Sanitary Silicone Electrical Conductivity: Fresh Mass & 600V Insulation Inquiry
kotuniunia 42577 1
  • #1 9747846
    kotuniunia
    Help: 74
    Rate: 305
    Hello . After searching the forum, I did not find anything, perhaps the effect of my indolence. In connection with this question as above. I especially care about the answer whether it is electrically conductive (about 600V) in the non-concentrated state (fresh mass). Maybe practically someone was checking. I know the paw gauge, the M? range and a sanitary silicone cap, and everything is clear. But there is one problem. I have no way to check the weight of the mass, and I have to insulate it, because I have nothing under my paw!
    jarecki 86
    Electrician specialist
    Help: 127
    Rate: 294
    Silicone is not a conductor, it's proven. But not suitable for insulating electrical connections, also proven. It is a corrosive substance that will corrode metals. On the other hand, the roofing sealant does not have these disadvantages.
    Yes.
    I close the topic.
