Accelerate Silicone Hardening for PVC Pipe Sink Seal: Using Warm Air from Farelka
szymon julian 17238 5
  • #1 16452912
    szymon julian
    I would like to seal the PVC pipe at the sink and I would like to do it with the help of universal silicone. I know that the silicone dries slowly, and I would like to use the sink quickly. If I warm it with warm air from "farelka", will it harden me faster without losing its properties?
  • #2 16452986
    marcin18dm
    Rate: 28
    hei
    I do not recommend it, because it can break you
  • #3 16453047
    mariuszkam
    Help: 8
    Rate: 71
    And why do you want to seal the pipe ...? you do not have original seals ...? You can use Teflon
  • #4 16454236
    mietek440
    Level 19  
    Help: 15
    Rate: 200
    In the pipe gasket there is a gasket, as it is worn out, replace it.
  • #5 16459958
  • #6 16460457
    mietek440
    Level 19  
    Help: 15
    Rate: 200
    I read, and you do something with hydraulics? Because if you should know that no silicon is needed and properly direct the questioner. szymon julian write in which place you have a leak, it is best to insert a photo.
