  • #1 10046153
    aryann
    request for identification at the occasion => is a coil or inverter?
    where could I get it?
    Does 8326Q specify any specific parameters of this element?
    if there are 3 same elements on the board, can you use some other replacement or if the replacement is all 3 the same ???
    thank you in advance for any suggestions
    I attach a photo:
    [I am looking for] R36W 4C 8326Q
    Added after 18 [minutes]:
    Thank you very much for your quick response ...
    the problem is that at some point the laptop died completely => HP PAVILION HDX series => I found on HP "Blank Screen LED Error Codes":
    http://h10025.www1.hp.com/ewfrf/wc/document?c...&docname=c01443366&lc=en&product=3769214#N445
    w / g this one flick of diodes (capslock / numlock) is a "non-functioning" processor => I decided to see what with it => I thought I would take / insert and see => I take out the plate and there is such a flower and these 3 elements in the vicinity of the slingshot. .
    if everything is correct ...
  • #2 10046282
