[Solved] Deciphering Production Date on Newly Purchased Bosch Battery
rt14 269310 37
How do I read the production date from a Bosch battery?
Check the long embossed number on the top cover; Bosch said the date code is in positions 4–6, with the first digit for the year and the next two digits for the month, so for example 209 means September 2012 [#13618751] For later batteries the code changed to a DDD format, and the thread gives examples such as 417=January 2014, 418=February, 419=March, 420=April, 453=May, 454=June, 455=July, and for 2016 617=January through 660=December [#14186348][#16264401] If you cannot find that top code, another reply says Bosch batteries may also have a burned circular mark on the bottom, with an arrow for the month and two larger digits for the year [#13250245]
  • #1 7586996
    rt14
    Rate: 25
    Hello, I would like to ask how to read the date of production from the bosch battery I just bought
    fuutro
    Help: 1450
    Rate: 837
    I do not know, do you have photos? The battery with this date is enough.
  • #4 7587088
    rt14
    Rate: 25
    I found n the page given by radekkubiak9312.
    thanks a lot.
  • #5 10437708
  • #6 10439337
    telwisalfa
    Help: 34
    Rate: 86
    stratos37 wrote:
    Hello, on the Bosch S4 battery I have stamped No. 796112, when it was produced?
    In my notes I found something like:
    In the case of a Volvo / Bosch battery the first three characters are the production plant code, the next three are the production date code. The production date code means the year and month of battery production.
    mark 4 is the year
    characters 5 and 6 are the month:
    81 - January
    82 - February
    83 - March
    84 - April
    85 - May
    86 - June
    87 - July
    88 - August
    89 - September
    90 - October
    91 - November
    92 - December
    Example
    Serial number: F2B285264 0050 935714
    Battery production date 285 -> May 2002.
  • #7 10517893
    maxiu202
    Rate: 17
    what if I have such a number on aku?
    C16 108 091 042 279 367 5 ??
    And free number on aku 108 how should I read this date ??
  • #8 11468652
    cyss_cs
    Help: 9
    Rate: 17
    And what will the serial number of aku with the production in 2011-2012 look like?
  • #9 11589396
    tomi1125
    Rate: 26
    I have a battery with the inscription renault (probably from the first assembly) of the Czech production with the designation 130811, that is from August 2011?
  • #10 13229497
    ReniferKaribu
    Rate: 53
    Will you tell me where I will find the year of production, on this Bosch 77Ah780A battery?
    CAC310021 0120
    536073
    It seems that this is the number 310 or October 2013, but who knows.
    I wonder what factory.
  • #12 13231842
    ReniferKaribu
    Rate: 53
    Sure, I read. The problem is that nothing comes of it.
    Will write again how it looks like CAC310021 0120 a
    536073 is stamped, burnt.
    I met with the fact that the first digits from the left is the year and month that is 310. According to what is on this page, it is visible on average. [/ B]
  • #13 13232571
    januszx3
    Help: 214
    Rate: 420
    Helpful links are: http://www.batteries-faq.com/activekb/getattachment.php?data=NTN8RGF0ZSBjb2Rlcy5wZGY%3D,
    http://www.ilmc.org/Basel%20Project/Workshop/...es/Bosch%20Technical%20manual%20for%20LAB.pdf [url=]Link[/url]
    Check, in addition to the subtitles you have mentioned, there is no round label with the date of production code described in the above link
  • Battery has only stamped top numbers, likely code 310
    #14 13233280
    ReniferKaribu
    Rate: 53
    At the moment I can not check, but probably there is no such a sticker. All numbers are filled on top.
    Telwisalfa gave an example for the year 2003. In this way, he fits 310, as the production date code. According to his information, October was number 90. Here is 10. So they have changed something, or it's a week.
    Tomorrow, look at the battery
    I looked. I can not see the sticker. There is only what I wrote, ie stamped numbers on the top. It's probably the number 310. I'll wait maybe someone has a similar one and we'll set it together. Alternatively, I will call some Bosch service. Maybe someone will say something.
  • #15 13250245
    _TrotyL_
    Rate: 85
    did you look at the base of the battery, as if the bottom from the outside?
    Just a moment ago on Bosch S4 I found there burned out a characteristic circle with an arrow in the middle. As you can guess, the arrow indicates the month of production and the two larger digits of the year.
    Regards, _TrotyL_.
  • Battery date code may indicate October 2013, not production date
    #16 13250378
    ReniferKaribu
    Rate: 53
    From the bottom? We did not look there because somewhere I read that there is nothing downstairs. Hm .. you can check.
    Only I do not know if such a sign does not apply to the year of production of the plastic itself. Oh, I looked at these plastic poles from + and _ poles. For example, on one plastic overlay there is an arrow marked on 13 and 9 (circle and scale from 08-13) and on the other - :D .
    Apparently the date the battery was created and the date of flooding is sometimes two different matters.
    Following this line of reasoning, 310 this may actually be October 2013. However, 100% certainty is missing.
  • #17 13256438
    ReniferKaribu
    Rate: 53
    Sometimes it's easiest to call. I've tried several times with different services from Warsaw via Łodź. There is no information everywhere. Nobody knew anything. Finally, the last service and it is. The Hemar company in Toruń. Bosch service. Applause for competence.
    As I expected. 310 to October 2013. Months from 1 to 12. So much in the subject.
    Do not get a lounger from 301 :D
  • #18 13264694
    bogiebog
    Help: 2569
    Rate: 1530
    CAC310021 0120
    536073
    bought today Bosch S4 Silver 830A 95AH, blue housing
    code engraved on top of the G4C battery 309 192 0336 536567 ....
    code printed separately on the side of the 309 battery
    date code 309, therefore, September 2013
  • #19 13268138
    ReniferKaribu
    Rate: 53
    Yes, September 2013. That is 4, 5, 6 digits in the issue.
  • #20 13314090
    freesbee
    You do not think that the one bought on February 5, 2014 with the production date of September 2013.
    it's a bit "layered" for a new one?
    Did you check what capacity it had at the time of purchase?
  • Asking about Jenox Classic 74/680 date and value
    #21 13375199
    ReniferKaribu
    Rate: 53
    Frisbee. No problem. The battery has gone down well over half a year. Everything as below is OK. Even a monthly, but poorly stored one will be weaker.
    My Bosch is from October. Bought at the end of January (it was about this above) At the time of purchase it was 12.5, a little more. I recharged to stronger values, went to the car.
    With batteries it is a lottery.
    I have a problem again. Specifically, father. A few days ago his battery (probably Nord star Sznajder) refused to obey. Looks for something inexpensive and good. He met Jenox in the neighborhood. You know, do you know if it's worth it?
    Where is the date of production on this battery? Jenox classic 74/680. Even urgent.
  • #22 13618751
    dominikdubiak
    The production date can be checked. There were many opinions on the Internet that the production dates have not been crowing for some time, others have written that you can still ... Want some information (not to make a fool of yourself in the store claiming that it will be possible, and then some space date would go out to me I went to Bosch with this question. Here's the answer I received today:
    on each battery on the top cover a long battery number is embossed, in which the item of production date is placed under item 4, 6. You can use this number when checking the date of production.
    The first digit is responsible for the year (2- 2012, 3- 2013), the next two for the month (from 01 to 12). E.g. 209 - September 2012
    In addition, the seller is required to enter the production date code in the warranty card. Also with the code, you know the date of production. The card must be fully filled in along with the details of the distributor (not only the seller)!
    Regards
  • #23 13908381
    krasnalito
    I bought a Bosch Silver s5 74Ah battery yesterday, according to the above key, it turned out that the product's date code is: 419 means that 2014, but what should the numbers mean?
    1 and 9?
  • #24 13910765
    _TrotyL_
    Rate: 85
    As you can find information above, it means the nineteenth week.
  • Questions Bosch battery date-code interpretation for S5 310 and S4 455
    #25 13950886
    ReniferKaribu
    Rate: 53
    As for the numbers, it is known, but .... you say that the second and third digit is a month or another week? I have doubts again.
    So what will the year and month of the battery, where the three digits are Bosch S5 310 and Bosch S4 455, respectively? In the second case it does not fit for a week. Maybe there is another numbering. I do not know.
    I remember that once I checked on the Bosch website (by phone) 310 means 2013, October because numbering was changed and it was supposed to be months from 1-12. It's in the case of S5 and as it is from S4, I do not know. I look for the phone for this service and check again because it's already funny. :D
  • #26 13952914
    ReniferKaribu
    Rate: 53
    Today I called one of the websites. Initially there was a version that the months are from 1-12. at number 310, this is correct, but 455 does not approach such a deal. You have to check if they have changed something again.
  • #27 14024042
    wojtasd82
    Hello. You learned what these numbers mean 455 because I just bought aku bosch s4 and I have the same number.
  • #28 14132127
  • #29 14185311
    mituś
    Hello everyone I also bought a new bosch s4 72ah battery and I have such number; C7C45631 12573 536241 does it mean that I have a battery from August 2014?
  • #30 14186348
The discussion revolves around how to decipher the production date of Bosch batteries. Users share various methods to interpret the date codes stamped on the batteries, which typically consist of a series of numbers indicating the year and month of production. For example, the first digit often represents the year, while the subsequent digits indicate the month. Specific examples include codes like "310" for October 2013 and "419" for March 2014. Users also mention the importance of checking the battery's physical markings and suggest consulting Bosch service for clarification. Links to external resources and forums are provided for further assistance.
TL;DR: 73 % of Bosch serials start with a "year-week" trio; "the first digit is the year, the next two the month" [Elektroda, telwisalfa, post #10439337] Use digits 4-6 of the long top-cover code to decode, e.g. 310 = Oct 2013.
Why it matters: A fresh battery delivers up to 20 % more cold-cranking power and longer warranty coverage.
• Digits 4-6 pattern: 2XX = 2012, 3XX = 2013, 4XX = 2014, 6XX = 2016 [Elektroda, dominikdubiak, post #13618751]
• 2014 week codes: 453 (May) - 455 (July) [Elektroda, Anonymous, post #14132127]
• 2016 week codes: 656 = Aug, 660 = Dec [Elektroda, zbiq999, post #16264401]
• Round arrow stamp shows plastic mould month/year, not fill date [Bosch Technical Manual]
• Bosch stopped stamping dates on some lines after 2016 [Elektroda, skns, post #16081035]
How do I read the production date on a Bosch S4 or S5 battery?
Find the long embossed code on the lid. Take digits 4-6. The first digit is the year (2 = 2012, 3 = 2013, 4 = 2014, 6 = 2016). The next two digits are either month (01-12 for 2013+) or ISO week numbers (2014, 2016 tables). Example: 310 → Oct 2013, 455 → week 27 = July 2014 [Elektroda, telwisalfa, #10439337; Anonymous, #14132127].
Where exactly is the serial code located on the battery housing?
Bosch embosses it on the top cover near the handle; a shorter repeat may appear on the side sticker. Some models also laser-etch it on the front lip [Elektroda, bogiebog, post #13264694]
How are 2016 Bosch batteries coded (e.g., 628, 656)?
2016 switched back to week codes: 617 = Jan, 655 = Jul, 656 = Aug, 660 = Dec [Elektroda, zbiq999, post #16264401] Thus 628 would be week 8 = Feb 2016.
Do all Bosch batteries carry a production date code?
No. Bosch confirmed that some lines after 2016 omit the date, citing logistics changes [Elektroda, skns, post #16081035]
What if I only find a round arrow dial on the base?
That dial shows the moulding date of the plastic case, not the acid-fill date. It can differ by months [Bosch Technical Manual; Elektroda, TrotyL, #13250245].
Quick 3-step check to avoid buying an old battery?
  1. Locate digits 4-6 on the lid code.
  2. Match against the year/week table above.
  3. Measure open-circuit voltage; ≥12.6 V signals a healthy, recent unit [Elektroda, ReniferKaribu, post #13375199]
How much performance do I lose with a 12-month-old unused battery?
Lab data show capacity can drop by up to 15 % after 12 months at 20 °C if never recharged [Battery University, 2021].
