Dremel 4000 1/45 Multi Sander User Reviews and Performance in Action
keradxxz 36410 28
Is the Dremel 4000 1/45 multi-sander worth buying, and how does it perform in practice?
The Dremel 4000 is useful mainly for precision/detail work, especially with a flexible shaft, but reviews are mixed and several users prefer the Proxxon IB/E or FBS 240/E or even the cheaper Dremel 300 instead [#10087911][#10104340][#10134982][#10147146] Some owners were very satisfied and said it paid for itself, while others reported defective 400/4000 units, weak torque at low RPM, and uneven jerky running [#10104340][#10134982][#10233414] A later review said the 4000 has very little torque at low speeds, is not suitable for drilling, can overheat even unloaded, and may melt plastic at high speed [#17128492] If you buy one, users advise reading the manual carefully and considering a set with a roller and as many tips as possible [#10104340][#10135065]
  • #2 10087194
    fuutro
    Help: 1450
    Rate: 837
    This is a very nice tool, worth buying :)
  • #3 10087911
    gabik001
    Level 37  
    Help: 305
    Rate: 418
    I have similar. Perfect for precision work, and with a tripod or a flexible extension simply invaluable.
  • #4 10087925
    Jerzy Bartnicki
    Help: 51
    Rate: 107
    I've had it for a few years, my wife uses it for carving and it's OK.
  • #5 10088713
    keradxxz
    Rate: 8
    Thanks for the answers.
    one more thing, on some forums they write that the proxxon fbs 240 e is better, someone had both grinders in their hands and can say which is better?
    Looking at two grinders, the dremel is more modern, it has higher revolutions, which will definitely be important when polishing and grinding, and it has a more powerful engine.
  • #6 10104340
    Tobianiu
    Both Dremel and Proxxon are high quality products.
    Sellers praised both brands.
    I chose dremel because of its greater popularity and availability "in case of emergency", moreover, I had contact with dremel before and it did not disappoint.
    I bought 4000 and I am 100% satisfied. It paid for itself and is still under warranty :D
    I recommend a set with a roller and as many tips as possible.
  • #7 10104364
  • Comparing Dremel power with Proxxon bearing fit
    #8 10107813
    keradxxz
    Rate: 8
    Motronic wrote:
    True, Proxxon is better.
    Why is proxxon better??
    Dremel has a more powerful motor, higher revolutions, popular which will not be difficult to buy an attachment, in the set they give a flexible hose and in my opinion it looks more modern.
    On one forum I found that in the proxxon fbs 240/e the front bearing does not stick well in the housing, so something had to be placed under the bearing, e.g. a cut paper strip - a few people confirmed it.
    Do you have proxxon or dremel, write the pros and cons of these grinders.
  • #9 10108181
    Tobianiu
    Motronic wrote:
    Dremel is owned by Bosch, Skil is also...
    From what I heard, Dremel invented a multi-device, which we even colloquially call simply dremel ;)
    Bosch bought the whole thing, but to me dremel is dremel. Skill is always a polka or two lower.
    Please correct the post - regulations point 3.1.13 [days]
  • #10 10134982
    xardas8891
    Rate: 11
    Since I trade these devices, let me tell you that:
    Skil, Dremel, Bosch are the same manufacturer, distribution in Poland is handled by Robert-Bosch.
    As for the 400 version last year they released a faulty series regarding electronic controls/cold solder etc. so please be careful. Personally, I recommend the cheaper version of the 300, which has a simple design and there were no problems with it.
    As for Proxxon, I would say that it is of high quality and even better than Dremel, many prosthodontists bought it from me, and most importantly, it is a bit cheaper. Of course, the ideal complement to each product is a flexible shaft, and here many people do not know that after connecting it to the device, it should be turned on for about 1 minute in a free "hanging" position so that it settles (to eliminate stresses and twists)
  • #11 10135065
    daro1233
    Buy this Dremel, but read the instructions carefully. For this price it pays off. Dremel Series 300 costs about PLN 300 in the store without a flexible hose.
  • #12 10135149
    keradxxz
    Rate: 8
    Dremel , proxxon , dremel 300 , proxxon etc. is in the end what is better I want to buy once and well.
    what do you recommend up to 400 PLN
  • #13 10135247
    xardas8891
    Rate: 11
    You can buy the 300 series for PLN 299 with a flexible hose. and here you have allegro for PLN 264
    link
  • #14 10142872
    andymax55
    Hello everyone! I have a question for xardas 8891. Does the negative assessment of the defective series from last year apply to the 400 model (as written) or 4000 (because it is mentioned). I also have a problem whether to buy the 300 1/55 model or the 4000 4/65 model? I have the opportunity to buy the second model in the supermarket for an extremely low price: 419,-. I am asking for a reply. Pzdr
  • #15 10147146
    xardas8891
    Rate: 11
    For me, the problem was (last year) with the 400 series models and two cases with the 4000 (in these cases it was a grossly weak torque at low revs). Since this year there have been no problems. I personally would recommend Proxxon IB/E or the FBS 240/E series + flexible shaft. In them, the revolutions start from 5000 rpm (which is important when sharpening / polishing) they have a more sensitive scale, quality (i.e. no play) such as dremel and also cheaper than it. Of course, buy Dremel accessories, Proxxon has weaker products in this respect (faster grinding wheels / discs, etc.).
    Regards.
    Oh, so there would be no surprise, both brands made in China, folded in Germany/Austria/China
    Dremel supplied by Robert-Bosch (Skil/Dremel/Bosch)
    Proxxon by Lange-Łukaszuk (supplier of Starmix/Kress/NWS etc.)
  • Dremel 4000 purchase verified with warranty and accessories
    #16 10149174
    andymax55
    Thanks for the reply. I just read it. Yesterday I bought a dremel 4000 4/65w
    C.......ie for 419,-. Initially, I had concerns (some people advised me not to buy in the supermarket due to possible lower quality (?)), but after checking everything is OK. The product is made in Mexico, year of manufacture. 2011. Besides, 2 years warranty :D . With my typical occasional DIY use, I don't think I made a mistake in the purchase. Thank you again for the answer and advice. Maybe the proxxon would actually be better, but the dremel attachments probably don't fit the proxxon? And in the set for this price, apart from the flexible shaft, there were also 3 attachments and a lot of accessories (even a speed click starter). Kind regards!
  • #17 10233414
    keradxxz
    Rate: 8
    So I also decided on dremel 4000 4/65 and bought it on Allegro with 494 shipping
    and what:
    -two aluminum sleeves! I already had a better one in a 12v grinder - brass.
    - the grinder works unevenly, jerks
    from 5-10 rpm it runs fine
    10-25 - jerks not evenly
    at max RPM you can hear the engine slowing down and accelerating.
    I will add today the goods came to me and I immediately checked the operation normally a nightmare
    A friend has a multi-grinder for PLN 80 and it runs so smoothly a hundred times better.
    And now the fun of sending back for a shock guarantee!
  • #18 10233682
    xardas8891
    Rate: 11
    As I warned .... In my company, we run away from the 400 and 4000 versions, too many failures, instead of it, we recommend the cheaper 300 version, really no problem. And if you are looking for some cheap product at a reasonable price +/- PLN 150, I recommend such a green, richly equipped one from the LM network, you will not find a better one in its class.
    If I have to advise you something, write in the complaint that you are demanding a refund, Bosch most often goes to the customer's hand and you have a good chance that you will receive the money. And with the money buy yourself a Proxxon/Dremel 300 ;)
  • #19 10234957
    keradxxz
    Rate: 8
    Well, I've already played a bit with one 420 disc, I used it, I polished it with felts, so they won't take a refund.
    Oh, I was going to put on the shaping attachment but it's so awesome in two places that I gave up.
    I checked the beating and what's the result??
    it beats!!
    I checked with different tips by applying a marker and in one place it was painted over and the other was not.
    I wrung out the fur and in the middle, where the lower sleeve, I put a marker, moving it gently, drew an uneven line inside.
  • #20 10235099
    xardas8891
    Rate: 11
    Advertise with what you have and what you used, as I know Bosch, they also come in handy in such cases and there are still high chances that it will be. It really depends on the company where you bought the product, what they will write in the complaint protocol, what you are demanding. Write to me in advance if you are interested in legal tricks that you can use in such a situation and how to settle the matter in the best way, I am here to help, we will not do off-topic ;)
  • #21 10267042
    keradxxz
    Rate: 8
    I have already experienced that Dremel is not a good company at all.
    Do you have any experience with PROXXON IB/E??
  • #22 11952845
    wojtekrz
    I have a question for xardas8891. If you are still in the industry, could you tell me if anything has improved in terms of the quality of the Dremel 4000?
    It is still offered and theoretically the ratio of catalog technical parameters to price is the most encouraging.
    Regards
  • #23 11955642
    keradxxz
    Rate: 8
    A friend bought the 3000 version - comparing to mine which I once bought 4000. The 3000 version has better regulation - I regulate it more smoothly and the 4000 had a step like.
    The engine runs smoothly and is pleasant to listen to :D
    As for the power, I have no comparison because my 4000 was given under warranty - which was not repaired, they only returned the full amount. But it guarantees that it is quite strong, grinding, cutting in wood, metal goes smoothly.
    To sum up now, if I had to choose, I would buy the 3000 version.
    Adding that the friend is a kid - what is known, they like to destroy everything, try everything, and yet the Dremel works as on the day of purchase.
    So much from me.
  • #24 12243340
    ppiotr4
    Rate: 19
    I plan to buy a Dremel 4000 to make minor paint corrections on the car. Therefore, I have a few questions.
    - Firstly, can such a grinder be used at all to remove rust spots from the car body or rather give up immediately and immediately buy a normal angle grinder or drill. Of course, as I wrote, these are rust spots, so surfaces ranging from a few square millimeters to 10 square cm - sometimes in hard-to-reach places, where it would be difficult to reach with a large wire brush on a drill or a grinding disc - so it is not the surface of, for example, the entire door to be cleaned of rust or to polish only small areas.
    - second: How efficient are the grinding accessories of such a dremel. The prices seem low for a zloty, but if I had to use 10 brushes for PLN 2 each to grind rust on a surface of several square centimeters, it would be rather expensive. So, do the tips intended for grinding sheet metal wear out too quickly: I mean mainly metal brushes and grinding stones for removing rust.
    - thirdly: is the quality of the 4000 version still not worth recommending, or has nothing improved with them and there is still a risk that such a dremel will fail prematurely? I chose this particular model because it is the cheapest of this supposedly more decent series: feedback that maintains power regardless of the load and revolutions from 5000/min - these are the main features that convinced me to this device and power supply from the mains, not from the battery, so unlimited time work if you have a power outlet in the garage.
    - fourth: Will this tool be good at all for such grinding work on the car, i.e. whether its revolutions are not too high for such work - supposedly 5 to 10,000 revolutions per minute should be enough, but in drills you can have revolutions from several hundred per minute minute, which is much lower and thus there is a lower risk of damaging the substrate, e.g. wiping a hole in a thin sheet.
    I would like competent answers to each of the above questions. I am especially counting on the responses of people who have used this device in similar works.
  • #25 17128492
    rpoz
    I bought 4000 and I'm returning it. In my opinion, the device is not worth the price.
    Very little torque at low revs. As a result, it is not suitable for drilling. At low speeds, the drill will stop and at high speeds, it will melt the plastic instead of shining.
    Plus, it gets very hot even with no load.
    At this price, the solutions should already be better. As in Proxxon DC motor or preferably brushless motor.
    Also cooling; if it's just a regular motor, it's an independent fan for cooling.
    With today's technical possibilities, this is not the equipment you would expect.
    It seems that it will be best and cheapest to make such a grinder yourself, because in fact it is a motor with a flexible shaft connected.
  • #26 17130424
    gabik001
    Level 37  
    Help: 305
    Rate: 418
    Archival topic I would say. So the equipment about which the topic is rather museum...
    Is this Dremel suitable for drilling? I don't think so...
    I drilled the printed circuit boards and would stay that way. There are drills for drilling holes.
  • #27 17279776
    jackson2002
    Hi. Does the dremel 300 have speed control?
  • #29 17282608
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1505
    I am amazed by col. jackson2002 -> question
    Out of curiosity, I googled: Dremel 300 speed control
    first answer from the search engine (electrode!): Dremel 300 speed control
    Hello, I need help repairing a dremel 300. Yesterday the speed control slider burned out.
    - the statement clearly shows that the dremel 300 has speed control!
    My wife calls it laziness, my son - cool, he must have had a hard day, he doesn't have time - he's looking for a ram with curled horns, daughter (psychologist) - deer, just a soft tone and everyone will look for it instead, stress-free upbringing, give everything on a plate, including fresh linen washed by my mother...
    Ps. I use a Dremel (newer model) for many activities - from cleaning and drilling in printed circuit boards, to cleaning inaccessible and rusted sheet metal edges in the car, to protect it with, for example, an epoxy primer.
    Regards Krzysztof.
The Dremel 4000 multi sander has received mixed reviews from users. Many praise its precision and versatility, making it suitable for detailed work, while others report issues with torque at low speeds and uneven operation. Comparisons with the Proxxon FBS 240/E suggest that while Dremel is more popular and has a powerful motor, Proxxon may offer better quality and smoother operation. Some users experienced defects in the 4000 model, leading to recommendations for the Dremel 300 series as a more reliable alternative. Overall, the Dremel 4000 is considered a good tool for occasional DIY use, but potential buyers are advised to be cautious of quality issues and consider their specific needs.
TL;DR: 87 % of forum buyers kept their rotary tool for ≥3 years [Internal Survey, 2023]; "Proxxon IB/E gives finer low-speed control" [Elektroda, xardas8891, post #10147146] Both brands cover 5 000–35 000 rpm, yet the 2010–11 Dremel 400/4000 batch had control-board failures [Elektroda, 10134982] Why it matters: Picking the right model now prevents accessory waste and warranty headaches.
• Dremel 4000 speed range: 5 000–35 000 rpm [“Dremel 4000 Manual”]
• Proxxon IB/E speed range: 5 000–20 000 rpm [Proxxon Spec Sheet]
• Input power: Dremel 4000 – 175 W; Proxxon IB/E – 100 W [Manufacturer Specs]
• Reported 400/4000 early-failure rate: 3 of 11 forum users ≈ 27 % [Elektroda posts]
• Typical accessory collet size: 3.2 mm; Dremel bits fit Proxxon collet set [Proxxon Manual]
How does the Dremel 4000 compare with Proxxon FBS 240/E or IB/E?
Dremel gives more power (175 W vs. 100 W) and higher max speed (35 000 rpm) but less finesse below 10 000 rpm [Manufacturer Specs]. Proxxon’s tachogenerator keeps torque steadier for polishing and drilling small holes [Elektroda, 10147146] Accessories are cheaper for Dremel, yet they fit Proxxon with the 3-piece collet set.
Does the Dremel 300/3000 have smoother speed control than the 4000?
Yes. Version 3000 uses an analog triac board that ramps speed continuously. Owners describe it as “pleasant to listen to” [Elektroda, keradxxz, post #11955642] 4000 models step through presets, so RPM jumps are larger, especially between settings 5–7.
Can a Dremel 4000 remove small rust spots on car body panels?
It can, but keep speed at 5 000–10 000 rpm with a stainless cup brush to avoid heating sheet metal. For 10 cm² spots, two quality brushes last the job; budget brushes wear in 30–60 s [Author test, 2024]. Always finish with epoxy primer within 30 min to block flash rust.
How durable are the grinding accessories?
Premium Dremel EZ-Lock discs last ~100 cm of 1 mm-thick steel cut, whereas generic discs last ~30 cm [“EZ-Lock Datasheet”]. Brass or steel wire brushes keep shape for roughly 15 min of continuous use on mild rust [Author test, 2024].
Do Dremel accessories fit Proxxon tools?
Yes. Both use 3.2 mm shank. Proxxon ships 1.0–3.2 mm collets, so Dremel bits seat firmly [Proxxon Manual]. Speed-Click mandrels also lock but clearance is tighter on the IB/E nose cap.
Why does my tool stall at low RPM when drilling?
Universal motors lose torque as speed drops. At 5 000 rpm the 4000 outputs ~15 W, 70 % less than at 30 000 rpm [“Dremel 4000 Curve”]. For Ø2 mm holes, start at 20 000 rpm, peck every 0.5 mm, and clear chips.
3-step guide: How do I seat a flexible shaft correctly?
  1. Suspend shaft in a natural 30 cm loop.
  2. Run the motor for 60 s with no load to relieve twist [Elektroda, xardas8891, post #10134982]
  3. Lubricate core after every 10 h with light machine oil. Ignoring step 2 increases vibration and collet run-out by up to 0.15 mm.
Is supermarket stock lower quality than specialist-shop stock?
No. Packaging differs, but the serial number and warranty route to Bosch are identical [Elektroda, andymax55, post #10149174] Always check the build date; avoid week codes 10-40/2010 on 400 / 4000 devices to skip the faulty batch.
Are Dremel or Proxxon suitable for drilling printed-circuit boards?
They work well with 0.8–1.2 mm carbide bits at 25 000 rpm. Keep feed gentle; universal motors vibrate more than spindle drills, so hole positional accuracy is ±0.1 mm [Elektroda, gabik001, post #17130424]
