Electrician Certification: SEP Courses, Cost & Locations for North-West Mazovia Residents
tomek9005 93566 43
How can a north-west Mazovia resident obtain the qualifications needed to legally install, repair, measure, and independently perform electrical work in residential buildings, and what course, cost, validity, and location should they expect?
For ordinary residential electrical work, obtain a G1 (group 1) electrical qualification certificate for E/operation up to 1 kV, preferably including control-and-measurement work; D/supervision is additionally relevant when supervising workers or signing documents [#12008911] The nearest SEP branch mentioned is in Płock, which can provide the application materials, course dates, and examination arrangements [#10403499][#10403530] Reported costs range from about PLN 400–450 for training plus roughly PLN 150 for the exam, while a later Płock listing reported PLN 150 for training and PLN 185 for the exam [#10403479][#10412075][#15794205] A short course mainly prepares candidates for the qualification examination and does not replace practical electrical experience; training duration is not legally prescribed [#12008911] Designing installations and formally accepting them requires building qualifications, not merely an energy qualification, and measurement work was described as requiring at least two people unless the applicable arrangements provide both E and D roles [#10404305][#11307928][#11263074]
  • #1 10403382
    tomek9005
    Rate: 54
    Hello dear colleagues.
    I would like to have electrician papers as an electrician and be able to work on my own as an electrician with an equivalent document (earn extra money after hours).
    I have experience because I have worked alongside an electrician for several years and also general knowledge (several hours a week in a technical college).
    I have a request, I could have someone write me what SEP course I should do
    to work legally. For example: someone builds a house, I come over there, I install it
    I give the owner he calls Energetyka come and pull the cables.
    And everyone is happy ;)
    How much does such a course cost? And where are the next such trainings held? (I live in north-west Mazovia.
    And the most important question, how much does it cost?
  • #2 10403427
    kizek
    Help: 288
    Rate: 488
    You enter your buddy in "Googlach" SEP and you already know everything.
  • #3 10403479
    more.fire
    Help: 5
    Rate: 24
    The course costs about PLN 400, and the exam costs about PLN 150. Everything is as above in googles
  • #4 10403499
    tomek9005
    Rate: 54
    My friend, unfortunately, I didn't see anything from this side. I only found the address.
    The nearest SEP branch is in Płock.
    I think I have to ask there if nobody will help me:>
    I can't find anything for anything, there are some pages, but it's not a transition.
    I mean explaining what course and what can be done and what not.
  • #5 10403523
    vorlog
    Level 40  
    Help: 527
    Rate: 2586
    Because SEP is not permanently associated with it anymore ...
    The certificate of qualification is not a "SEP qualification".
    As for the rest, read on
    http://www.abc.com.pl/serwis/du/1998/0377.htm " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://www.abc.com.pl/serwis/du/1998/0377.htm
    https://www.lebiedz.com.pl/uprawnienia_sep_egzamin_grupa_1 " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > https://www.lebiedz.com.pl/uprawnienia_sep_egzamin_grupa_1
  • #6 10403530
    kizek
    Help: 288
    Rate: 488
    Friend, unfortunately, but you have to personally go to the SEP facility, you will get the appropriate materials there and the only thing left to do is sign up for the next organized course and then take the exam, unless your friend feels up to the exam externally. Good luck.
  • #7 10403557
    more.fire
    Help: 5
    Rate: 24
    It is not as easy as it sounds. At the beginning, I recommend that you do E type permissions up to 1kV and have control and measurement procedures. There are many sub-items, I don't remember how many.
    As I thought, they were with me in the group of polytechnic graduates ... they did everything when it goes above 1kV. But their heads were stout.
  • #8 10403561
    vorlog
    Level 40  
    Help: 527
    Rate: 2586
    The first attempt exam and, in addition, the first ever qualification certificate without a course, can only be obtained by the examiner himself :D
    I have a valid E certificate (currently up to 15kV) for thirty years, D for ten years, but without the "course" I bought, I would rather not go ...
    One day course and exam - that says a lot, right? And with me recently a few non-electricians with a zero professional notion have passed :P
    V.
    EDIT: The qualification certificate is required for people operating devices with an installed capacity of over 20kW, so such a miller, for example, working on a larger milling machine, must also have them. Theoretically, he will be promoted to the group of professional electricians ...
  • #9 10403636
    tomek9005
    Rate: 54
    Gentlemen, without exaggeration, I will also do such a genius, I'm not.
    My only point is to design installations to install people at home, repair faults and make a little money on it and that it should all be legal :)
  • #10 10403646
    vorlog
    Level 40  
    Help: 527
    Rate: 2586
    Here, the qualification certificate itself will probably not touch ...
    V.
  • #11 10403787
    tomek9005
    Rate: 54
    This is what he wants to know where to do it and how much it costs and how many years it is valid. :)
  • #12 10403817
    kizek
    Help: 288
    Rate: 488
    For a period of 5 years.
  • #13 10403824
    vorlog
    Level 40  
    Help: 527
    Rate: 2586
    tomek9005 wrote:
    I just mean to design installations
    I repeat - the qualification certificate is not enough ...
    And correct the title - unless you really want to become just an "electrician"
    V.
  • #15 10404305
    more.fire
    Help: 5
    Rate: 24
    To design installations, you must have design qualifications. During your studies, you do such projects and you need an internship after graduation. Personally, I do not know a technician or ZSZ graduate who would have such qualifications, but I know more of an engineer.
  • #16 10410042
    nicox
    Hello...
    I do not want to start a new topic so I will ask here:
    having no education or extensive experience, I would like to take such a one-day course and SEP exam
    I don't need permission at the moment, but for the future :) besides, I will probably do the installation in a new house myself, so additional knowledge will be useful because someone with the appropriate 'paper' will probably have to take measurements and issue a protocol (?)
    So what is the chance that in these few hours they will teach me enough to pass the exam (I would like D and E together)?
    Maybe someone who, like me, does not have school or experience, was at such a training?
  • #17 10410085
    bmserwis
    Level 36  
    Help: 262
    Rate: 200
    I will answer in turn:
    Rather, exploitation will conquer you, do not count on anything else.
    nicox wrote:
    I do not need permission at the moment, but for the future
    Valid for five years.
    nicox wrote:
    So I will probably do the installation myself in a new house, so additional knowledge will be useful, because probably someone with the appropriate 'paper' will have to take measurements and issue a protocol (?)
    SEP 1kV P, additionally, the installation design must be approved by someone with a building license.
    Unless you are Einstein or Tesla - zero.
  • #18 10410097
    more.fire
    Help: 5
    Rate: 24
    @nicox
    The course lasts a month and the exam is "easy" but it depends on who you hit ... forget it in one day. If you do the course, you will rather pass it because you have already paid for the course .... understand ?. And if you pass the exam without a course, they will let you go on the first, second and third.
    There is no difference in price, but you will have to learn what you would know after the course. Understand?. Speculation rules ...
  • #19 10410577
    vorlog
    Level 40  
    Help: 527
    Rate: 2586
    Gentlemen, it's worth keeping your news up-to-date :)
    To read:
    http://ise.pl/index.php?option=com_jfusion&Itemid=39&jfile=viewtopic.php&f=16&t=14889 " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://ise.pl/index.php?option=com_jfusion&Itemid=39&jfile=viewtopic.php&f=16&t=14889
    There:
    Despite the appeal of the Association of Polish Electrical Engineers to deputies regarding the maintenance of obligatory exams for energy specialists in the Energy Law, the Sejm rejected the amendment of the Senate on August 19, 2011. This means that the obligation to repeat qualifying examinations every five years has been reduced.
    It is only valid:
    -people who have appropriate qualifications, but have not worked on devices, installations or networks in the last five years
    -people dealing with the operation of devices, installations or networks, and providing services to consumers and micro, small and medium-sized enterprises.
    - at the employer's request - in the case of modernization or significant change in the parameters of devices, installations or networks at which employees are employed.
    The amendment was signed by the President .
    V.
  • #20 10410613
    bmserwis
    Level 36  
    Help: 262
    Rate: 200
    You have to read it with understanding, in practice, this amendment meant that only power plant employees will not have to renew their allowances every 5 years, for the rest nothing has changed.
  • #21 10410659
    vorlog
    Level 40  
    Help: 527
    Rate: 2586
    bmserwis wrote:
    Buddy, you have to read with understanding
    So I suggest you relate it to yourself.
    I do not work in ZE, but since my company is owned by large enterprises, in addition, I do not earn extra money, I am not obliged, like all electricians in the company, to repeat every five years. Proven at the source.
    V.
  • #22 10410869
    tomek9005
    Rate: 54
    Gentlemen, that is, every five years if someone does not work in the ZE, you have to renew it?
    And what is the situation (procedure) of connecting the house to the national network?
    I mean, for example, does an electrician with permissions set up the installation and there must be a third person who measures and gives a protocol to the power supply that the house is suitable for connection to the network? How is it?
    Moderated By lechm56:
    Let me remind you of the topic: Courses Sep. How to become an electrician? (Should be an "electrician")
  • #23 10411548
    bmserwis
    Level 36  
    Help: 262
    Rate: 200
    If you have SEP 1kV P qualifications, you sign the report yourself and stamp it. ZE arrives and seals the meter and that's it.
  • #24 10412075
    tomek9005
    Rate: 54
    This is what I mean. And what are the monthly fees for having a stamp?
    Such a course is said to cost PLN 450. Tomorrow I will call SEP Płock, find out something more, I will write.
  • #25 10709319
    -pawlo111
    Rate: 23
    gentlemen or course - Preparing to obtain a qualification certificate gr. I (electrical) operation of selected devices, installations or power networks with a voltage of up to 1 kV.
    The training ends with an examination before the Admissions Committee. the same as the SEP course for E-esksploatacji?
    because I read I read and I have more and more confused already.
    Because I have a job offer, but SEP qualifications are needed - even the lowest ..
  • #26 10710720
    bmserwis
    Level 36  
    Help: 262
    Rate: 200
    What does it mean the lowest?
    If that's what it is called then yes.
  • #28 11263074
    alberrt
    Help: 5
    Rate: 36
    sp6vga wrote:
    I also suggest paying attention to this comment so as not to repeat the topic
    http://gep.com.pl/PDF/upr_do_kontr.pdf
    The above comment is false and misleading. In 2006, the Ministry of Economy re-interpreted the scope of activities and duties in positions E and D :)
    It was stated there that E and D are two different positions and the one who has E cannot do what D does and vice versa, that is, who has D cannot do what E. As for measurements, if someone has only D, it cannot perform them, because it is physical contact with the device or installation (and this can only have E). D can only sign a report of such measurements. If someone has an E and D, he can take measurements and sign them on the protocol. Just remember that control and measurement work is an activity that should be performed by at least two people. So, after all, there must be two workers: for example, one E and one D, or one that has E and D and one E.
  • #29 11296173
    Sobecki Racing
    Rate: 15
    what do you need to have for pickup? I'm trying to train, exam, found books from my grandfather and he has D + E.
    It has it written there
    D-operation, maintenance, repairs, assembly, control and measurement
    E-service, maintenance, repairs, assembly
    could he do pickups or not ??
  • #30 11307928
    alberrt
    Help: 5
    Rate: 36
    Building qualifications are required to receive the electrical installation, not energy qualifications.
Residents of north-west Mazovia seeking electrician certification can pursue SEP courses, which typically cost around PLN 400 for the course and PLN 150 for the exam. The qualifications are valid for five years. It is recommended to start with E-type permissions for installations up to 1kV, and to consider multi-day courses for better preparation. The SEP branch in Płock is a key location for training. The qualification certificate is essential for legal work, and it is important to understand the distinction between E (exploitation) and D (design) qualifications, as they have different scopes of work. For installations, a qualified electrician must sign off on the work, and additional knowledge about control and measurement procedures is beneficial.
TL;DR: SEP group-1 courses cost 150-450 PLN and exams 150-185 PLN [Elektroda, more.fire, #10403479; gebka, #15794205]. “Unless you are Einstein – zero chance to pass without study” [bmserwis, #10410085]. Typical certificates stay valid five years unless you work continuously. Why it matters: Picking the right course and scope saves repeat exams, money and legal trouble.
• Course fee range: 150 PLN (Płock) – 450 PLN (Mazovia) [Elektroda, #15794205; #10412075] • Exam fee: 150-185 PLN (10 % of minimum wage) [Elektroda, #10403479; #15794205] • Validity: 5 years, waived if you work on installations continuously [Elektroda, vorlog, post #10410577] • Key licences: E = operation, D = supervision; both fall under Group 1 ≤ 1 kV [Elektroda, 11263074] • Measurements require two people or one person holding both E and D [Elektroda, post #11263074]
What licence do I need to wire single-family houses legally?
Choose Group 1 (≤ 1 kV) exploitation “E” permission. It covers installation, repair and maintenance of low-voltage home wiring [Elektroda, more.fire, post #10403557]
Is SEP ownership mandatory, or will any accredited body do?
The Energy Law only requires passing an exam before an accredited commission. SEP is popular but not obligatory [Elektroda, vorlog, post #10403523]
How much will the course and exam cost in Mazovia?
North-west Mazovia quotes 400 PLN for the course and 150 PLN for the exam [Elektroda, 10403479] Płock offers 150 PLN training and 185 PLN exam [Elektroda, post #15794205]
How long are the certificates valid?
Standard validity is five years. Renewal is skipped if you have worked on qualified equipment during that period [Elektroda, vorlog, post #10410577]
What is the practical difference between E and D?
E lets you operate, maintain and test equipment. D lets you supervise staff and sign protocols. Tasks often need both [Elektroda, 11263074]
Do I need both E and D for measurements?
Yes. E holder performs tests; D holder signs. One person with both E and D can do all steps [Elektroda, 11263074]
Can I pass the exam without attending a course?
Yes, but boards may fail first-timers. One member noted, “They will let you go on the first, second and third” attempt if unprepared [Elektroda, more.fire, post #10410097]
How long do trainings last?
Offers vary from one-day cram sessions to month-long evening classes. Płock advertises a single-day option [Elektroda, 15794205], while others run five-day blocks [Elektroda, 12045782]
Three-step process to obtain SEP G1 E licence
  1. Register with an accredited centre and pay the fee. 2. Attend preparatory course (optional but recommended). 3. Pass oral exam before the commission and receive the printed certificate and stamp [Elektroda, 10403530]
Can a SEP certificate holder design electrical installations?
No. Design work requires separate building-design qualifications issued by the Chamber of Civil Engineers [Elektroda, 10404305]
Who may connect a newly built house to the grid?
An E-licenced electrician issues the measurement protocol; D signs it; the utility then seals the meter [Elektroda, bmserwis, post #10411548]
Are there monthly fees for holding the round stamp?
No statutory stamp fee exists. After you buy the stamp once, no periodic payments follow [Elektroda, 10412075]
What if I stop working in the trade for five years?
You must retake the exam because active practice exemption no longer applies [Elektroda, 10410869]
Edge case: will the commission grant D rights on a first exam?
Some SEP boards refuse D to newcomers, despite no legal basis [Elektroda, 12008911] Prepare to appeal or re-sit.
