Will Gasoline, Oil, Denatured Alcohol Affect Ordinary Sanitary Silicone or Sealants?
nokash 54044 12
Can ordinary sanitary silicone seal a stainless-steel part that will be exposed to gasoline, oil, and denatured alcohol without dissolving or leaking?
Fully cured silicone is generally not dissolved by gasoline, oil, or even acetone, but sanitary silicone is still a poor choice for fuel/oil service because these liquids can break its adhesion to the surfaces and wash it away [#9831527][#9836889][#9838422] The thread recommends using automotive/motor-tech silicone or another fuel-resistant sealant instead of sanitary silicone [#9826786][#9831604] If you use silicone, it must be completely cured and the surfaces must be clean and dry before any contact with fuel, or the joint can fail [#9831527][#9836889]
  • #1 9826737
    nokash
    Hi. I have a question. Will gasoline, oil, denatured alcohol dissolve ordinary sanitary silicone?
    Alternatively, is there any silicone or silicone-like sealant that the above liquids will not dissolve? Please give me some suggestions.
  • #2 9826786
    glosny83
    Help: 91
    Rate: 487
    Sanitary is not suitable buy a car, what do you want to seal?
  • #3 9826787
  • #4 9826822
    nokash
    Thanks for the quick replies. The point is, I have a handmade stainless steel item and I wanted to seal it. Has contact with the fluids I have replaced. I want to seal it so that it does not leak and the sealant does not dissolve. It does not have to be colorless.
  • #5 9826867
  • #6 9828675
    carot
    Help: 41
    Rate: 643
    The car silicone Technicoll petrol, nor any of the substances mentioned above, dissolves. Of course, it must be solidified, otherwise it can be washed off with water.
  • #7 9831527
    saskia
    Help: 174
    Rate: 1087
    Silicones, as long as they have a little solvent in them, can be washed off with many liquids, but if the ribbon is 100%, even acetone will not dissolve it.
  • #8 9831604
    robokop
    Help: 1763
    Rate: 6376
    Motronic wrote:
    . Use the silicone used in the moto technique, but I haven't seen the colorless ones, that's what you mean.
    They are colorless.
  • #9 9836699
    pseudodiablo
    Sanitary is the most suitable in my opinion
  • #10 9836889
    telecaster1951
    Help: 829
    Rate: 818
    Gasoline should not dissolve the silicone. Alcohol too.
    All stories of silicone dissolving by various liquids are mainly due to the misuse of silicone. If someone seals the fuel tank of a scooter without cleaning the surface and the fuel is poured in when it is wet, the joint lets go.
  • Gasoline caused silicone sealant to swell and clog carburetor
    #11 9836917
  • Gasoline causes sanitary silicone to detach and crumble
    #12 9838243
    robokop
    Help: 1763
    Rate: 6376
    Jerzykowski wrote:
    Once a friend of mine sealed a carburetor in a Fiat 126p with silicone.
    The term "idiot" for this acquaintance is too mild.
    The silicone has grown into small balls under the influence of gasoline.
    Not under the influence of gasoline, but too much stuffing it, and in addition, wherever it falls - the squeezed out litter fell wherever they wanted.
    In general - sanitary silicones can be used in environments where there are neither oils nor substances similar to them - it is, among others, o that the silicone gasket is detached from the surface and crumbles.
  • #13 9838422
    telecaster1951
    Help: 829
    Rate: 818
    Exactly. Gasoline, crude oil, engine or cooking oil should not dissolve the silicone, but it should detach it from the surfaces to be joined. Especially when dealing with constantly flowing fluid. It will then be washed away.
The discussion centers on the compatibility of ordinary sanitary silicone and sealants with gasoline, oil, and denatured alcohol. Users share experiences indicating that gasoline can dissolve silicone, while the effects of oil and alcohol are less clear. Recommendations include using specialized silicone products, such as those designed for automotive applications, which are more resistant to these substances. It is emphasized that proper curing of silicone is crucial to prevent detachment from surfaces, especially in environments exposed to fluids. Some users suggest alternatives like acrylic or two-component adhesives for better resistance.
