Can an Exhausted Battery Cause Uneven Engine Operation and High Fuel Consumption?
diamentowy 57719 14
Can a weak or exhausted battery cause uneven engine operation and higher fuel consumption, especially during cold starts?
Yes, a weak or aged battery can cause strange behavior during starting, but once the engine is running the alternator should supply the car and the battery alone usually should not make the engine run badly. A voltage drop while cranking can make the controller lose settings or behave oddly, which may explain the rough running that disappears after charging or after disconnecting the battery [#10510762] [#10511132] [#10511336] Measure the voltage on the battery terminals 10–15 seconds after starting; if it is below 12 V, replace the battery [#10510871] One reply also notes that even a heavily discharged battery should not affect engine operation much, but a damaged or 5-year-old battery can have an effect [#10511169]
  • #1 10510708
    diamentowy
    Rate: 10
    Hello. I wanted to ask my colleagues to confirm my guess.
    As probably in most of these frosts some problems appeared.
    My looks like this. I start the car in the morning (it turns on poorly, the lights dim, but it catches quickly) after starting the drama. The car shakes, it does not accelerate from the exhaust, it smells of fuel. Combustion according to the load of 26l After heating, the situation improves. After a long ride, everything is ok.
    Of course, I was thinking of the probe, the stepper motor (the revolutions are waving) and the flow. And this morning the starter is not spinning the battery died. It went to charge after putting it in the car, it fired perfectly, it was great, all the symptoms disappeared, fuel consumption according to the 15.5 limit.
    My question for you. Is it possible that such flowers happen because of the exhausted battery?
    Basically my line of reasoning is this. Weak battery - the car fires but the power consumption of the battery when charging is so large that there is no electricity for the spark and all the receivers in the car, which makes the car work unevenly (not all cylinders) generally after charging the battery, the car runs perfectly. Somehow it fired but even the central locking did not close the door. 15 minutes with the ignition on, he was able to discharge the battery and the car did not want to start. ??
    I will add that the car is a bmw e32 m30b30 without gas (until frost -20 it was easy) the battery has 5l
    Thanks to everyone for the answer and best regards!
    Diamond
  • #2 10510762
    adamblonsky
    Help: 5
    Rate: 23
    The theme with the battery is a rather mischievous theme, the car after firing receives its voltage from the alternator and I assure you that it has enough electricity for everything that you must have frozen.
  • #3 10510839
    diamentowy
    Rate: 10
    in general, I noticed that everything subsided after connecting with his hand and the car was standing all day (where it had problems with uneven work after a whole day earlier). Probably the computer deleted errors, but do errors and ecu deletion have such an impact on the work? Generally, I was supposed to buy a new battery anyway, but I thought that I would do it by spring.
    To sum up, a weak battery has no effect on, for example, a weak spark?
  • #4 10510871
    vodiczka
    Help: 1185
    Rate: 4311
    adamblonsky wrote:
    The theme with the battery is a rather lame theme, the car gets its voltage from the alternator after starting
    Not entirely misleading because if the driver has too little voltage, miracles can happen. If the situation repeats, measure the voltage on the battery terminals 10-15 seconds after firing. at a voltage lower than 12 V, do not regret the PLN and replace the battery.
  • #5 10510885
    autoas
    Help: 571
    Rate: 3924
    And you know, buddy, that cars are serviced and serviced regularly, in accordance with the manufacturer's recommendations, regardless of whether something "screams" on the instrument panel or not
    This is the rule ...
    You make bizarre conclusions because you have no idea about diagnostics
    You have to use the workshop ...
  • #6 10510974
    diamentowy
    Rate: 10
    My grandmother has almost 20l and the oldest Bavarians know how much mileage, but it stays well :) . The problem is that in a 20-liter car, something breaks every now and then and you (grandmothers) need to repair it. The problem occurred a few days ago and I have been looking for the fault since then. I use the workshop when it is necessary and when I can fix something I fix it myself.
    But thanks for the answer, you contributed a lot to the topic, your help is invaluable.
    greets
    ps how do you know if and where he has his car serviced? You make brilliant conclusions, buddy, after reading a few sentences. Do you read all the posts in the head?
  • #7 10511046
    excray
    Help: 739
    Rate: 657
    I would try to check / replace the ignition coil / coils because something seems to me that there is simply no spark on one of the cylinders or it is too weak.
  • #8 10511063
    autoas
    Help: 571
    Rate: 3924
    If you make inferences about whether a charged battery pack helps, it's rather obvious
    And whether the car is old or not, you still need to be serviced ... or know each other well ... at least you have a book like "I fix it myself" or whatever ...
  • #9 10511109
    diamentowy
    Rate: 10
    the basic question is why after charging the battery the engine works perfectly? If the coil were damaged, the problem would not solve itself.
    I repeat the question. Can a discharged battery burden the alternator so much as to disrupt the operation of other devices?
    To my friend "autoas", if I knew each other well, I would not ask on the forum. I already had a few cars and did a lot of each one myself. The BMW m30b30 is new to me, so I ask. Secondly, there is no book "I repair myself" for my car, only an English service book. Third, you have my question above. (read carefully) I don't ask if charging the battery will help or not. The forum is probably for people who want to help, help and answer the questions asked. If you can help me listen, if you can't, don't answer.
  • #10 10511132
    tzok
    Help: 3176
    Rate: 6549
    Various "bushes" may appear in the controller's memory during the start-up on a falling battery. If there are checksums, it will catch it and reload it with default values, if not, it will apply it, if it lights up at all, it will take a while for him to "recover".
  • #11 10511143
    excray
    Help: 739
    Rate: 657
    I had a case where the coil worked properly in normal driving and it stopped working in the area of 2800-3200 rpm at high acceleration, so the assumption that "if something works sometimes it is definitely good" is wrong.
  • #12 10511164
    vodiczka
    Help: 1185
    Rate: 4311
    I repeat my answer, measure the voltage and you will know if it is weighing you down or not.
  • #13 10511169
    kortyleski
    Help: 957
    Rate: 3860
    Buddy, don't fight with the smarter ones or you'll lose. you ask Are you asking for help on the forum? Probably not ... Hey, you write that your errors have been deleted after disconnecting the batteries ... If they were deleted, they were some ?! And the errors are the orange indicator light on. And the orange indicator light says: "You can go, but fix it as soon as possible." Are you asking whether errors (service mode) can disrupt the engine's operation? It's like asking if a virus can harm a person ... And as for the question about the battery - even the most discharged battery should not affect the engine's operation. A damaged battery can have an impact. Five-year battery may have an effect. Even if part of the active mass lies at the bottom of the cell instead of on the plates, shorting the plates.
  • #14 10511306
    diamentowy
    Rate: 10
    I did not check the errors because I had to remove the battery, they probably were, since the check was burning.
    Someone who writes that he is smarter is rather conceited and therefore stupid.
    I asked if the old battery has an influence, a few of my colleagues replied matter-of-factly without unnecessary deliberation.
  • #15 10511336
    robokop
    Help: 1763
    Rate: 6372
    It has and there is not. Are you looking for an excuse to buy a new one? So the time to do so, 5 years is a lot for a battery. It is enough that the voltage dropped too much during the start-up and the engine controller could lose the settings. I close.
The discussion revolves around the impact of a weak or exhausted battery on engine performance, particularly in cold weather conditions. The original poster describes symptoms such as poor starting, engine shaking, and high fuel consumption, which improve after charging the battery. Responses highlight that a weak battery can lead to insufficient voltage, potentially causing erratic engine behavior and affecting the engine control unit (ECU). Suggestions include checking battery voltage, replacing the battery if it drops below 12V, and inspecting ignition coils for potential issues. The conversation emphasizes the importance of regular vehicle maintenance and diagnostics to address such problems effectively.
