Opel Astra G (1998 - 2009) - Reviews, engines, engine versions
dsf11 8373 5
  • #1 17012676
    dsf11
    I'm going to buy an Opel Astra G used with medium mileage. Which engine version do you recommend and what faults I will be exposed to. I would like to know as much as possible about this car. Thanks in advance
  • #2 17012703
    robokop
    Help: 1763
    Rate: 6372
    The best of the petrol ones is the 8-valve 1.6 - they do the greatest mileage. DOHC engines are much less durable and oil-hungry. Ev. diesels.
  • #3 17018691
    kakibara
    Help: 202
    Rate: 1284
    It would be good if it was equipped with air-conditioning, look for velor seats because the original ones are mega stools, the rust eats the rear wheel arches, check when you buy whether it is leaking from the simering on the flywheel, - connecting the engine with the gearbox.
    1.7dti burn little, under LPG 1.6 75KM 1.6 84 KM, 1.8 125KM.
  • #4 17088063
    piochuxl
    Help: 14
    Rate: 19
    1.6 8 valve engine indestructible but a bit weak. 1.6 16v is more agile but causes more problems.
  • #5 18057462
    krysteeeky
    Level 4  
    Rate: 22
    I drive 2 years with 2.0dti 101 YDTH, I had absolutely no problems with the engine. When you change from 1.9 tdi you can feel the difference that some of the higher revolutions are collected. It takes a little more oil than usual, but these are old cars, so ... my mileage is 238,000. Overall, I consider it to be one of the best cars in the 3-5k price range, but maybe it's also a matter of taste.
  • #6 18057746
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    It's easy enough to buy, let it stay warm for 5 minutes at idle speed, then take a ride, spinning up to 5000 rpm in each gear, if it leaves a cloud of smoke, release the timing or other parts immediately.
    Also, notice that the engine and cooling controls are not lit because these are all hybrid engine computers.
    Klime would also fit and COOL.
