How to Determine Computer's Age: Identify Year of Manufacture & Production Date
iamtheone 72802 11
  • #1 10142985
    iamtheone
    Help: 72
    Rate: 39
    Is it possible to check the year of manufacture of the computer?
  • #2 10143009
    fuutro
    Help: 1450
    Rate: 836
    There may be overprints on the components that allow you to evaluate something.
  • #3 10143074
    prosiak22
    Help: 15
    Rate: 129
    aida32 see the date of the bios because I rarely install a new one :)
  • #4 10143133
    daavid117
    Help: 263
    Rate: 167
    As for the "mileage" of the computer, you can check the number of hours worked by the disk (as long as it was the same all the time from the beginning).
  • #5 10143681
    pietrach
    Help: 8
    The age of the computer can be determined after the year of production of the northern motherboard chipset, because the current chipset on the market is mounted to the board, so if the chipset is from 2006, the year of production of the motherboard should also be the same. When we bought everything new, the disc also, if the chipset on the disc is from 2006, the whole computer was probably bought in 2006.
  • #6 10144208
    Quamis
    Help: 34
    Rate: 22
    Just check in which years all components were produced, the youngest one will give you the answer.
    Please forgive me for the lack of Polish characters, but I use a computer with Dutch windows for which there was a fight and for which I received a warning a few days ago.
    Deign to adapt the form of your speech to linguistic norms. [M]
  • #7 10144229
    Matuzalem
    Help: 1651
    Rate: 1095
    Branded - yes (as a rule), folding - no (the best thing to do is to say that it is not older than ...).
    Of course, all assuming that "computer" is defined in a logically consistent manner.
    Doradztwo podatkowe
    Wilczyńskiego 25/13, Olsztyn, 10-686
  • #8 10144410
    SKM 1964
    Help: 150
    Rate: 660
    Why bother so much, you'd better find a warranty card, and the date is there.
  • #9 10145653
    szymon7x7x7
    Help: 15
    Rate: 21
    Forget these hints ... and how do you know that he has a warranty card? I guess if he had her, he would have seen it.
  • #10 10148832
    d3zynh
    Help: 29
    Rate: 21
    On the motherboard (which was least often mentioned) you have a motherboard model on the laminate and underneath it with small letters "rev 1.03" - for example, and in "google" enter the manufacturer's brand, model along with the version and add "production date" or "date" and check the oldest entries. Rather the simplest solution.
  • #11 10148858
    daavid117
    Help: 263
    Rate: 167
    As long as the motherboard in the computer is the same that was installed at the beginning - when you buy it ... This is also the case with each component. The age of the computer can be determined only if it is a company computer or if there are any "papers" on it.
  • #12 10156083
    iamtheone
    Help: 72
    Rate: 39
    Thanks for the answers, the bios date is 99 or 98 (I don't remember exactly) so the computer is probably quite a bit old: p
✨ To determine a computer's age, users can check various components for production dates. Key methods include examining the BIOS date, which can indicate the computer's age, and checking the motherboard's chipset production year. The chipset's date often reflects the overall age of the system. Additionally, users can look for overprints on components, check the number of hours the disk has been used, or find the warranty card for the purchase date. If the motherboard and components are original, their production dates will provide a reliable estimate of the computer's age.
