Heating Resilience of Clear Sanitary Silicone: Comparing Fireplaces, Engine, Boiler Use
jump$ 22701 6
  • #1 10193902
    jump$
    Help: 7
    Rate: 115
    Hello. Mainly, my point is whether sanitary silicone is suitable for heating (smoke) connections of fireplaces and stoves.
    On such sanitary silicone it says that its strength is up to 100-150'C~,
    engine 350'C~, boiler 950'C~
    Isn't it so that silicones differ only in color, generally in Wikipedia they write that silicone is not flammable?
    I have a lot of sanitary silicone so I don't want to buy red silicone :D
  • #2 10194648
    wariato
    Help: 1213
    Rate: 841
    Silicone is flammable - recently, out of curiosity, I threw a tube with dried silicone into the oven (about 20% left) it was fire and black smoke as if the tire was on fire. It was plain white sanitary silicone.
    What exactly do you want to silicone? If close to the fire source, it seems to me that a more engine or other heat-resistant one would be suitable for such applications.
    Moderated By _PREDATOR_:
  • #3 10194666
  • #4 10194761
    popielarski.555
    Of course, it is not suitable, such ordinary sanitary silicone will behave more or less like rubber. So, however, my friend will have to buy a heat resistant one.
  • #5 10196062
    _PREDATOR_
    Help: 1864
    Rate: 2315
    Nice example!
    ELMAX
    Małe Przedmieście 20/4, Olesno, 46-300 | Tel.: 535 XXX XXX (Show) | Company Website: http://ftp.interka.pl/~elmax/about.php
  • #6 10207728
    krakarak
    Help: 681
    Rate: 1851
    _PREDATOR_ wrote:
    Nice example!
    It's in the name of science :D .
    Buy more expensive, but designed to work at high temperatures. Sanitary will melt and run or catch fire.
  • #7 10208220
    jump$
    Help: 7
    Rate: 115
    APPROX. I already bought a 950'C
Sanitary silicone is not suitable for high-temperature applications such as sealing connections in fireplaces, stoves, or boilers. The thermal resistance of typical sanitary silicone is limited to 100-150°C, while flue temperatures can reach up to 1000°C and regularly hover around 500°C. Users have reported that sanitary silicone can catch fire or melt when exposed to high heat. It is recommended to use heat-resistant silicone specifically designed for high-temperature applications, such as those rated for 950°C.
