BIOS AMI - Fix System Clock on Intel DG31GL Motherboard with Pentium E6300 Processor & Windows XP
Eisenmann 14742 5
  • CMOS clock error persists after battery reset
    #1 16504468
    Eisenmann
    Good morning,
    I have a problem with an office computer, my father recently brought such equipment from work, because they exchange in the company for a newer one.
    Specification:
    - Processor: Intel Pentium E6300 2 x 2.8 GHz,
    - Motherboard: Intel DG31GL (B),
    - Chipset: G33 Express,
    - South Bridge: 82801GB,
    - System: Windows XP x86,
    - Graphics: P35 / G33 (Bearlake) Integrated Graphics Controller,
    - BIOS: AMI,
    - RAM memory: 2 x 512 MB 667 MHz DDR2 Dual-Channel Kingston (KVR667D2N5 / 512),
    - Power supply: Logic 400W (LOGIC-400ATX),
    - Network Card: Intel PRO / 100 VE,
    - Audio: 82801G HD Audio,
    - Disk: Samsung: HD322HJ 320 GB;
    The computer started up normally the first time, I was able to rip the data to an external disk, it walked a little slowly because it was misconfigured (1.5 GB of memory consumption after system startup). He worked only an hour. The only setting that I changed was the monitor resolution, I adjusted it to Full HD. I have researched what hardware I am dealing with with programs like CrystalDiskInfo and CPU-Z. Then I restarted the equipment. (Computer has shut down normally, restart function).
    When the computer rebooted from the BIOS level, it made 4 short beeps, did not turn on. Please note that nothing was tampering with it in the meantime, opened, etc.
    I thought it was because of the dust, like in office computers. I thoroughly cleaned the entire central unit, including the power supply. I put the kit back together and tried to run. The sounds from the speaker are the same.
    Four short - Error related to the system clock.
    What I have already tried:
    - any combination with RAM,
    - reset the BIOS settings when removing the battery,
    - more thorough cleaning of the contacts in the RAM memory slots,
    - remove RAM of the same type from another computer and insert into the slot,
    - theoretically exchange (I'm not sure it's not new) for a working battery for the BIOS memory;
    When removing RAM from the slots and starting the computer - 3 short beeps.
    When removing memory from this computer and inserting a working one from another - 4 short beeps.
    When removing RAM memory and BIOS battery - no sounds.
    Three short - problem related to the problem of reading the first segment of RAM (64KB)
    Is there anyone who has had a similar hardware problem?
    How did he solve it?
    Can it be bypassed without visiting the site?
    Anyone else have any ideas on how to solve this problem, what to try?
    I really care about this computer. I don't want to see the first answers like "Take it to the site if you care!"
    Sincerely,
    Eisenmann
    Added after 20 [minutes]:
    UPDATE: I also tried it with a battery that is 100% functional, to no avail - still 4 sounds.
  • #2 16504496
    Kasek21
    Help: 4981
    Rate: 3547
    Check if the battery is not discharged.
    I understand that you checked by connecting only one memory module in different slots?
    Bo: 4 short - system clock or first memory plug error
  • #3 16504507
    Eisenmann
    It is possible that the battery is discharged, although I tried to use a battery from another computer and the same effect.
    I tried all the combinations, (there are 2 slots) I put only in the first, then only in the second, then both at once, the same effect.
    I will go to the store and buy a completely new one to be sure. If anyone has an idea yet, write boldly.
  • #4 16504517
    djacek
    Help: 19
    Rate: 29
    Have you seen the capacitors on the board or are they swollen? :(
  • #5 16507269
    Eisenmann
    Whole and healthy capacitors. I ordered CR2032 batteries, when they come, it remains to be seen if the problem is resolved :)
  • #6 16519553
    Eisenmann
    The motherboard is damaged, unlucky, hah ;) Thank you for the quick answers :)
    Sincerely,
    eis
