Lubrication for BOSCH Grinders: Gear Grease Recommendations, Viscosity, and Quantity Considerations
Matiush 56370 17
What grease viscosity and quantity should I use in a Bosch angle grinder gearbox so the grease stays on the teeth instead of being thrown out or leaking away?
For a Bosch angle grinder gearbox, the thread recommends a semi-fluid gear grease such as Lubriten EPS-0; EPS-1 is used more for hammers and slower, heavily loaded tools [#15094706][#10444586] Class 0 grease is often too fluid for grinders, and the original Bosch class-0 grease tends to leak out of older gearboxes with worn seals and O-rings, so it works best only in new, tight tools [#10444586] The grease should be viscous enough to stay on the teeth, but not so thick that it stops circulating; users note that too-thick grease may not participate in lubrication, while too-thin grease behaves almost like oil and can leak from the housing [#19407666][#19408366][#10441444] There is no exact quantity rule in the thread, but the practical advice is to use a grease that stays in the gearbox and then recheck it after some running time for settling, thinning, or lumps [#19408366] Do not mix incompatible greases, especially bentonite, polyurethane, or perfluorinated types, because they may damage the mechanism [#10441444]
  • #1 10432241
    Matiush
    Rate: 54
    I can't find specific information on gear lubrication in grinders. Different lubricants are given, but I checked two Łk-43 and another one recommended on the forum, the name of which I can't remember, and it applies to heavily loaded bearings and gears.
    The conclusion is that none of these lubricants do their job to the end. The latter is quite rare and when it smears the wheel it works fine, but it is soon thrown out by centrifugal force and the teeth go by ear. The grease is everywhere except on the teeth. I mixed two grade 00 and 2 greases to thicken. The effect is that after folding it works fine and is not thrown away right away, but when I left it with the axle up for the night - the grease flowed from the teeth and the grinder ran dry again. I'm already confused on this topic. Why does the grease not accumulate on the teeth, as in drills, where the grease is thick? How to improve the viscosity?
    And what about quantity? If there is a lot of thin grease in a very large amount, so that it has to be lubricated somehow, will it heat up faster, burn out?
    I did not check the lubricants recommended by the manufacturer, because they are a bit too expensive, and I am interested in a fairly universal solution. Although with the current problems, I have to try.
  • #4 10441444
    Matiush
    Rate: 54
    @ jannaszek: I am looking for a lubricant for the service, not for one lubrication. The ones recommended by Bosch cost about PLN 150 for 250ml. So it comes out to PLN 7-8 for lubrication and no one will pay me for it, because the customer is of the opinion, why lubricate when the lubricant is still there, or put Pan towot like waceko12. And then, because my teeth are chattering, and the Lord was fixing it.
    @PtasiorWro: colleague as always specific.
    I did some reading in the meantime.
    Some recommend 00 or 0 grade lubricants.
    Lubricant classification:
    Consistency class
    000 very fluid
    00 liquid
    0 semi-fluid
    1 very soft
    2 soft
    Lubriten EPX-000, EPX-00, EPX-0, EPX-1 greases are used depending on the gear structure, degree of sealing and temperature:
    Lubriten EPX - 000 - for lubricating the gears of rotary mower mechanisms.
    Lubriten EPX - 00 - at lower temperatures of the given range and with good sealing of the gearbox.
    Lubriten EPX - 0 - in intermediate conditions.
    Lubriten EPX - 1 - at higher temperatures of the given range and with poor sealing of the gearbox.
    Mixing incompatible lubricants can lead to damage
    mechanism. Especially bentonite and polyurethane lubricants
    and perfluorine are not miscible with the others.
  • #5 10444586
    PtasiorWro
    Help: 111
    Rate: 545
    I will add that the zero class is too fluid for grinders and hammers.
    The original Bosch grease is class zero, but it works only with new tools, as there are new oil seals and o-rings because after some time, especially at high temperatures, it starts to leak from every hole.
    In our company, we use EPS1 for gears (grinders, wall chasers, impact drivers, etc.), 2-pound hammers (GBH2-26, PPH30, DH24, HR2450) to demolition hammers (USH27, Milwakee 2500, 900K) and other tools where it is required lubrication.
    We only pour oil into new Hilti hammers and diamond drills (CARDI, REMS, etc.)
  • #6 10463488
    mareczek222
    Rate: 27
    For the Bosch GWS 14-125 angle grinder, I used Husqwarny grease for the angle gears of brushcutters (225 ml tube for PLN 23). The angle grinder has quieted down and the gears do not run dry. Kątówka has a lot of hours worked.
  • #7 10464705
    bolek9001
    Rate: 30
    Will this EPS-1 grease also be suitable for lubricating SDS terminals?
  • #8 10464912
    Matiush
    Rate: 54
    It seems to me that this grease will be too soft and too thin for SDS tips, but it's better to put something on it than nothing. I personally lubricate EP-2
  • #9 11069849
    Matiush
    Rate: 54
    Returning after some time to the topic of lubricants. I wonder if thick casein oil is suitable for gear lubrication? I have a lot of it.
    The lubricant recommended by PtasiorWro is elegant, I use it every day now.
    However, sometimes when I open grinders from customers there is this very sticky grease, very sticky. It was also similar in the transmission of a self-propelled wheelchair, where there may not be high revolutions, but a large load. I would like to know what specific it is.
  • #10 11175172
    Matiush
    Rate: 54
    I will answer my own question about sticky lubricants. They are used primarily at low speeds and high loads. In the event of high revolutions, the grease as well as the oil should not be viscous. It acquires proper lubricating properties only during operation.
    I am currently interested in Makita P-08361 semi-fluid graphite grease - do you know the equivalent?
    What lubricant do you use in drills, mixers (approx. 2000W)? The grease used so far burns out, and I used EP2 from a good company. what do you use?
  • #11 11178869
    PtasiorWro
    Help: 111
    Rate: 545
    I use FAZI EPS 1 from Czechowice Dziedzice.
    It works well with hammers as well as with slower machines such as stirrers and magnetic drills.
  • #12 11179675
    Matiush
    Rate: 54
    Is this FAZI EPS 1 also suitable for stirrers? When I open the machine, there is quite a thick grease there and I tried to apply it, sometimes I put phases, but without conviction. So, in general, this samarium can be applied to young, slow machines with a greater load, but also to high-speed grinders or polishers, right?
    I'm digging this topic, because not which companies I repair tools get equipment and wrongly selected lubricant or amount takes revenge. I haven't had a problem with this grease yet, but with others I've had. A grinder that runs for a few hours without major breaks quickly returns, but hopefully not with the same fault. I often waste time wondering if this grease will be suitable.
  • #13 15094706
    matti66
    Rate: 16
    I used to work in a power tool shop. Lubriten EPS-0 for grinders, Lubriten EPS-1 for hammers - such lubricants are also recommended by Celma, the manufacturer of power tools. More expensive professional GBH hammers and other tyranny by companies were lubricated with Bosch's dedicated grease (thick, sticky), or after agreement with the client (if he wanted cheaper) also EPS-1.
  • #14 15140866
    jaktom3
    For the bevel gear in the AEG WS2200-230 grinder, I used brushcutter gear grease. It works quietly and has not spilled grease from the gear onto the cover. It seems to work well for this purpose.
  • #15 16989659
    bolek9001
    Rate: 30
    I just see that colleagues use the same grease that I bought FAZI May EPS-0 EPS-1 and EP-2
  • Clean gearbox and replace thick grease with new lubricant
    #16 19407666
    pacp
    Hello everyone,
    I bought a used Milwaukee CAG125 grinder. After I bought it, I opened it to refresh it. I also opened the gearbox. The grinder was rather little used and the amount of grease placed there and its density because it is quite thick - thick enough that it does not participate in the lubrication of the gear.
    I assume the grease is original. I assume that I will not get a better one anywhere except the manufacturer.
    Now the question is what to do with it? I'm currently lubricating the gears and closing the case, but I think it's a temporary solution. Isn't it better to clean the gears and give something new and in what quantity?
    Lubrication for BOSCH Grinders: Gear Grease Recommendations, Viscosity, and Quantity Considerations Lubrication for BOSCH Grinders: Gear Grease Recommendations, Viscosity, and Quantity Considerations Lubrication for BOSCH Grinders: Gear Grease Recommendations, Viscosity, and Quantity Considerations
  • EPS 0 grease recommended for Bosch grinder gears
    #17 19408366
    bolek9001
    Rate: 30
    Hello - I used EPS0 for the gear and the gears are now not dry, and they were dry, but I heard from one of the experts that the gears are dry when cold, nothing bothers me because when the head warms up, the grease splashes - this kind of thick and it also makes sense because the head actually heats up, don't throw away the grease, possibly add Fazi EPS 0, it should be ok, after some time you can open it and check if it has weighed or if there are no lumps, EPS 0 is probably the rarest grease from Fazi , thinner probably would not make sense because it would be approaching the consistency of oil and could leak outside the housing - best regards
  • #18 19408629
    pacp
    I'll check it. I'll run it for a few minutes and let it warm up. We'll see what's inside. I'll put it down to cool so that it flows by gravity onto the gear.
    When it comes to adding to the existing one, the idea is rather out of the question because if I mix two with different parameters, it is not known what I will get and whether it will stick to my teeth at all..
The discussion centers on the challenges of selecting appropriate lubricants for BOSCH grinders, particularly regarding gear grease viscosity and quantity. Users express frustration with various lubricants, noting that many do not adequately adhere to gear teeth, leading to insufficient lubrication. Recommendations include using Lubriten EPX greases (grades 000, 00, 0, and 1) based on specific conditions, with EPS-1 being favored for its effectiveness in high-load applications. Users also mention alternative greases like Husqvarna gear grease and FAZI EPS-0 and EPS-1, which have shown better performance in maintaining lubrication. The importance of grease consistency and the impact of temperature on lubrication effectiveness are highlighted, with suggestions to avoid mixing different greases due to potential incompatibility.
