Opel Vivaro car - which engine to choose?
lukas92p 95007 10
Which diesel engine is the better choice for an Opel Vivaro delivery van: the 1.9-liter 101/102-hp engine or the 2.5-liter 145/150-hp engine?
Of the two engines, the 2.5-liter is generally recommended because it is considered a good, proven choice with no major engine problems reported in the thread [#15998138] The 1.9-liter can also be reliable if the oil is changed every 10,000–15,000 km rather than following excessively long manufacturer intervals [#16002614] However, one owner reported repeated gearbox, clutch, and other drivetrain problems with two 2.5-liter vehicles, while a 2.0-liter vehicle had no such issues apart from oil condition [#16051142] The 2.0-liter is another acceptable option, but its injectors are expensive and may seize in the cylinder head [#15998138] Therefore, choose the best-maintained individual van, with the 2.5-liter preferred over the 1.9-liter if their condition and service history are comparable.
  • #1 15988253
    lukas92p
    Rate: 27
    Hello, dad is planning to buy an Opel vivaro delivery van, but he doesn't know which engine is better 1.9 101 km or 2.5 150 km, we are talking about a diesel engine. I am asking for clarification and help
  • #2 15990198
    decybel91
    Help: 1024
    Rate: 4237
    The best choice is 2.0dci.
  • #3 15998138
    Kune
    Help: 23
    Rate: 213
    1.9 is an engine with incl. Lagoons. Read on.
    2.5 is a good choice, it drives in Master, no major problems. 2.0 is also very ok, only very expensive injectors, which can weld due to the poor structure of the casing.
  • #4 16002606
    lukas92p
    Rate: 27
    And it is said that 1.9 102km are good. only my father knows which one to choose because dad read the reviews 1 recommend 1.9 and the others 2.5 145 km
  • #5 16002614
    sebap
    Help: 538
    Rate: 1084
    1.9 with Renault are not bad in themselves if the oil changes normally, i.e. every 10-15 thousand, and does not believe in the manufacturer's nonsense with long oil intervals.
  • #6 16002619
    lukas92p
    Rate: 27
    apparently opel parts have cheaper parts than renault trafic and nissan primastar is that true. and others write that one of them does not remember which one has better cymbals
  • #7 16002812
    pp_pablo
    Help: 93
    Rate: 406
    Buddy, all these cars are produced at the Renault plant in France. I had Trafiki and Vivaro, there were Renault signs on all the parts I saw. What's the difference between them? Upholstery patterns, steering wheels, dummy, bumper (directions front but before lift) a different font on the dial of the counter and the fact that the "servo" indicator in Renault is replaced with "car key" in Opel. I have not noticed any other differences.
  • #8 16046439
    Gitner
    Help: 90
    Rate: 200
    I used Master from 2.5 and Traffic from 2.0 (both from '07) and with the Master there were problems with the hardware over and over again.
  • #9 16046684
    pp_pablo
    Help: 93
    Rate: 406
    You can expand a little, I mean those hardware issues. I saw a Mastery with a 2.5 engine with mileage of 600-700 thousand. In the fast courier PL-> west, they mostly use Master machines. Previously with 2.5 engines now 2.3.
  • #10 16051142
    Gitner
    Help: 90
    Rate: 200
    We had the most problems with the gearbox or the clutch, the drive in general, at least twice a year, it was the same in 2 copies, the electrics had the immo and the alarm. There were no problems at Traffic except for the oil condition. All domestic cars.
  • #11 16278267
    lukas92p
    Rate: 27
    I close the topic.
The discussion revolves around choosing the best diesel engine for the Opel Vivaro delivery van, specifically comparing the 1.9 (101 km) and 2.5 (150 km) engines. Participants suggest that the 2.5 engine is a reliable option, commonly used in the Master model, while the 1.9 engine, associated with Renault, is also considered decent if maintained properly with regular oil changes. Concerns are raised about the cost of parts and potential issues with injectors in the 2.0 engine variant. Overall, the consensus leans towards the 2.5 engine for better performance, although the 1.9 has its merits if well cared for. The discussion also highlights that the Vivaro shares many components with Renault models, indicating similarities in parts and maintenance considerations.
