Temperature Sensor Cable Selection: Indoor (8m) & Outdoor (20m) - Best Options & Recommendations
luki30 42628 4
  • #1 10107820
    luki30
    I have a question about what wire to lay for the temperature sensor which will be inside the house about 8m from the cooker and the other sensor outside the house at a distance of about 20m.
  • #2 10108071
    H3nry
    Level 32  
    Help: 165
    Rate: 289
    What type of sensor is it? What device does it work with?
  • #3 10109136
    luki30
    This is what I do not know what type the sensors are to be and they are supposed to work with the stove, and exactly with its controller, but I do not have any about these sensors and I have to put the cables and here is the problem
    Please correct the spelling of the post. [retrofood]
  • #4 10109304
    Krzyś33
    Help: 58
    Rate: 104
    Hi. You do not write anything about the type of controller and furnace. For the Buderus cooker, generally YDY2x1.5 type installation wires are used indoors and YKY2x1.5 outside.Regards.
  • #5 10110294
    kasprzyk
    Electrician specialist
    Help: 354
    Rate: 671
    Most of the wiring in boiler rooms for outdoor temperature sensors I make: OMY 2 * 0.75
    I never put larger cross-sections, there is then a problem with connecting a thicker wire in the sensor itself or on the boiler plate - although here it is easier to extend or reduce the wire - but it is always additional time spent on arming the boiler room. Lead a 3 * 0.75 in line to the external sensor.
    The question is what sensor is inside? Maybe more about a temperature controller? If it is the latter, then very often the boiler automatics "cut" is a regulator with a NO relay, it is supplied with a voltage of 230V - according to the provisions of min. the cross-section of the permanently laid cable is 1.5mm - I would put a 3 * 1.5mm line
    Regards
