Best Gasoline Engine Swap Options for Golf 2: Upgrade from 1.6 to Larger Alternatives
rapoch1996 21390 12
What larger gasoline engine can I swap into a Golf 2 instead of the 1.6?
The forum’s best practical recommendation is the 1.8T, while VR6 is also mentioned if you care more about sound than a 4-cylinder setup [#16516499] [#16518712] If you want to register the swap legally, one reply says you can only use an engine capacity that was offered in that model from the factory, i.e. up to 1.8 in the Golf 2, and that VR6 or R32 would require an expert opinion for registration [#16516499] A good approach is to buy a complete donor car and move over the engine, gearbox, and especially the brakes, rather than assembling the swap piece by piece [#16520640] One example suggested was an A3 1.8T 150 donor, bought as a whole car and transplanted into the Golf [#16522075]
  • #1 16515810
    rapoch1996
    I have a question about which engine can be placed in the Golf 2. Currently, I have 1.6, but I would like bigger, preferably gasoline, someone will recommend something? :D
  • #2 16515879
    Włodzimierz Wojtiuk
    Level 32  
    Help: 231
    Rate: 273
    For example, VR6
  • #3 16515890
    szymitsu21
    Help: 343
    Rate: 1300
    You can put a lot of engines.
    What do you want to achieve? 100? or 500hp?
  • #4 16515998
    Alfred_92
    Help: 148
    Rate: 706
    Regarding the rules, remember that you can only pack the engine with such a capacity as it was at the factory.
    Is this 1.6 falling or are you just lacking power?
  • #5 16516244
    Włodzimierz Wojtiuk
    Level 32  
    Help: 231
    Rate: 273
    You can ask for a link to the sources.
    Jackall
    Help: 77
    Rate: 396
    You can anyone with the capacity that was present in a given model, ie max 1.8 in golf 2. If you want VR6 or eg r32, you must have an expert opinion to register legally. Cool for swap are 1.8T ...
  • #7 16518712
    gigit
    Rate: 45
    I recommend the 1.8T very nice unit for lifting power, unless you like sound more than 4 cylinders then of course vr6
  • #8 16519300
    rapoch1996
    And whether it will be necessary to change the gearbox as I would assemble 1.8T.
  • #9 16520640
    gigit
    Rate: 45
    The engine, the chest, and above all the brakes are best to buy the whole thing, for example, oktavie or anglika, and translate peacefully
  • #10 16520666
    marek49ae
    Help: 57
    Rate: 254
    rapoch1996 wrote:
    and whether it will be necessary to change the gearbox as I would assemble 1.8T
    Is not it better to make a pair of stakes and buy something ready with 1.8T? A4, passat b5? I know such combined spacers, over-content over the form. Unless you are in love with your golf.
  • #11 16521134
    gigit
    Rate: 45
    I would definitely prefer to fly in two after fashion like a shepherd or 4, but that's my opinion ....
  • #12 16521968
    Jackall
    Help: 77
    Rate: 396
    Precisely, you have silent golf - watch the face of a karka in bmw, when you tour it ... Priceless :-)
  • #13 16522075
    andrzej20001
    Help: 1578
    Rate: 6669
    Entry only with A3 1.8t 150. Buy angola for 3tys. and you're driving with coke.
The discussion centers around engine swap options for the Volkswagen Golf 2, specifically upgrading from the stock 1.6L engine to larger gasoline alternatives. Participants suggest various engines, including the VR6 and 1.8T, noting that the maximum engine capacity permissible is 1.8L without requiring special registration. The 1.8T is highlighted as a favorable choice for power enhancement, while the VR6 is recommended for its distinctive sound. There are considerations regarding the necessity of changing the gearbox and the benefits of acquiring a complete engine setup from models like the Audi A4 or Passat B5 for a smoother swap process. Legal regulations and performance goals are also discussed, emphasizing the importance of expert advice for larger engine installations.
