16v vs 8v Engines: Comparing Performance, Longevity, and Cost-Effectiveness in Gasoline Cars
Piotrek50501 116446 18
What is the difference between 8-valve and 16-valve gasoline engines, and which one is more durable and cheaper to run?
An 8V engine has 2 valves per cylinder, while a 16V engine has 4 valves per cylinder; in practice, 8V engines usually have stronger low-end pull, and 16V engines breathe better and pull harder from about 3,000–4,000 rpm upward [#10448958][#10451151][#10770007] Fuel consumption is not determined only by valve count: a 16V can use less if you drive it for the same performance, but if you use the extra power, it will usually burn more [#10451151] For durability and repair cost, the thread suggests the engine’s condition matters more than 8V vs 16V, though 8V is often described as simpler, cheaper to repair, and sometimes more tolerant of LPG [#10448995][#10449006][#10465662] Several replies also say a modern 16V is not automatically fragile, and with proper sequential LPG it can work well too [#10451151][#10463033] So there is no universal “better” choice: pick a well-kept engine, then choose 8V for simplicity and low-end use, or 16V for better performance and flexibility [#10451151][#10770007]
  • #1 10448837
    Piotrek50501
    Rate: 29
    I'm going to buy a gasoline car and everyone tells me an 8v engine is better than a 16v engine. What is the fundamental difference between these engines? which last longer and are cheaper to use ??
  • #2 10448958
    DUDAŚ
    Rate: 65
    16v you have 4 valves per cylinder (4 * 4 = 16) and 8v you have 2 valves per cylinder (4 * 2 = 8)
  • #3 10448975
    Piotrek50501
    Rate: 29
    well, but do these 16v break down more often or what if people do not want to buy them ??
  • #4 10448995
    kamil907
    Help: 66
    Rate: 160
    It depends on what engines you want, but usually 8-valve engines are more durable and less emergency.
  • #5 10449006
    robokop
    Help: 1763
    Rate: 6372
    16 valve engines are more strenuous and complex. More dynamics, unfortunately, comes with a lower durability and usually higher fuel consumption. If you are going to buy a gasoline car and set up LPG, look for the traditional 8 valve version.
  • #6 10449051
    DUDAŚ
    Rate: 65
    16v are more expensive to renovate, they burn more, they do not like gas very much, sequences must be assumed. But they have more power. And 8v burn less, no major problems with gas, cheaper renovation (e.g. when the timing belt breaks) burn less.
  • #7 10450555
    PCcepuk
    Level 19  
    Help: 18
    Rate: 118
    as in the topic of the number of valves in the engine, i.e. 16v, they will have 2x more than 8v
    to sum up: the more valves, the more aired / ventilated engine,
    that is, when driving dynamically, he will get more air-fuel mixture, which makes it more dynamic, more lively, stronger and flexible than, for example, 8v
    and in repair it means the same thing :)
  • #8 10450959
  • #9 10451008
  • #10 10451151
  • #11 10461177
    Piotrek50501
    Rate: 29
    I was thinking about the Opel Vectra B. What do you think about it ?? I would choose the engine 1.6 8v. Does anyone know if there is any other 8v petrol engine than 1.6 ??
  • #12 10461814
    kamil907
    Help: 66
    Rate: 160
    Generally, everything from VB would be ok if it wasn't for the weak cymbals. When buying, pay special attention to their condition. In addition, it is a car that is quite cheap to maintain and is not particularly emergency.
  • #13 10463033
  • #14 10463511
    michael1986
    Help: 14
    Rate: 70
    Here you have a nice description of what it is all about 16v engine . In my opinion, nowadays, with these fuel prices only 16v - you can safely assume gas for them, do not be afraid of that. 8v may make sense today, but only with turbo.
    Added after 4 [minutes]:
    it seems to have 75 hp - a light massacre in this rather heavy car. it seems that around 16 seconds from 100 km / h, do as you like but today the new compacts have 12 seconds by 100 km / h maximum - most have less. In 3 years, with such a car, you will be typical traffic jams in the city or on the uphill route. From year to year, the performance of cars is moving forward. It is different, some 2.0 8v - that would be enough but there is no such thing in Vectra B if I am not mistaken.
  • #15 10465662
    xyro
    Help: 47
    Rate: 238
    For such a vectra it is a minimum of 1.6 16v and optimally 1.8 16v or 2.0 16v.
    When it comes to durability, the 1.6 8v, despite its poor performance, is more durable and tolerates gas better. It is enough for a smooth ride. An alternative to the vectra is the astra f 1.6 8v which is less emergency, just as rotting and the estate version not so stupid. Unfortunately, these cars have their own years and everything can fit together.
  • #16 10468660
    michael1986
    Help: 14
    Rate: 70
    I doubt that a 1.6 8v that will still need high speed will be more durable than a 2.0 16v. A low-power engine for more than 1,200 kg will not be durable. The cost of repairing the 8v head and the cost of repairing the 16v are not that big of a gap. It would be worse in the case of v6.
    As for gas, a properly installed installation will be easier in a more powerful engine than in a weak engine that will still have a high load and speed.
  • #17 10469462
    Boohay22
    If it is to be a Vectra B, the best engine for the version before the lift will be: sedan 1.8 X18xe - 115 km or station wagon 2.0 X20xev - 136 km, both engines tolerate gas installations - sequential (almost identical combustion of petrol and gas). However, the 1.6 is too weak for the weight of the car 1,200 - 1,417 kg (station wagon). Fuel consumption is similar in both engines, depending on how often you step on the left pedal. As already noted, Ecoteki like oil, no matter if 1.6, 2.0, 2.5V6. In the case of compression-ignition engines, slow but economical and durable, the 1.7 TD (isuzu), or similarly economical, but the Opel 2.0 DTH design. Characteristic faults plague each of the engines that you can look for and read on the Internet.
  • #18 10470568
    xyro
    Help: 47
    Rate: 238
    The 1.6 is not crazy in such a vectra, but it is the second least fail-safe engine after the 2.0 8v. 1.6 16v is ok, much better pulls. If the pleasure of driving is only the eco kibel 2.0, but the costs can sometimes catch up. As durability and low maintenance cost is only 1.6 8v.
  • #19 10770007
    czmiel_t
    Rate: 8
    Taking into account the lack of variable valve timing in these cars, 8v will pull better from the bottom, but at 4k / rev it will get short of breath, 16v will be weaker at the bottom but from 3k / rev it only starts to pull and pulls hard almost to cut-off. Generally 8v for Sunday rides to church and for everyday use when you need some dynamics of 16v. There should be almost no difference in combustion. Toyota heads, which have been using FE 16v engines since the 1980s, are designed to burn a lean fuel mixture and, despite driving at higher revs, burn very little. I know it from the autopsy because I have been driving Japanese for several years and I have a comparison to other 8V engines. Fuel consumption is even lower and performance is much better.
The discussion centers on the comparison between 8-valve (8v) and 16-valve (16v) gasoline engines, focusing on their performance, longevity, and cost-effectiveness. The 16v engines feature four valves per cylinder, allowing for better airflow and higher power output, but they tend to have higher fuel consumption and maintenance costs. In contrast, 8v engines are generally more durable, less complex, and cheaper to repair, making them a preferred choice for those prioritizing reliability and lower operating costs. Users noted that while 16v engines offer better performance, especially in dynamic driving conditions, the 8v engines are often more suitable for everyday use and can tolerate gas installations better. Specific models discussed include the Opel Vectra B, with recommendations for the 1.6 8v and 1.6 16v engines based on their performance and maintenance characteristics.
