I have a leaking cast iron elbow from the cold water inlet in a place that is difficult to reach and practically impossible to replace. Renovation, including the replacement of pipes, is planned only in spring, so advise what to seal it with. The buttonhole is in the center of the elbow with a diameter, so to speak expertly, one drop every two minutes. The paxylin was useless, twice (if it wasn't, the surfaces were clean and dry). Do you have any other ways?
ajpier
ajpier
Level 37
Help: 363
Rate: 480
