Chinese Chainsaw Fuel Issue: Carburetor Clean, No Fuel Flow, Stalling After 3 Minutes
lukas102 19404 3
  • #1 16321208
    lukas102
    Hello, I have a problem with a Chinese saw, the carburetor is clean, no fuel is coming on, if it lights up it goes well, it gets screwed on the revolutions and can walk until the fuel runs out. If you put it out, it will last for 3 minutes, the candle does not light, which can be please help.
  • #2 16321274
    lisekey
    Help: 12
    Rate: 77
    Maybe the tank does not vent, it happens in my tank as I pour fuel to the max and the same fuel does not want to reach the carburetor, then I cast a part and fires the first time.
    Check the vent in the tank with me it looks like this:
  • #3 16321323
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1132
    Check what the predecessor advised, and the second thing is the carburetor, it was cleaned, but in these saws very often their faults occur. Maybe the membrane was damaged during cleaning or something else or it was not installed properly during cleaning. if it was unscrewed, maybe after re-screwing there is a leak somewhere and does not suck fuel well when turning the starter.
  • #4 20945651
    rafalchrzesny321
    And in my case, the hose from the tank to the carburetor broke and couldn`t suck in the fuel. But I cleaned it all up. 😀😀😀🤯
