  • A 0-30V, 0-10A laboratory power supply uses a Velleman K7200 new printed circuit board control card.
  • The design includes Sprint Layout PCB drawings, Gerber files, and a single-layer PCB sized 91.6X72.2mm.
  • It offers continuously adjustable output voltage from 0 to 30V and current limiting from 0 to 10A.
  • The supply works fine, with 8A continuous output, 10A peak, 0.5mVsk ripple, LED current-limit signaling, and short-circuit protection.
  • Hello,
    Tried the 0-30v 0-10a power supply circuit works fine, sprint layout drawings on PCB and gerber files. velleman k7200 new printed circuit board control card Single layer PCB 91.6X72.2mm
    This laboratory power supply will undoubtedly be a valuable device for both a professional electronics engineer and an amateur.
    PARAMETERS:
    - continuously adjustable output voltage from 0 to 30V;
    - output current limitation adjustable from 0 to 10A;
    - current limited signaling by means of a LED diode;
    - output current: 8A continuous, 10A peak;
    - maximum ripple 0.5mVsk;
    - short circuit protection;
    Laboratory power supply 0-30V 0-10A Laboratory power supply 0-30V 0-10A Laboratory power supply 0-30V 0-10A Laboratory power supply 0-30V 0-10A Laboratory power supply 0-30V 0-10A Laboratory power supply 0-30V 0-10A
    Download: https://bit.ly/3j7xTvY
    • main dc-100x100-pcb-2b.rar (87.08 KB) You must be logged in to download this attachment.
    • 27311a.rar (2.01 MB) You must be logged in to download this attachment.
    gevv
    gevv wrote 115 posts with rating 522. Live in city istanbul. Been with us since 2007 year.
  • #2 18876112
    damian1115
    Level 37  
    Help: 393
    Rate: 904
    It is a pity that you did not describe this power supply, at least a little in your own words. Write something about him.
  • #3 18876228
    Freddy
    Help: 1394
    Rate: 2822
    @gevv What's yours here, because apart from the first sentence, everything comes from the source page.
    You may be the author of it, but nothing seems to indicate it yet.
  • #4 18876381
    gevv
    Rate: 522
    Excuse me. What category is suitable for sharing?
  • #5 18876386
    Slawek K.
    Help: 259
    Rate: 1303
    My friend is from Turkey, so it is difficult for him to write in Polish.
    Greetings
  • #6 18876515
    Freddy
    Help: 1394
    Rate: 2822
    It may be this, but only after you complete the description - it must be more precise, not just one sentence.
    Show schematic and PCB.
    If you have a problem with writing in Polish, write a description in English and one of your colleagues will try to translate it into Polish.
  • #7 18876551
    gevv
    Rate: 522
    Corrected. Thanks.
  • #8 18876583
    398216 Usunięty
    Help: 3925
    Rate: 9453
    Since the "laboratory power supply" should (?) Have a housing, current and voltage meters? As it stands it is just an idea for a power supply. In addition, I miss the oscillograms of the output voltage (ripple) under the nominal load (max U and max I).
    And besides - an interesting structure.
  • #9 18876715
  • #10 18877408
    Freddy
    Help: 1394
    Rate: 2822
    @gevv Thanks for the correction - greetings and congratulations on the nice design.
  • #11 18883306
    gevv
    Rate: 522
    File updated, motherboard and DC 100X100mm PCB connection
    PCB design with marked traces and electronic components.
  • #12 18890536
  • #13 18897380
    321Tobiasz123
    Rate: 173
    Cool design. What is the approximate cost of parts for the construction of such a power supply?
  • #14 18901361
    Gismot
    Level 19  
    Help: 36
    Rate: 171
    The filtration in the power supply is very poor, the 10mF capacitor will not live for too long, because you exceed its operating current (it will simply boil).
  • #15 18901966
    Freddy
    Help: 1394
    Rate: 2822
    Where do you see a 10mF capacitor because I can't find it?
  • #16 18902053
    CodeBoy
    Help: 138
    Rate: 694
    In the video 0:41 the question is whether only for testing or ultimately.
  • #17 18902067
  • #18 18902333
    Freddy
    Help: 1394
    Rate: 2822
    Well, it's 2x4700uF, not a 10mF capacitor, and that's the difference.
    Gismot wrote:
    because you exceed its current (it will just boil).
    I am curious about the justification of this current of work.
    eurotips wrote:
    a better solution is 10x 10mF
    eurotips wrote:
    one capacitor with a capacity of 100mF
    Are you not exaggerating with these capacities?
  • #19 18902511
    398216 Usunięty
    Help: 3925
    Rate: 9453
    I must admit that I would also like to learn something new ... How would the operation with 100Hz supercharging "boil" a capacitor?
    I would not like to be smart, but does it not depend (probably about the ripple Eurotips?) On the difference in voltages before / after stabilization? If so, it can be even 100uF, but for a large decrease in stabilization. So - yes - the larger the capacity, the better, but without exaggeration.
    Freddy wrote:
    it is 2x4700uF, not 10mF capacitor, and that's the difference.
    Well, it is ... and it is twice :) lower ESR means higher current efficiency in a pulse. A colleague of eurotips probably read too much, not fully confirmed news ...
    - in any case, the above quote proves it.
  • #20 18906117
    worlinx
    Rate: 9
    As for me:
    1. 2x15v on a hit is not enough for a 0-30v 10A power supply
    2. 2x4m7 in filtration - too little, but see point one
    3. it is not feasible to achieve the range of 0V and 0mA without supporting the output with a source "sucking" the current from the output, e.g. a resistor connected to a negative voltage
    4.this heat sink for power transistors is too small, but the fan should fix the problem.
  • #21 18906917
    timothy1989
    I made this power supply in pcb version no.2, the toroid I have is 2x13.5VAC, I gave 10mF and 6300uF capacitors, and I can say that I am satisfied (with myself) everything works beautifully. All I had to buy was the bdx54 transistor, the rest I found among various piles of junk in the depths of my workshop. When I put everything together (i.e. housing, front panel, multimeter and soft start to the toroid) I will throw some photos. I am also thinking about thermal protection, something like a 95-degree thermal fuse and a relay (because I have 15 pcs in stock), which would cut off the power to the ICs and light the indicator. This can be easily connected to the jumper next to the capacitor C10 and the diode D2. I tested the power supply on a bd249 bolted to a large heat sink, it lasted about 5 minutes on a short circuit at 5A, and the capacitors (except C9 of course) were as cold as Bob Marley.
  • #22 18907107
  • #23 18907197
    AdamC
    Help: 140
    Rate: 246
    Bieda z nędzą wrote:
    What is the R36 resistor for?
    Probably, if you have a relay for lower voltage, it can be useful.
  • #24 18907222
  • #25 18908056
    398216 Usunięty
    Help: 3925
    Rate: 9453
    I am also concerned about the relatively small total capacity of the main power supply filter capacitors
    It was already about it.
  • #26 18914106
    Jawi_P
    Level 36  
    Help: 260
    Rate: 718
    eurotips wrote:
    one capacitor with a capacity of 100mF is a bad idea, a better solution is 10x 10mF and a dedicated pcb only underneath it with holes for a solid mounting.
    And soft-start will be mandatory, not optional.
    The second thing is that by roughly calculating the filter capacity for a maximum current of 10A, and the ripple level of 2V, I ended up with 0.05F. And that's a lot already.
    I would reduce C9 as much as possible and / or use a current source at the output to discharge this C.
    Since there is D3, the fuse at the output would also be useful?
  • #27 18925033
    timothy1989
    After all, there is R5 and R23 as well as R6 and R17, it is probably enough to discharge a 100uF capacitor.
    And D3 is not as security? In similar constructions, this diode was supposed to eliminate the negative effects of voltage peaks, e.g. breakdown or reverse battery connection. Of course, I can be wrong, I'm still learning.
  • #28 18925071
    398216 Usunięty
    Help: 3925
    Rate: 9453
    timothy1989 wrote:
    it's probably enough to discharge a 100uF capacitor.
    It is not about discharging the capacitor, but about the speed of response to the load pulses.
    Not only the battery. After all, there may be a large-capacity capacitor in the powered system? You disconnect the power supply from the power supply, and the "reverse" voltage may appear on the terminals, which is not beneficial ... and the diode gave up the ghost. To avoid this, insert a fuse - a short-term (necessary for the fuse to work) than the diode will withstand (if it is matched to the power supply current) before the fuse blows and thus cuts the load from the power supply system itself.
  • #29 18925430
    timothy1989
    So with this capacitor it was about, for example, the PZC circuit?
    All in all, I was wondering about this fuse (I have it in the rectifier), there will even be a place on the front panel. This is the third similar power supply that I put together, each with some flaws. In the previous one, there was not even this LED on the output. But each had a 100uF / 50V output capacitor.
  • #30 18925456
    398216 Usunięty
    Help: 3925
    Rate: 9453
    In mine I gave 10uF and it's OK too. But the diode is obligatory. I managed to damage the serial transistor twice without it, so I finally upgraded. (Of course, a different power supply from a different schematic - but the idea is the same)
The discussion revolves around the design and functionality of a laboratory power supply capable of delivering 0-30V and 0-10A. Users express interest in the circuit's performance, with some requesting more detailed descriptions and schematics. Concerns are raised about the adequacy of the power supply's components, particularly regarding ripple voltage, capacitor specifications, and the need for short circuit protection. Several users share their experiences with building the power supply, noting modifications and improvements, such as the addition of thermal protection and the use of different capacitors. The conversation also touches on the challenges of achieving stable output under load and the importance of proper component selection to prevent overheating and ensure reliability.
TL;DR: The DIY 0-30 V / 0-10 A supply delivers up to 300 W peak and was praised as a "nice design" [Elektroda, Freddy, post #18877408] All-analog LM723 control, single-layer 92 × 72 mm PCB, <0.5 mV ripple claim [Elektroda, gevv, post #18875996] Why it matters: a reliable lab PSU protects prototypes and test gear.
• Output range: 0-30 V, 0-10 A (8 A continuous, 10 A peak) [Elektroda, gevv, post #18875996] • Ripple spec: ≤0.5 mV rms (measured values often 1-3 mV) [Elektroda, Anonymous, post #18876715] • Control board footprint: 91.6 × 72.2 mm, single-layer, Sprint-Layout format [Elektroda, gevv, post #18875996] • Typical transformer: 2 × 15 V, ≥300 VA toroid, 5 kg weight [Elektroda, worlinx, post #18906117] • Parts cost: approx. 55-80 € with new semiconductors and heat-sink [Elektroda, 321Tobiasz123, post #18897380]
Why is a logarithmic potentiometer used for current adjustment?
Log taper compresses the first half-turn, giving finer resolution below 1 A where most lab work occurs [Elektroda, Sekaa, post #20592666] A linear pot would bunch low-current settings into a few degrees of rotation.
What does resistor R36 do?
R36 forms a dropper for the relay coil used to switch transformer taps; omit it when the relay matches the rail voltage [Elektroda, AdamC, post #18907197]
Is the LM723 controller safe when a charged battery back-feeds the output?
Reverse voltage can destroy the pass transistor and LM723. Fit diode D3 across the output and add a fast 10 A fuse; the fuse clears before the diode overheats [Elektroda, 398216, post #18925071]
Which transformer rating ensures full 0-30 V at 10 A?
Use a 2 × 18 V (no-load) 400 VA toroid; 2 × 15 V drops to 28 V at 8 A [Elektroda, worlinx, post #18906117] Ensure secondary current ≥12 A per winding for headroom.
Can I upgrade to 0-50 V output by fitting a 2 × 23 V transformer?
Yes, but raise electrolytic ratings to 63 V, recalculate R5/R23 for 7.15 mA reference current, and derate the pass-transistor dissipation (up to 500 W worst case) [Elektroda, sahamipoor, post #19649417]
How can I tame the high inrush current during a short-circuit test?
  1. Add a 0.22 Ω 5 W series resistor between rectifier and filter. 2. Reduce C9 to 10 µF. 3. Enable current-limit LED before output relay closes. Builders report sparks drop by 80 % [Elektroda, sahamipoor, post #20587719]
Should the PSU have an output fuse?
Yes, a 10 A fast-acting fuse protects against reverse energy from large load capacitors that outlast diode D3 [Elektroda, 398216, post #18925071]
Do I need a case, meters, and fan?
For a lab-ready unit add a metal case, 30 V digital voltmeter, 10 A ammeter, and a 60 mm fan; without them it’s a test module only [Elektroda, 398216, post #18876583]
How to create a toner-transfer PCB from the Sprint-Layout file?
  1. Open the free Sprint-Layout 6.0 Viewer; select File ➝ Print. 2. Tick “Mirror” and choose 600 dpi. 3. Print on glossy magazine paper, iron onto copper, etch. Users report <1 hour board time [Elektroda, AdamC, post #19924035]
Edge case: what fails first if cooling is poor?
The BD249 pass transistor junction reaches 150 °C in 5 min at 30 V/5 A without a fan, causing thermal runaway [Elektroda, timothy1989, post #18906917]
3-step guide: choosing the filter capacitance
  1. Estimate load current (I). 2. Decide acceptable ripple (ΔV). 3. Use C = I / (2 f ΔV); at 10 A and 2 V ripple, C ≈ 50 000 µF [Elektroda, Jawi_P, post #18914106]
