in fact 1/6 of it .. The scythe works very well, fires well "hot", but when I turned off the engine for 20 minutes, I had to wave a lot to start again .. After the second off, there is no way to fire it after a second break. I wave and wave and nothing ... follows the instructions 10 x suck, choke lever, pull, lever to work and pull to light. I'm really pissed off, I didn't start mowing well and something's not working anymore .. work is standing still! I had a flat 40: 1, I poured 160 ml of oil into 5 liters of gasoline, so the proportions were rather appropriate. Was it the candle that flooded? I unscrewed the candle, blown it, pulled the rope and screwed it back in. I noticed that the casing is slightly melted by the candle. I am asking for help, I had at least 1/4 planned today and I didn't even cut half of what I had planned.
    • STIGA SBC 252 D Brushcutter Won't Start: Troubleshooting, First Mowing Issues, Flooded Spark Plug 0F80BACF-731F-48E9-B91F-DB6EBEA7B52C.jpeg (435.66 KB) You must be logged in to download this attachment.
  • #2 17199428
    Pedros050
    Help: 2471
    Rate: 3921
    Hello. Did you check that this candle has a spark?
  • #3 17199467
    portier90
    I took out that black part, there are some little sparkles when I pull.
  • #4 17199474
    Pedros050
    Help: 2471
    Rate: 3921
    Do you have replacement candles?
  • #5 17199495
    portier90
    I put on Daemon from an old scythe, nothing. I chose the correct proportions, I must have poured more than 160 ml for those 5 l ..
  • #6 17199513
    Pedros050
    Help: 2471
    Rate: 3921
    And the candle is flooded after unscrewing?
  • #7 17199543
    portier90
    It does not look, the sparks are flying .. I hope the engine is not seized .. here is the candle:
    • STIGA SBC 252 D Brushcutter Won't Start: Troubleshooting, First Mowing Issues, Flooded Spark Plug 265CC014-A299-4AD1-8560-1E4C0C10A22D.jpeg (678.05 KB) You must be logged in to download this attachment.
  • #8 17199553
    Pedros050
    Help: 2471
    Rate: 3921
    It has a rich mixture, but the fuel is dry as pepper.
  • #9 17199567
    portier90
    I rubbed it, I am constantly wondering if I made the right mix .. Since you suggest a good, defacto in the ratio of 40: 1 comes out 40 ml per 1 l, I was wrong and poured about 180 ml for 5 l instead of 200 .. and now it worries me terribly . Remove the record from the manual.
    • STIGA SBC 252 D Brushcutter Won't Start: Troubleshooting, First Mowing Issues, Flooded Spark Plug FB26469F-0EE0-47C9-960B-32EA627DDFE3.jpeg (1.13 MB) You must be logged in to download this attachment.
  • #10 17199573
    płetwa
    Help: 164
    Rate: 549
    The mixture was made by a colleague 1:32, but it's not a problem yet, it should work and smoke more.
    Tell me why the hell are you pumping fuel again after a 20 minute break and re-choke. The scythe after such attempts is 100% flooded. In such a situation, you twist the candle, turn the machine upside down and, pulling with a jerk (as when starting), "spit out" all the fuel from the cylinder. You screw the candle in and after such a procedure it has to light up.
  • #11 17199586
    Pedros050
    Help: 2471
    Rate: 3921
    Pour the fuel from the syringe into the cylinder through the candle hole and burn this mower, you will know if there is fuel or not?
  • #12 17199615
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1130
    This mixture was rather 31.25: 1, to be 40: 1 that would be 100 ml of oil for 4 liters of gasoline, with 40: 1 for 5 liters of gasoline, 125 ml of oil would come out.
  • #13 17199629
    portier90
    Could the engine seize due to such a flat?
  • #14 17199650
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1130
    Rather, there is no fear. What mixture is recommended in the manual?
    In that case, it can only smoke more.
    Well, unless the manufacturer recommends a 20: 1 mixture (100 ml of oil to 2 liters of gasoline) :D so with the hard work of a new, unbroken machine, anything can be done with such a mixture.
  • #15 17199651
    Pedros050
    Help: 2471
    Rate: 3921
    Erase no, but the problem with starting, add clean gasoline, did you not smoke that mower?
  • #16 17199722
    portier90
    It doesn't seem to smoke, there are no signs of smoking on the casing either.
  • #17 20148828
    KrisPan
    The coil to be replaced and after the scream before this procedure, the air filter would be checked if it was dry and clean
  • Carburettor seals, diaphragms and low-speed mixture checks
    #18 21932926
    LEDówki
    Help: 1313
    Rate: 2571
    This is an old thread, but it might be useful to others:
    1. Check the seals between the intake manifold, the cylinder and the carburettor. Check that the manifold and carburettor are securely tightened.
    2. For an emergency start using extra fuel, it’s best to add up to 0.3 cm of fuel under the air filter. You can do this via the nut securing the filter cover.
    3. Check the diaphragms in the carburettor: there is one on the side without the pump and another on the side with the pump; they must not be punctured, deformed or stiff.
    4. The valves in the carburettor should move freely.
    5. The carburettor’s flow channels must be clean. This is difficult to describe; a photo or video would be better.
    6. The engine revs should increase immediately when you press the accelerator. If the engine roars for a moment and only then picks up speed, the mixture is too lean at low revs. From my online research, it appears that the screw closer to the engine controls the mixture ratio at low revs. Loosen it by 1/8 to 1/4 of a turn and check whether the rev response has improved. The second screw, further away from the engine, is apparently responsible for the fuel mixture at high revs. I haven’t been able to find instructions on how to adjust this carburettor.
✨ The STIGA SBC 252 D brushcutter is experiencing starting issues after brief operational pauses. The user reports that the machine starts well when hot but fails to restart after being turned off for 20 minutes. Troubleshooting steps include checking the spark plug for spark, ensuring the fuel mixture is correct (40:1 ratio), and examining the spark plug for flooding. Suggestions from the forum include checking the air filter, ensuring the fuel is clean, and potentially replacing the ignition coil. The user is concerned about the possibility of engine seizure due to incorrect fuel mixture proportions.
TL;DR: 1:32 mix can run but smoke; "after such attempts it is 100% flooded." Clear floods and skip choke on warm restarts. [Elektroda, płetwa, post #17199573]
How do I fix a STIGA SBC 252 D that wont start when hot?
Do not choke or pump the primer again on a warm engine. Over‑priming floods the cylinder. "The scythe after such attempts is 100% flooded." Clear the flood by removing the plug, inverting the unit, and pulling several times to expel fuel. Refit the plug and pull to start with the lever on Run. If it still fails, let it sit a minute, then try again without choke. [Elektroda, p2etwa, post #17199573]
Whats the correct fueloil ratio and volumes for 5 liters?
For 40:1, mix 125 ml of two‑stroke oil with 5 liters of petrol. Using 160 ml in 5 liters is ~31.25:1. This richer mix will not match 40:1. Keep ratios precise to avoid smoke and plug fouling. [Elektroda, wojtek1234321, post #17199615]
Could a ~31:1 mixture seize my new engine?
No. A richer mix (more oil) reduces seizure risk. It may smoke more and foul the plug. "Rather, there is no fear. It can only smoke more." Use the manufacturer’s recommended ratio once the engine is running correctly. [Elektroda, wojtek1234321, post #17199650]
Should I choke and pump the primer after a 2020 minute break?
No. Avoid re‑choking and re‑priming after a short stop. That floods the cylinder and prevents ignition. Clear the flood if it happens, then restart without choke. This behavior is typical when a warm two‑stroke is over‑primed. [Elektroda, p2etwa, post #17199573]
How do I clear a flooded twostroke brushcutter?
Use this 3‑step reset:
  1. Remove the spark plug.
  2. Turn the unit upside down and pull the starter several times to expel fuel.
  3. Reinstall the plug and start with no choke. It should fire after this procedure. [Elektroda, p2etwa, post #17199573]
My spark plug looks dry after many pullswhat does that mean?
A bone‑dry plug indicates fuel is not reaching the cylinder. One expert noted the plug was "dry as pepper" despite a rich mixture. Suspect fuel delivery issues rather than ignition. Check primer action, fuel lines, and tank filter next. [Elektroda, Pedros050, post #17199553]
How can I quickly confirm a fuel delivery problem?
Do a syringe test. Inject a small amount of fuel through the plug hole, refit the plug, and pull to start. If it fires briefly and dies, you confirmed fuel starvation in the normal path. Proceed to inspect the fuel system. [Elektroda, Pedros050, post #17199586]
I see spark; should I still try another spark plug?
Yes. Swap in a known‑good plug to rule out a weak or failing plug under compression. As one helper asked, "Do you have replacement candles?" It’s a quick, low‑cost check before deeper diagnostics. [Elektroda, Pedros050, post #17199474]
When should I suspect the ignition coil on this trimmer?
If the air filter is dry and clean, yet starting fails despite fuel and plug checks, suspect the ignition coil. Replace the coil as the next step. Coil faults often present as intermittent or weak spark and hard restarts. [Elektroda, KrisPan, post #20148828]
Does a rich mixture cause smoking and harder starts?
Yes. A richer mix will "work and smoke more." Excess oil can wet or foul the plug, making restarts harder. Ensure the correct ratio and clear any flooding before retrying. Return to the recommended mix once it runs steadily. [Elektroda, p2etwa, post #17199573]
