Choosing Between Dremel and Proxxon for Jewelry and Model Making Projects
Kadah 13650 9
Which durable rotary tool should I choose for jewelry making and model making: Dremel or Proxxon?
Both Dremel and Proxxon are good choices, but the thread leans slightly toward Dremel 4000 for power and ease of use, while Proxxon is often seen as the more solid and quieter option. One user specifically recommends the Dremel 4000 because it has sufficient power, smooth speed regulation, and a separate switch button [#18149498] Proxxon gets praise for feeling more solid, having good accessories, and offering higher torque at low revs, with one user noting the FBS 240/E worked trouble-free for about 10 years [#18140033] [#18139735] [#18149552] A downside mentioned for Dremel 3000 is that it lacks a separate on/off switch and can be noisy, though it still handled metal and plastic cutting and only needed bearing replacement after about 2.5 years of regular use [#18140026] [#18140110] Proxxon FBS 240 was also described as a nice impression and cheaper than Dremel 4000 [#18149498]
  • #1 18139712
    Kadah
    I`m looking for a nice DIY tool. I make jewelry, and I also plan to make models, so the question is: which multi-grinder should I choose? I don`t want to buy a Chinese one that will burn out when I least expect it, but something more durable that will serve me for a long time. I found two companies - Dremel and Proxxon - and I am asking for help in choosing which of them is more trustworthy. And if anyone has something else, proven, I`d love to hear it too.
  • #2 18139730
    koala106
    Help: 471
    Rate: 1240
    I have Dremel micro tools and a lot of accessories and I can recommend them. I also used Proxxon and it`s ok.
  • #3 18139735
    siewcu
    Help: 133
    Rate: 458
    Some say that Proxxon is better because it has higher torque at low revs.
    djramu
    Help: 26
    Rate: 24
    Personally, I use a Dremel. Proxxon seemed somehow "plastic" to me. Now, after several years of use, I can confidently say that Dremel works. The 3000 model coped with cutting a 20x3 flat bar. I used discs with the speed click system. It wasn`t a pleasant cut, but as the only tool I could use, it did the trick. Ordinary screw-on discs from L*** lasted a few seconds.
    And now the disadvantages:
    Noisy - However, high speeds and fan cooling do their job. I heard that Proxxon is incomparably quieter. I don`t know, I haven`t had a chance to check.
    Bearings - Unfortunately, after about 2.5 years of use, I had to replace the bearings. In fact, he didn`t have it easy. Let`s say 10 minutes a day. But when I did something, I did it specifically.
    Now I would also have a dilemma.
  • #5 18140033
    m2c
    Level 19  
    Help: 29
    Rate: 31
    Take both in your hand, Proxxon seems much more solid. The same applies to accessories, e.g. a tripod. What annoys me about my Dremel 3000 is the lack of an on/off button, you have to set the speed every time.
  • #6 18140046
    djramu
    Help: 26
    Rate: 24
    Right. I forgot to add. This is very annoying. I added a socket with a switch at my desk. There`s always a solution...
    However, no matter how you look at it, the lack of an on/off switch is a disadvantage.
    koala106
    Help: 471
    Rate: 1240
    The Dremel 3000 I use - I cut holes for automation elements in metal and plastic panels, I hit several boxes with discs. I managed with an extension cord with a foot switch installed. The lack of an on/off switch is a disadvantage, but it is survivable. I still have a small Dremel that was powered by two 18650 batteries, but the regulator failed and I changed it so that it now regulates the speed from the power supply via PWM and it has been like this for a few years.
  • #8 18140782
    Kadah
    Ok, and if I decide to choose Proxxon, can you recommend a specific model?
    wiktor13570
    Rate: 39
    I asked myself the same question some time ago. Ultimately, I chose Dremel 4000 and I can certainly recommend it, it offers sufficient power, smooth speed regulation and, most importantly, a separate switch button.
    As for Proxxon, I had the opportunity to use FBS 240 and it also made a nice impression on me, no better than Dremel.
    Overall, both tools offer plenty of accessories, and I`ve also found models on Thingiverse that make the job easier ;)
    An additional advantage for Proxxon is the lower price than Dremel 4000, but I would choose Dremel.
  • #10 18149552
    Felini
    Moderator
    Help: 124
    Rate: 433
    I have been using Proxxon FBS 240/E for about 10 years, no complaints so far.
    I bought this model because it is powered directly from the 230 V network.
The discussion revolves around choosing between Dremel and Proxxon multi-grinders for jewelry and model making projects. Users share their experiences, highlighting Dremel's reliability and performance, particularly the Dremel 3000 and 4000 models, which are noted for their power and speed regulation, albeit with a lack of an on/off switch. Proxxon is mentioned for its higher torque at low speeds and quieter operation, with the FBS 240 model receiving positive feedback for its durability. Users recommend handling both brands to assess build quality, and while Dremel is favored for its performance, Proxxon is recognized for its lower price and solid construction.
