Rusty Drinking Water Pipe: Removing Rust & Limescale, Effective Treatment Methods
kamilwy16 46324 6
  • #1 10187917
    kamilwy16
    I have a problem with rusty pipes in my drinking water system. And I have a question how to remove this rust and limescale. What means or something?
  • #2 10187943
    Qbuś
    Help: 380
    Rate: 876
    But you probably got the forums "mixed up"? Unless you want to remove rust and limescale electronically?
    Ps. Ask a plumber to replace the pipes with copper or PVC.
  • #3 10947240
    ^ToM^
    Help: 495
    Rate: 2939
    Basically, a simple answer can be given: it cannot be removed in a simple (read: cheap) way. Usually, pitting corrosion occurs in the pipes as a result of prolonged ion exchange. Thus, even if by some chemical method all this rust was removed, it will form again in a moment, because water contains carriers and oxygen and this causes corrosion. Usually pipes are galvanized inside and until this zinc is ionically "worn" it protects the pipes against corrosion. Depending on the quality and parameters of the water, it takes from several months to several years. As long as you remove the scale with the right amount of a popular descaler solution (provided that the zinc remains on the inner surface of the pipe), rust does not. Sooner or later you will have to foresee the replacement of pipes, at least those for drinking water, because drinking iron water is harmful to the body.
    As for the magnetizers mentioned by the previous speaker, I am skeptical, especially when it comes to removing rust from pipes.
    Regards!
  • #4 10949353
    wowka
    Help: 49
    Rate: 247
    You can rinse the pipes with a descaler and a rust remover, but you have to rinse the muck out of them later.
    The second thing is that after such a procedure, they may be suitable for replacement in a moment because they will be making holes in different places every now and then - where there were the largest patterns from the inside.
    The galvanized pipe on the top looked like new and there were such small holes in it - smaller like a needle punctured - so it burned from the inside after about 15 years on cold drinking water. I also saw pipes over 30 years old quite good, it depends a lot on how the pipe was made.
  • #5 10952112
    ^ToM^
    Help: 495
    Rate: 2939
    However, I think that the parameters of the water that flows in them are of great importance. On the other hand, the quality of the tube itself is of course also important, but it seems to me that it comes only in 2nd place :)
  • #6 10953386
    phanick
    Help: 65
    Rate: 2840
    Buddy - do you have any evidence to support this thesis? As far as I know, drinking rock water does not affect the body in any way. And as for iron-covered water, if it is brown in color or you can see floating iron particles, your installation must be replaced immediately?
    Alternatively, invest in an electric kettle with a strainer.
  • #7 10955115
    ^ToM^
    Help: 495
    Rate: 2939
    Well, maybe I will answer. Of course there is evidence. It is enough to google "the effect of iron water on health" and read.
    In addition, you do not distinguish between fossilized water (i.e. containing mainly magnesium and calcium carbonates) and iron water. Iron water is not the same as stony water. While stony water, i.e. water of high hardness, is not harmful and usually beneficial, it can be even toxic.
    Iron is one that, apart from its normal carbonate content, has an addition of excess iron ions from the water supply.
The discussion centers on the issue of rusty drinking water pipes and methods for removing rust and limescale. It is noted that while descalers and rust removers can be used, they may only provide a temporary solution, as corrosion can quickly reoccur due to the water's chemical properties. The consensus suggests that replacing old pipes, particularly with copper or PVC, is often the most effective long-term solution. Concerns are raised about the health implications of consuming water with high iron content, emphasizing the need for immediate pipe replacement if the water appears brown or contains floating particles. The quality of both the water and the pipes themselves significantly influences the longevity and safety of the drinking water system.
