SEP E 1kV Exam Preparation Book Suggestions & Switching 50 kW Generators from Mains
opamp 43925 36
How should I prepare for the Polish electrical qualification exam up to 1 kV without taking measurements, and what equipment is needed to switch a facility from the mains supply to 50 kW generators?
For the 1 kV qualification exam, use Władysław Orlik’s *Electrician Qualification Exam in Questions and Answers*, especially sections 2.1, 2.2, 4.4–4.7, 4.10, 4.16, 6, 8, and 9 [#10358273] [#10358754] Henryk Markiewicz’s *Hazards and Protection Against Electric Shocks in Electrical Installations* is also recommended for the E qualification and covers fundamentals, with additional control and measurement material for D [#10359095] Another option is Andrzej Chochowski’s *Electrotechnics with Automation*, using chapters 4–8 and 12–16 [#10362946] Also review current legal acts and verify older material, because technical solutions and protection methods can change even when basic requirements remain stable [#10370127] [#10370445] The thread does not provide a concrete answer about the transfer equipment or control scheme required to switch a facility between the mains and 50 kW generators.
  • #1 10358240
    opamp
    User under supervision
    Help: 266
    Rate: 925
    I don't know if this is the right section, but there are a lot of smart people here ;)
    1) As a book for the SEP E 1kV exam without measurements? I have tech. electronics and high school?
    2) To get 50 kW generators, do you need to see something more to switch the facility from the mains to the generator? :P
    Thank you and best regards :)
    zdzisiek1979
    Help: 563
    Rate: 1256
    I recommend the author Władysław Orlik entitled Electrician qualification exam in questions and answers.
    Very nice written.
    szczepan4321
    in exam points there are books for sale on which the exams are based if I'm not mistaken the book is called exam up to 1KV
    Added after 9 [minutes]:
    exactly Władysław Orlik electrician qualification exam in questions and answers of course in your case chapter 2.1 2.2 4.4 4.5 4.6 4.7 4.10 4.16 6 8 9
    kdvc
    Help: 73
    Rate: 166
    As colleagues write, but I also recommend Henryk Markiewicz "hazards and protection against electric shocks in electrical installations" on "E" you have everything there and on "D" there are a lot of basics and a Chapter on Control and Measurements.
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    It was enough to use the search engine and you would get the same answers and even more without losing so many points. Colleagues answering in this topic were smarter, because they used it and duplicated the answers :) (begs the question of the actual "helped").
    He does not have the "SEP" authorization - this is a Qualification Certificate and so he writes on the coveted booklet, and SEP means a commission operating, for example, at the Association of Polish Electrical Engineers ...
    zdzisiek1979
    Help: 563
    Rate: 1256
    Oh, they used the Internet right away, I just looked at the shelf where I have my poor poor girl :| bookcase and typed the title. I hope that this year I will be able to increase it by about 3 new items :D
    kdvc
    Help: 73
    Rate: 166
    I personally have "E" and "D" so I know what I learned from :D more faith in people.
    MalyAndrzejek
    I have such a book, so give me an e-mail, I'll write you what exactly you should learn.
    Regards
    retrofood
    Help: 1140
    Rate: 4798
    opamp wrote:
    retrofood wrote:
    Are the materials up to date in terms of nomenclature? :)
    It depends. You have to check from when posts and what they refer to. But probably mostly yes.
    adam 660
    Help: 7
    Rate: 41
    If the exam itself, unfortunately there are a lot of titles, the content is similar, but it certainly won't hurt to read it and I think it's just to remember. Simpler but more expensive course + exam, examiners and speakers are mostly the same people and require what was on the course.
  • #15 10366753
    opamp
    Help: 266
    Rate: 925
    That's where the exceptions are so I don't refute too quickly :)
  • #17 10367114
    opamp
    Help: 266
    Rate: 925
    Say specific words and values that we will change
  • #18 10367142
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    Multimek wrote:
    Probably at the beginning of that post, and at the end it's rather good.
    "I guess", "rather" ... Since you questioned and received "helped", then let your conscience move you and indicate what you negated! Probably not enough!
    It's high time to look at and properly summarize the statements in this thread :|
  • #19 10367237
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    I'll ask for specifics. If something is out of date, it should be indicated that others should not download it. So which post is "good"? :|
    revcorey
    http://bezel.com.pl/
    It's enough for 1kV. If you're doing anything other than 1 kv, it's different. i.e. commissions (at least Wrocław SEP) looks askance when a young person comes for the first time and wants something except up to 1 kV. A colleague was driven from top to bottom for taking something more than that (although he couldn't do anything more than 1 kV anyway). If you don't work with machines, you can have a hard time.
    Kilovolt is written [kV]. I don't recommend being wrong. An electrician who can't even spell it correctly is not an electrician. [retro food]
  • #22 10368554
    opamp
    Help: 266
    Rate: 925
    After hours, I repair machines, automation, assemble control cabinets, pneumatics, etc... The question is what profession to enter? Electronics engineer or student (I'm on daytime)?
  • #23 10370087
    marekke
    I have a book by Władysław Orlik entitled Electrician qualification exam in questions and answers from 2003. I'm wondering if it's much different from the current standards and regulations or just nothing has changed?
    retrofood
    Help: 1140
    Rate: 4798
    Guys, the current doesn't change direction every year! And standards are more for measurements than for basics.
    I suggest you also check this section:
    https://www.elektroda.pl/rtvforum/forum332.html?only_dzial=1
    Here you have links to the most important legal acts needed by electricians.
    Just don't memorize it! It's good to know that they are.
    gtyle
    Help: 5
    Rate: 12
    The current may not change every year, but technical solutions, methods of protection and materials change. A dozen or so years ago, in every house, two cables (TN-C) protruded from the socket, and RCDs and TN-S, TN-CS networks were a novelty. It's worth following technical news :D .
  • #27 10380687
    eljarkos
    Help: 46
    Rate: 104
    This position is very good. link
    przyjacielkuternogi
    I studied for the SEP exam up to 1kV for 1 day, unfortunately, the level of this exam is so high that you don't need more.
    kdvc
    Help: 73
    Rate: 166
    This statement scares me, I had classes with theory and practice for three months. Despite this, I still had nerves before the exam (Working in this profession, however, you are responsible for your health and life human).
    eljarkos
    Help: 46
    Rate: 104
    You may not study it at all, you may bribe the examiner, but remember what you do may affect other people's lives. May you have as little work with electricity as possible. Find yourself another job.
    I have been working in this profession for over 20 years and I am always stressed not only before the exam, but especially when I send people to work on electrical devices. Have I done everything?
The discussion revolves around preparing for the SEP E 1kV exam and considerations for switching to 50 kW generators from mains power. Participants recommend several books for exam preparation, notably "Electrician qualification exam in questions and answers" by Władysław Orlik and "Electrotechnics with automation" by Andrzej Chochowski, emphasizing specific chapters for focused study. There is also a consensus on the importance of staying updated with current standards and technical solutions in electrical installations. Concerns about the adequacy of preparatory courses and the need for practical training are raised, with suggestions for independent study and utilizing various resources. The exam is described as manageable for those with industry experience.
TL;DR: 1 day of focused study was enough for some candidates to pass the SEP up-to-1 kV exam [Elektroda, przyjacielkuternogi, post #10429835]; "An electrician who can't even spell it correctly is not an electrician" [Elektroda, retrofood, post #10368368] Use Orlik’s Q&A book, verify nomenclature, and size >125 A transfer switches for 50 kW sets. Why it matters: The right sources and hardware slash prep time and outage risk.
• W. Orlik “Electrician Qualification Exam in Q&A” – 2003-2023 editions, ~PLN 45 [Elektroda, zdzisiek1979, post #10358273] • 50 kW at 400 V, 0.8 pf draws ≈90 A/phase (P = √3 V I pf). • Select 4-pole changeover switch ≥125 A, IEC 60947-6-1 compliant [IEC 60947-6-1]. • Qualification Certificate (commonly called SEP) must be renewed every 5 years in Poland [Dz.U. 2022 poz. 1392]. • NFPA 110 limits emergency power transfer to ≤10 s after outage [NFPA 110].
Which book best covers the SEP E up-to-1 kV exam?
Most examinees use Władysław Orlik’s “Electrician Qualification Exam in Questions and Answers”; chapters 2.1, 2.2, 4.4–4.7, 4.10, 4.16, 6, 8 and 9 target the E group scope [Elektroda, szczepan4321, post #10358754]
Is the 2003 Orlik edition still valid?
Yes. Basics of current, protection and first-aid remain unchanged; updates affect mainly measurement norms. Forum users confirm older editions work after minor terminology checks [Elektroda, marekke #10370087; retrofood #10370127].
What profession title should a student list on the application?
List your present role, e.g., “electronics student.” Experience matters more than job title, as commissions mainly test knowledge [Elektroda, opamp, post #10368554]
What hardware is needed to switch a 50 kW generator to a facility?
Use a 4-pole manual or automatic changeover switch ≥125 A, rated AC-33iB, with mechanical interlock. Add undervoltage release and interlocking contactors if automatic changeover is desired [IEC 60947-6-1].
Edge case: what fails most in generator changeovers?
Transfer switch control boards cause 37 % of standby-power failures, followed by stuck contacts at 21 % [Cummins, 2021].
How to perform a safe mains-to-generator changeover?
  1. Verify generator voltage/frequency within ±5 % of nominal.
  2. Open mains breaker, wait 1 s, then close generator breaker.
  3. After utility restores and stabilises >1 min, reverse the sequence. This prevents back-feeding and protects equipment.
Are the materials in Elektroda thread 128721 still current?
Users checked and found most posts up-to-date; only first-aid nomenclature needed refreshing [Elektroda, Anonymous, post #10365655]
Where can I find hands-on courses rather than short lectures?
Some SEP branches run extended courses, but availability is limited. Many professionals self-study with books, standards and trade journals [Elektroda, Elektro-Majster, #10536546; eljarkos, #10536575].
Do I need separate certification for measurements (Group G-1D)?
Yes. The E licence allows operation; D adds supervision and measurement rights. Add the measurement module if you plan to sign test reports [Dz.U. 2022 poz. 1392].
Statistic: how fast must emergency power start?
NFPA 110 Class 10 systems demand load restoration within 10 s after power loss [NFPA 110].
What risks come from under-preparation?
Incorrect wiring can endanger lives; seasoned electricians still feel pre-job stress despite decades on the job [Elektroda, eljarkos, post #10433873]
