Understanding Power Supply Data: Guide to Selecting Correct Replacement & Cost Estimates
kotwbutachx 32074 18
How do I choose the correct replacement power supply for my mixer when the original one is broken, and what should it cost?
You need a 12V AC power supply/transformer rated at 0.5A (500mA), which is about 6W; the original unit is a 230V input adapter with 12V AC output [#10364516][#10364535][#10364857] Do not buy a DC supply marked DC or "=", because it will not work; look for one marked AC or "~" [#10378412] If the mixer is healthy, a supply with a higher current rating is fine because the mixer will draw only what it needs [#10374717] The forum estimate for such a supply was about PLN 10 maximum, depending on where you buy it [#10364741]
  • #1 10364503
    kotwbutachx
    Hello! I'm green with this topic and my power supply has broken. I am looking for a new one with the same parameters as in the picture. I am asking for guidance on how to choose it correctly and how much can it cost?
    Regards!
    LuckyDj
    Help: 186
    Rate: 192
    AC power supply, twelve volts, half ampere.
    Now watch out - the firecracker is coming!
    PRI - Primary, primary winding (voltage) of the transformer (voltage that enters the power supply)
    SEC - Secondary, secondary winding (voltage) (voltage that comes out of the power supply)
    AC - Alternating Current, because if it were:
    DC - Direct Current
    :) Regards.
  • #3 10364535
    goldi74
    Help: 1367
    Rate: 1538
    Power: 6W
    Input voltage: 230V
    Output voltage: AC 12V with a load capacity of 0.5A
  • #4 10364537
    kotwbutachx
    Now watch out - firecracker is coming!
    DC - Direct Current
    :) Regards.
    well explained now!
    Thank you very much!
  • #5 10364597
    LuckyDj
    Help: 186
    Rate: 192
    And yes, OT, does a colleague sometimes need this power supply for some audio mixer?
  • #6 10364614
    kotwbutachx
    exactly ;) reloop acces 3. my old power supply is dead, so you need to buy a new one.
    How did you know it? ^^
  • #7 10364693
    LuckyDj
    Help: 186
    Rate: 192
    Because AC power supplies are rarely used, and you have the note Dj, so I immediately thought that ...
    In DJ mixers with external power supply, AC power supplies are used, because only 2 wires come from the power supply to the mixer, even though the mixer needs double power (symmetrical), in such a case, a voltage doubler with stabilization etc. is made in the mixer, etc., long to tell ;)
    I used to play. I also made and repaired a lot of mixers, now I only maintain (after some cultural centers, etc.)
  • #8 10364722
    kotwbutachx
    Do you know how much such a power supply can cost? What if I connected a DC power supply? The mixer wouldn't come on? would something happen?
    LuckyDj
    Help: 186
    Rate: 192
    Nothing bad will happen, but it will definitely not work.
    Maybe the level indicator will fire, but nothing else.
    The cost of such a power supply is about PLN 10 MAX, of course, it depends where, because if you have one EL store for the whole city, a halogen bulb can cost 2 dozen.
  • #10 10364758
    kotwbutachx
    I see. You helped me a lot. One more question:
    "Good morning. AC adapter, please (it is otherwise called -pulse?) 12v / 0.5A?"
    these 50Hz and 6W does not matter?
    0.5A is 500mA? :D
    there was supposed to be one question xD
    kybernetes
    Help: 426
    Rate: 1486
    Not impulse, your power supply is basically a 12 volt transformer in a box. Just like in halogen desk lamps, only smaller.
    50 Hz is the mains voltage frequency, Poland, Europe and most of the world use this value (Americans, for example, use a different one, 60 Hz).
    6 W is the power that results from the parameters: 12 V times 0.5 A.
    0.5A is 500mA.
  • #12 10374484
    kotwbutachx
    Hello! Sorry to refresh, but I don't want to create a new tem. on a similar topic. Whereas:
    I am looking for a power supply with the same parameters. Today I ran around the city and nothing! the visitor had this "interior" and asked me to make myself ...
    I'm looking for Allegro. can you help me?
    I found this: will it be suitable?
    http://allegro.pl/zasilacz-stabilizowany-12v-500ma-f-v-led-i2025299326.html
    ? if necessary, please give me some suggestions
    http://allegro.pl/listing.php/search?string=12v+500mA&category=76371
    PS what would happen if I gave more amps? yes to 1.2?
  • #13 10374717
    LuckyDj
    Help: 186
    Rate: 192
    If the mixer is not damaged, then nothing. The mixer will take as much "A" as it needs.
    It seems to me that your mixer is OK, and the power supply burned down because it was bad and connected to the mains for a long time.
    About March last year, I bought three sets of AKG WMS450 wireless microphones, all sets had an impulse power supply, 16 hours a day were under voltage, after 0.5 years 2 power supplies from 3 were lost.
    Only buy an AC power adapter.
  • #14 10378097
    kotwbutachx
    I got a power supply Universal AC / DC Lexton Lx g54 power supply.
    I don't know, I'm afraid to connect, will it be good?
    kybernetes
    Help: 426
    Rate: 1486
    This one is not suitable. This is a DC power supply (labeled DC or "=", eg "output: 12V ="). You need an AC adapter (marked as AC or "~", eg "output: 12V ~").
  • #16 10378590
    kotwbutachx
    it is even impossible for me to get such a power supply ...; /
    it's also hard to do on the net with this ...; /
    kybernetes
    Help: 426
    Rate: 1486
    On Allegro you will find companies selling such power supplies.
  • #18 10382351
    kotwbutachx
    in that case, I would ask you for at least one of them. I will be eternally grateful because I cannot find them.
  • #19 10382458
    _PREDATOR_
    Help: 1864
    Rate: 2312
    Subject exhausted, the answer was in the subject / the rest of the communicators!
    ELMAX
    Małe Przedmieście 20/4, Olesno, 46-300 | Tel.: 535 XXX XXX (Show) | Company Website: http://ftp.interka.pl/~elmax/about.php
✨ The discussion revolves around selecting a replacement AC power supply for a broken unit, specifically one that outputs 12V at 0.5A. Participants clarify the specifications, including the importance of using an AC power supply for devices like audio mixers, and the implications of using a DC supply instead. Cost estimates for suitable power supplies are provided, with suggestions to check local stores and online platforms like Allegro. The conversation also touches on the compatibility of power supplies with different amperage ratings, confirming that devices will only draw the current they need.
