Sealing a 0.5mm Hole in Leaking Cast Iron Radiator: Effective Solutions for Moist Conditions
marty1 67172 10
How can I seal a 0.5 mm leak in a cast iron radiator when the area stays constantly moist?
For a constantly moist 0.5 mm leak, use an epoxy resin that is meant for damp surfaces, such as epoxy resin 7706; one reply also mentions N28 glue, but 7706 is the practical option here [#10282066] If the hole is accessible, another emergency method is to drill it, tap it, and screw in a screw; if you do not have a tap, a wooden dowel can be pushed into the hole [#10580611] These are only temporary repairs, not the proper fix [#10576527] The proper repair is to drain the radiator/system and fix it correctly, for example by replacing a gasket or repairing/replacing the damaged radiator section [#10576527]
  • #1 10281922
    marty1
    Cast iron radiator - use to seal a leaking hole of 0.5 mm. There is moisture all the time, so it's harder.
  • #2 10281948
    rafik108
    Help: 7
    Rate: 100
    You will have a hard time if there is moisture there. If you would try to dry this place somehow, you will find a lot of glue with which you can patch it up
  • #3 10282066
    bobo
    Help: 69
    Rate: 686
    EPOXY RESIN 7706 and N28 glue. The first one is about PLN 25 per package (2x12ml), the second one is about PLN 700 per 100ml. Adhesive 7706 can be used on damp surfaces.
    Greetings
    rafik108 wrote:
    ... sticks a lot with which ...
    glue is plural to glue
  • #4 10576527
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    If sealing helps, then good. Nevertheless, this is only an emergency repair. The proper repair can be done after draining the water from the installation (at least from this radiator). Is it leaking from the connection between individual ribs (this is the most common) or from the rib itself (such failures occur VERY RARE)? In the first case (leakage between the joints of the ribs), this leaky joint must be unscrewed (note: a special wrench is required and may require enormous force, especially after several decades of operation), replace the gasket in the lower and upper intercostal joints (after cleaning both ribs), turn the with radiator nipples (if the nipples were heavily corroded, they must be replaced). If a specific radiator rib is damaged, you have to unscrew it from the radiator and replace it with an undamaged one, and if the radiator is large (larger than necessary) - simply remove it from the set. Sometimes the radiators are oversized - especially when the building has been thermally insulated and the windows are replaced with tight ones.
  • #5 10580611
  • #6 11123406
    Shizo
    Rate: 77
    For me, a similar problem, but specific because the radiator started to leak after painting, previously it was only yellowed, but there was no rust or leakage. The place is a joint between the last rib and the pipe, so I don't think about drilling or gluing. It's as if the paint has dissolved the bonding ...
    Photos with a cell of a slightly poor quality because it's dark there ...
    Sealing a 0.5mm Hole in Leaking Cast Iron Radiator: Effective Solutions for Moist Conditions Sealing a 0.5mm Hole in Leaking Cast Iron Radiator: Effective Solutions for Moist Conditions
    Do you think something can be done about it?
  • #7 11124806
    MarudaP
    Help: 24
    Rate: 238
    If I can see it correctly, it's leaking on the gasket. I don't think you can do without removing the radiator. A ring key probably 32 mm, heat it well with a burner. After unscrewing, clean it and give a new gasket.
  • #8 11125404
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    The key is larger than 32 mm. If it is an old shell, it is even 48 mm, in newer ones a bit smaller (probably 42 mm), but you can always use a "Swede" (a large one). Of course, the water must be drained from this heater. Unscrew the plug, thoroughly clean the edge of the rib to which the plug is screwed in (clean the plug too, or give a new one), give a new gasket, which is also good to lubricate the so-called the liquid gasket (special sealing silicone, red) and screw it STRONGLY. You do not need to use tow for the thread (because it is cylindrical and they can slip), but you can - saturated with good thread paste or linseed varnish. The heater does not need to be removed for this. If the cap cannot be unscrewed, take a striking ring spanner (with such an anvil) and tapping the spanner unscrew it. Note the direction of the thread. Blind plugs usually have a left thread, while plugs to which the supply valve and the return pipe are screwed - right (if the radiator is cross-connected, the plug with the return screw connection is left).
  • #9 11125517
    Shizo
    Rate: 77
    What is this gasket that made the alkyd paint dissolve from? Where can you get such a gasket? Now it is after the heating season, I live in a skyscraper, do you think that the water is only in the radiators or in the entire system? I'm afraid of flooding myself and my neighbors!
  • #10 11125821
    karter
    Level 19  
    Help: 33
    Rate: 53
    Don't play repairs or you'll be making trouble for yourself. The water should be drained or frozen (special device). I've seen two supposedly experienced plumbers replace the plugs with one with a vent. They had a burner, they had a key (almost a meter long), a hammer of course. The heater practically almost jumped when they were processing it (one was holding a heater that was normally attached to the wall). Result - they replaced the plugs in 4 heaters, on the second day two heaters started to leak on connectors (the overloads were too high). The fact is that the radiators were 35 years old. Why do you want to do this? If you live in a block of flats, let the cooperative or the manager (housing association) do it. They charge the rent to the renovation fund. You cannot voluntarily flush the system without the consent of the building manager.
  • #11 11125850
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    First you need to check if the water is drained from the system. In principle, the water should not be drained (it is better for the installation when it is constantly full), but some cooperatives do discharge so that someone does not flood during some repair. The gasket must be purchased in the store. As for unscrewing the plugs, last summer I removed the plugs from the radiators that were 48 years old (and replaced them with plugs with an opening to give air vents) using a 45 cm long "Swede". I had a problem with only one stopper and I had to use the wrench to beat. After replacing this plug, it is also worth tightening the screw connections, because overloads can actually loosen them (unseal).
The discussion centers on sealing a 0.5mm hole in a leaking cast iron radiator, particularly under moist conditions. Users suggest various methods for temporary and permanent repairs. Epoxy resin (specifically EPOXY RESIN 7706) is recommended for damp surfaces, while others discuss the importance of draining the radiator for proper repairs. Techniques include drilling and threading the hole, using wooden dowels, or replacing gaskets at the joints. Concerns about the integrity of old radiators and the potential for flooding in multi-unit buildings are also raised, emphasizing the need for professional assistance in some cases.
