Current meter and force. How is the strength different from ordinary 220V?
prosiak22 79451 10
How is three-phase power different from ordinary 230V household supply, and does it use a separate meter?
Three-phase power is not a different kind of electricity; it is usually a three-phase supply and it is normally measured by one meter, not a separate second meter. In a three-phase installation there are 3 phase wires plus a neutral wire, while ordinary 230V is one phase plus neutral [#10183053][#10183206] A meter marked 230V is probably single-phase, and many meters for three-phase supply are marked 3x230V [#10183183][#10183206] Between two phases you get 400V because the phases are shifted by 120 degrees [#10183206] In older buildings, a separate meter could have been used for outbuildings or farm power, but in homes today one 3-phase meter is usually used [#10183198]
  • #1 10183037
    prosiak22
    Help: 15
    Rate: 131
    My question is, if there is power at home, does it have 2 counters?
    One for regular and the other for strength?
    Can anyone briefly explain to me what is the difference between the power and the usual 220V?
    And if there is a second numerator specifically for strength, why?
  • #2 10183053
    andy127
    Level 30  
    Help: 134
    Rate: 193
    If there is force, one numerator is also used, but a different one. The force is 3 phases (4 or 5 wires), In a 1 phase installation 2 or 3 wires.
    Andrew
  • #3 10183083
    prosiak22
    Help: 15
    Rate: 131
    I have a counter from 1973 with a metal circle in the center.
    And how to check if this power is attached to it?
  • #4 10183109
    andy127
    Level 30  
    Help: 134
    Rate: 193
    Take a photo. You can also search by type for what the meter is.
    Andrew
  • #5 10183169
    prosiak22
    Help: 15
    Rate: 131
    FLESZ makes everything clear that you cannot see
    I will write what is written on it
    AEG
    FORM A41G NR (multiple digits) 1973
    230 V 10 (40) A 50 Hz 600U / kWh
    andy127
    Level 30  
    Help: 134
    Rate: 193
    If it says 230V, it is probably single-phase.
    Andrew
  • #7 10183198
    mikad80
    Hello. Specify the question what you want to do. Nowadays, one 3-phase meter is usually used in homes. In the past, 230V was often pulled to the house and power was pulled to farm buildings, and a separate power meter was installed there.
    Cowboy zagrabie
    Help: 159
    Rate: 502
    And if there is a second numerator specifically for strength then why?
    the force is 3 wires of 230V and the fourth neutral wire. 230V is one 230V + zero. On the 3-phase meter it writes 3x230V. A 3x230V = 400V Because the current from the same generator is phase shifted by 120 degrees
  • #9 10183238
    prosiak22
    Help: 15
    Rate: 131
    mikad80 wrote:
    Hello. Please specify what you want to do.
    I want to know if the counter I have in my cupboard is the only one I have.
    I am renting an apartment and I am a little surprised that nobody told me about the second meter (if any)
    I will immediately remove the plug cover and see if these wires (what is the force) go to the meter
  • #10 10183344
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    Dear author, you either take pictures and describe again exactly what is going on or the end of the topic and the basket. There are no fairies in the forum.
  • #11 10183358
    prosiak22
    Help: 15
    Rate: 131
    look, everyone understood and you did not.
    You do not read carefully the flash is so flashing that I will not be able to take a normal photo.
    I wrote what is on the meter.
    I took the cover off and the meter does not come out with such 3 VERY thick cables only from the wall.
    A few cables to the traffic jams come out of the meter.
    So there has to be a second numerator somewhere.
    Then I guess no one will help me where these CABLES are coming from, I will have to ask the owner of the apartment.
    Thanks for the answers
The discussion revolves around the differences between standard 220V power and a three-phase power system, often referred to as "force." Users clarify that a single meter can measure both types of power, but typically, a three-phase meter is used for three-phase installations, which consist of three wires plus a neutral wire. The standard 220V system uses one live wire and a neutral. One participant inquires about an old AEG meter from 1973, seeking to determine if it is a single-phase or three-phase meter. The conversation highlights the importance of identifying the wiring and the potential existence of a second meter for additional power sources, especially in rental situations.
