Bosch MSA 15.5 VW LT35 ECU Pinout for Bench Testing and Power Connections
wacek 19774 4
  • #1 10035870
    wacek
    Rate: 65
    I have 3 damaged drivers from LT35 (Bosch MSA 15.5) and I would like to connect them outside the car. Please provide pin description.
    Will it be like this?
    +12 - 38, 42
    -12 - 1, 24, 46
    K - 61
    I am asking for information.
  • #2 10047316
    viper555
    Help: 582
    Rate: 2165
    31-1, 24, 39, 46
    15-38
    30-23, 45, 68
    61-yes
  • #3 10047855
    wacek
    Rate: 65
    Thanks @viper555
    Just in the meantime I found relay J317.
    Can I connect 38, 23, 45, 68 to +12 together or do I need to use a relay as in the installation?
    One more question.
    I have damaged some pins in them (oxidized and fell off). Is it a big problem to replace them individually from another controller?
    viper555
    Help: 582
    Rate: 2165
    For checking 30 and 15, they can of course be combined.
  • #5 10069689
    wacek
    Rate: 65
    In the meantime, more damaged ones arrived.
    After connecting, it turned out that after K only one from SDI corresponds, the others from TDI do not. I desoldered all EE (24C02) and only this one can be read from SDI.
    Does anyone have the original input for one of these drivers?
    074906021AK
    074906021AG
    074906021P
    074906021J
    074906021AM
    074906021AN
    The one I read is 074906021Q.
    If anyone needs it, I will of course share it.
