1999 VW Passat B5 – water under passenger footwell, where is the leak?
BOSSMAN26 195495 54
Why does water collect under the passenger’s feet in a VW Passat B5, and where should I check for leaks?
The most likely leak is the pollen filter housing gasket or clogged plenum drains under the battery/servo; check the door vapor barrier/metal cover seals too [#10340981][#10537530][#13417900] Pull off the wipers/cowl and inspect the pollen-filter housing seal, then clear the drains with compressed air or a wire until water runs out underneath [#10340981][#11161527] If water is coming in at the sill/threshold, remove the door trim and check the metal cover seal, round door plugs, and the bottom door drains; water can overflow from the door into the cabin if these seals/drains fail [#13417900][#11570617][#10531939]
  • #1 10340488
    BOSSMAN26
    Rate: 42
    I am the owner of the aforementioned model from 1999, I have been observing for some time that there is water on the floor under the passenger's feet next to the driver.
    Once, in a heavy rain, I noticed water running in over the plastics on the door sill, but it was only a few drops.
    Could this be the reason for the formation of a lake in the car?
    (Pressing the palm of the hand on the carpet shows water).
    I am asking for tips and advice on how to remove and prevent this vulnerability?
    I once read that seals may be to blame - how to check it?
    Where else have I heard that the conduit draining the condensed water from the air conditioning could have been blown (although the amount of water in the cabin is too much in my opinion)?
    The last idea that comes to mind is a leaky chassis and possible leaks from the outside to the inside of the vehicle, but why is there only water here?
    The car did not take part in any collisions, it was operated in a fairly calm way, no adventures with the chassis.
    I am asking for help, thanks in advance for the information. GREETINGS.
  • #2 10340583
    Dominik04
    Rate: 16
    at the beginning, I advise you to check the drainage of water from the air conditioning. because you write that there is a lot of this water, but you do not know when it started to pour there.
  • #3 10340587
    Ture11
    Help: 573
    Rate: 1127
    I will probably not help much, but the reason may be a clogged water drainage gutter (I do not know if it is in b5), or a rusty metal under the pit gutter. As for the removal of water, let me tell you how I did it, but please don't do it at home. Specifically, I took the Zelmer Wodnik DUO vacuum cleaner with a water filter and I was vacuuming the floor for about 15 minutes ... Until it started to pour out through the HEPA filter ;-) . Of course, it is very dangerous, because even though I have dismantled this vacuum cleaner once and the 220v is well separated from the centrifugal blades, you always have to take into account the presence of this voltage, which will gladly kill you. For others, I will also add that my brother was the initiator, who flooded the water filter with water and turned on the vacuum cleaner, which made the whole living room damp. The HEPA filter didn't care. For me, the water stood in three places (Renault Megane 1.6), and we managed to pull out about 7 liters of water!
  • #4 10340602
    Dominik04
    Rate: 16
    if you unfasten the plastic on the threshold, you will lift the carpet enough to remove the water. you will not vacuum everything up. there will be not enough of it. :) :) :)
  • #5 10340616
    pawel-jwe
    Level 30  
    Help: 123
    Rate: 273
    If you have a sunroof, check if it is leaking.
    The second option is when you open the passenger door, there should be (factory) holes on the pillar where the hinges are, and originally there should be special plugs (best compare with the driver's door), if one is missing, it is very likely that it is the fault of "flooding" (I had yes in another car).
    The third option is to check if the bottom door openings are not clogged. Excess water flows (e.g. on the glass) to the center of the door and this water should flow further through these openings, if they are clogged, the water will collect and overflow inside (I also encountered it in one car).
    When it comes to drying it, unfortunately you will most likely have to take a few plastics apart and fold back the entire carpet from under the "passenger's feet", there will probably be 5-10 cm of hard sponge there. You have to take a wallpaper knife and cut out the entire lobe that has water in it and dry it properly at home. Since it's a hard sponge, unfortunately it will take a while. I had it this summer and it was dry for 2 days in the sun
  • #6 10340631
    BOSSMAN26
    Rate: 42
    thank you for the quick answer - I only have a few questions how to check the drainage of water from the air-conditioning and how to fix it if a possible fault is detected?
    I do not have a roof damper, I will check the condition of the plugs and water drainage holes tomorrow morning.
    Thank you greetings
  • #7 10340718
    Dominik04
    Rate: 16
    on the passenger side in the front legs on the left side in the corner you can see this wire. black, rubber. if it is leaky it must be replaced
  • #8 10340981
    Slawek12345677
    Rate: 22
    most often it is a damaged gasket of the pollen filter housing. The water is poured down the glass and then to the sewage gutter with a hole for the pollen filter housing. Regards
  • #9 10351928
    kkc18
    Gentlemen, in my belt, it flows through the chrome strip, which does not fit exactly to the glass, and it is together with such a seal and too much water flows into the door. And therefore I have a question, namely how to disassemble this strip. She hangs on pegs or something. Because I had lacquered the door, so there is a high probability that the painter put something together wrongly.
  • #10 10370831
    BOSSMAN26
    Rate: 42
    I was looking for this cable from the air conditioning - I did not find it :( I checked the plastics on the door completely, the filter - hard to define, but it seems to be dry and tight.
    I noticed that with rainfall it continues, and rather not a few drops, and sometimes even a small stream flows into the cabin through the groove on the threshold (a combination of two plastic elements, some masking the threshold and some masking the interior of the vehicle, the right wheel arch from the inside). it's probably a sensation - unfortunately ...
    What could be the cause of this water infiltration through this stomata / gutter? I would like to add that, on the other hand, nothing similar is happening and, as we all know, the driver's door is more exploited. Please give me suggestions / good ideas to fix / improve this vulnerability. GREETINGS
  • #11 10374081
    elwiz
    Rate: 14
    I have a similar problem in the B3 pass. My 18 yr old has the floor wet like a baby diaper. For now, I am removing it by sticking leaflets from hypermarkets under rubber mats. Very quick measure and helps for a very short time. I can only suspect a problem with the channels draining water from the pit, but to be honest I don't know how to check them. When I look in it, I can only see a black hole - no dirt, but you know, I don't reach the end with my eyesight. This afternoon I put a few sheets of paper on the frets and on top of the front mats - if it is dripping somewhere I should pick up traces of moisture but I have to wait for something to collect. Have you tried to somehow irrigate the cars to detect leaks?
  • #12 10526582
    bimber98
    Rate: 10
    pollen filter housing for 100
    pollen filter housing for 100, as my colleague says
  • #13 10531939
    Jan Nojszewski
    Help: 20
    Rate: 102
    If water appears on the door seal, it is very likely that the round plug in the door leaf (for loosening the glass down) is leaking or missing. Water flows under the upholstery. Remove the upholstery and watch.
  • #14 10537530
    sadek1979
    Cars specialist
    Help: 237
    Rate: 1419
    my friend, the reason is, as colleagues write, pollen filter housing, blocked drains in the gutter (there are 2, one under the battery base, the other under the servo), poorly replaced glass, computer housing or, as I have, an electrician and not fully sealed bulkhead wall More information and tips you will find http://forum.vw-passat.pl/threads/40108-Woda-w-car- szodzie including photos and opinions of other Passat users
  • #15 10680725
    BOSSMAN26
    Rate: 42
    I noticed another disturbing symptom, water on the rear wiper behind the passenger ... in this case I think the door seal is leaky / damaged .. I saw it does not look deformed or incomplete? all these faults appeared this winter, before the frosts, and the rest during these record frosts .. Where to look for the causes and how to deal with them?
  • #16 10682426
    sadek1979
    Cars specialist
    Help: 237
    Rate: 1419
    buddy so much advice and you are still looking ??? When it comes to the rear, check if you have plugs on the bottom, in addition, as a station wagon, check at the rails.
  • #17 10683809
    mariuszek1978
    Help: 5
    Rate: 48
    I once had such a case in a colleague's passat - the plastic computer casing turned out to be the fault - or rather its sealing on the bulkhead wall right next to the left wheel arch. Window glue did the trick, besides, drains under the battery often clog up and an "aquarium" forms ...
  • #18 11161527
    elgrego
    My father had such a problem, we opened the hood, we look at the water in the battery compartment. we unscrewed the battery, the drainage channel was clogged, we pushed it through, the water flew and the problem is gone. :D
    Greetings
  • #19 11570617
    dario 71
    I had this problem, the reason was the seals in the metal side panels of the door. If the water is running on the thresholds, remove the sides of the door with upholstery, loosen the screws of the metal sides, seal with e.g. silicone, tighten and put the upholstery on. Another reason is a clogged drain under the battery or incorrectly applied sealing rubber the tailgate lift cable.
  • #20 11574331
    pawel-jwe
    Level 30  
    Help: 123
    Rate: 273
    Maybe I will add my own case :)
    I had water under the driver's feet, I struggled with it for a long time and wondered what was going on?!?!
    The reason turned out to be "unusual" (but it happened to others and that's the only reason I checked it), namely the unsealed windshield was the cause. The most reliable repair is, of course, re-gluing the glass by a specialist, but sometimes it is enough to coat the bottom edge of the glass with sanitary silicone (at the junction of the glass with the frame, so you have to disassemble the entire glass from the outside). As for the diagnosis of this case, you can often recognize it by the "wavy" sticker with the VIN number on the pit, the second method is pouring copious amounts of water with suds and blowing with a compressor (both inside and outside - if foam begins to appear, then we already know what's going on).
  • #21 11578976
    czaczacza1
    Buddy, check if your windshield is well glued I have a Mercedes ml 2000 year I also did not know why after washing or after driving after rain I have a lot of water on the passenger's wiper, it turned out that the windshield let water through and the windshield was original from new, it just got unsealed
  • #22 11579200
    Radeon 24
    Help: 66
    Rate: 192
    Hello!
    After all, he writes that water appears on the threshold. As someone wrote above, it is pouring through the metal cover of the door. Pull off the upholstery, unscrew the cover, brush the wounds with silicone and tighten.
    Regards!
  • #23 11591286
    czaczacza1
    Well, I didn't really understand. It could be something with a door seal, or maybe it could somehow run down the glass in the middle of the door and therefore run down the threshold.
  • #24 12007758
    dan0031
    In my streak, the windows stopped working overnight. After connecting to VAG, errors popped up when I wanted to move the glass - communication error or something. When I deleted it, they didn't work anyway, but the error popped up when I wanted to move the glass. I read a bit about the cables in the threshold - shock! The cables shorted together, some cables survived and some fused together. I cut it out and started to connect the cables one by one by color, pair, twisted pair. I connected them by extending them with a new cable and fastening them with weight ankles.
    When the pairs of cables ran out, I had a few brown and white-red cables left. I found a diagram and tied the cables together according to the colors to be put together on a few input wagons, i.e. brown all together and white and red together. When connecting, the connector on the red-blue cable fell apart, it was green in the center. So I got them together too.
    Everything seemed to be connected and as it should be, then this is a test. And what? The panes don't work anymore. But I checked if they respond to the key and it works. But the driver's lock itself reacts strangely. To open the door, I have to turn the key clockwise twice quickly. And the windows open when you close and close when you open the door.
    VAG showed such errors:
    1328 Comfort function data bus
    no fixture / not related to hardware
    1334 Right Rear Door Control Module -J389
    CAN bus no signal
    1333 Left Rear Door Control Module -J388
    CAN bus no signal
    1332 Passenger door control module-J387
    CAN bus no signal
    1331 Driver's door control module-J386
    CAN bus no signal
    Does this apply to the blue / red wire? Who can tell me what's wrong?
  • #25 12009011
  • #26 12009109
    dan0031
    Can-a or blue-red? I checked and the voltage in the ankles in relation to the mass is 12V. I will try to fasten them again or connect them with something else ..
  • #27 12009129
  • #28 12009266
    dan0031
    Not all cables in the threshold burned, I do not know if I had to make some extra money for these cables. But I'll check if they're okay. The Passat is from the 96 year, 1.8T.
  • #29 12010694
  • #30 12014207
    cebula1972
    Rate: 15
    Ah, those leaking passats
✨ The discussion addresses water accumulation on the floor under the passenger's feet in a 1999 VW Passat B5. Common causes include clogged drainage channels under the battery and servo, damaged or missing door seals and plugs, especially on the door leaf and metal door covers, and leaks from the pollen filter housing gasket. Water can also enter through unsealed windshield edges, faulty sunroof seals, or blocked door drainage holes. Diagnosing involves checking the air conditioning evaporator drain tube, inspecting door seals and plugs, removing door upholstery to examine metal panels, and verifying the condition of the pollen filter housing. Solutions include cleaning drainage channels with compressed air, resealing door metal covers with silicone, replacing damaged gaskets, and in some cases re-gluing or sealing the windshield. Water removal requires lifting carpets and cutting out soaked insulating sponges for thorough drying. Electrical wiring in door thresholds may also be affected by water ingress. Persistent leaks despite these checks may indicate chassis-related issues or faulty bulkhead seals. The problem is often localized to the passenger side threshold area, with water sometimes entering through the groove between plastic elements near the wheel arch. Regular inspection and maintenance of seals, drainage paths, and filter housings are essential to prevent water ingress and subsequent floor flooding.
TL;DR: Up to 80 % of Passat B5 cabin-flood cases originate from clogged plenum drains [VW TSB 01-09], and as forum expert Dominik04 warns, "check the drainage of water from the air-conditioning" [Elektroda, Dominik04, post #10340583] Quickly clearing both drains and resealing door carrier plates stop most leaks.
Why it matters: Standing water corrodes wiring, shorts the comfort module and can total €700 in electronic damage.
• Plenum drain diameter: approx. 20 mm; clog risk rises after 50 000 km [VW SSP 263]. • Door carrier plate has 10 × T45 bolts; OEM butyl seal service life ≈ 12 years [PassatWorld Survey 2021]. • New pollen-filter housing gasket: €14–€18, install time 15 min [ETKA 2024]. • Windscreen re-glue at glass shop: €90–€140 inc. labor (Poland, 2023 price list). • Comfort module sits only 22 mm above floor; <5 mm water can flood it [VW SSP 263].
How can I quickly check if the plenum drains are blocked?
Remove the battery cover, shine a torch into the plenum. If water pools after you pour 1 L around the pollen filter and nothing exits under the car within 10 s, the drains are blocked [Elektroda, elgrego, post #11161527]
Where is the A/C evaporator drain hose and how do I clear it?
Look behind the front passenger console, left corner. A black rubber elbow passes through the bulkhead [Elektroda, Dominik04, post #10340718] Gently squeeze the hose from under the car, then insert a plastic cable tie from the cabin side to dislodge slime. Avoid metal tools that may pierce the hose.
How do I reseal the leaking door carrier plate?
  1. Remove door trim and speaker. 2. Undo the ten T45 bolts holding the metal plate. 3. Peel off old butyl, apply 8 mm butyl cord or OEM seal, refit plate and torque bolts to 9 Nm. Leak-free in 30 min [Elektroda, Radeon 24, post #11579200]
What’s the test for a leaking windscreen?
Spray soapy water along the lower windscreen seal, then blast compressed air from inside the cabin. Bubbles pinpoint gaps [Elektroda, pawel-jwe, post #11574331] If the VIN sticker looks wavy or stained, the bond already leaks.
Can water damage the car’s electronics?
Yes. The comfort-control module (CCM) sits under the passenger seat and is only 22 mm above the floor; once submerged, remote locking and windows fail [VW SSP 263]. One forum user lost all four door CAN signals after wiring soaked and shorted [Elektroda, dan0031, post #12007758]
What is the safest way to dry the soaked carpet and foam?
Lift sill plastics, fold carpet back, cut the waterlogged hard sponge, and dry it 48 h in the sun or near a dehumidifier [Elektroda, pawel-jwe, post #10340616] Vacuuming alone leaves moisture that breeds mildew.
Why do leaks often appear only on the passenger side?
The pollen-filter housing and A/C drain both sit on the passenger side, so any failure routes water straight to that footwell [Elektroda, BOSSMAN26, post #10370831]
Could a wet rear floor be linked to the same problem?
Yes. Water entering through rear door carrier-plate seals runs along the sill and pools behind the front seats [Elektroda, czechmar, post #13900427]
How much does professional leak repair cost?
Typical workshop prices (Poland, 2024): plenum clean €30; reseal one door €40; pollen-filter housing €25 parts+labor; windscreen re-glue €120. Full CCM replacement after water damage can exceed €700 (Autonaprawa 2023 price list).
Edge case: What if water appears after long highway drives with A/C on but no rain?
A collapsed evaporator drain tube can allow condensate to spill only while the system produces high flow. Carpet feels wet near the centre tunnel, underbody remains dry [Elektroda, passat B5 by Badi, post #16624475]
How can I prevent future leaks?
  1. Clear plenum drains every oil change. 2. Replace pollen-filter seal every 4 years. 3. Inspect door carrier-plate butyl annually. 4. Spray silicone on windscreen seal after winter to limit cracking. Experts say, "simple maintenance keeps the carpets dry" [Elektroda, sadek1979, post #10537530]
