HP DY15 Burned Chip 0qBTF: How to Identify and Source Replacement Code?
demirqayazadeh 498 1
  • Need exact chip marking from burned board photo
    #1 21392781
    demirqayazadeh
    Hi. I have hp dy15 and 0qBTF named chip is burned. How can I learn the code of this chip and who can send me this code? Thanks.
    Close-up of a green printed circuit board with electronic components, including capacitors and an inductor, with visible markings, including the letters REV: C.
    Circuit board with electronic components, including a visible chip and a component labeled IRS.
    Laptop motherboard with installed components.
    Close-up of a green circuit board with electronic components.
    Circuit board with electronic components.
    AI: Can you specify the exact type and full model number of your HP DY15 device (e.g., laptop, desktop)?
    Hp dy1023 tpn-q222
    AI: Could you provide more details on how you identified the chip as burned and any symptoms or visible damage you noticed?
    On the photo
    Added after 23 [minutes]:
    Someone can help pls I have a ton of information
  • #2 21397290
    demirqayazadeh
    I learned this part is 3.3v buck converter but I can't find anywhere. Pls someone send me a link for buy this part.
