AUDI A4 1.9 TDI 100HP uneven engine operation after firing on a cold engine
raffal12 18999 12
  • #1 16364478
    raffal12
    Hello, I have such a question, what could be the reason for uneven engine operation for a few seconds after starting a cold engine?
    On a warm engine the problem gives way to the candles I replaced but it did not help. The car was connected to a computer and it turned out that pump injection bumps are quite high 84,95,89,99 block 13 and 18 is ok. I am asking for advice.
  • #2 16364561
    patryk44gks
    Help: 11
    Rate: 74
    If you have such a high, maybe the pump seals or the pumps themselves for replacement or regeneration, a worn camshaft quite likely.
    Check the timing setting and check if the camshaft synchro in group 4 last window should be around 0 +/- 3
    Added after 5 [minutes]:
    And to start with, replace the filter, it can also be something with a vacuum pump
  • #3 16364572
    raffal12
    fuel dose corrections are good, this is block 13 and here is the problem with block 23, i.e. the solenoid valve opening time the norm is + -30 and for me as I wrote above ..
    I will add that under the power of nothing accelerated good combustion in the standard of 6-7 liters
    I forgot to add that all filters have just been replaced and of course oil
  • #4 16364582
    patryk44gks
    Help: 11
    Rate: 74
    In that case, replace the fuel filter first
    It turns out that they are already worn out and may have worn off, maybe try pouring some magical fuel into the fuel to clean the injection system.
  • #5 16364592
    raffal12
    I have replaced the fuel filter. Can there be gaskets on the pumps worn and these will be the symptoms ??
    patryk44gks
    Help: 11
    Rate: 74
    I would suggest replacing the pump o-rings and checking the camshaft right away.
    drop the cover and look at the roller and take out the injection plugs and plug in again and check the beam maybe something will help.
  • #7 16364622
    raffal12
    this car not long ago I bought and the previous owner reportedly changed timing before sale may be it
    good direction
  • #8 16364706
    patryk44gks
    Help: 11
    Rate: 74
    Check the timing setting and if you have access to the interface check also the timing cam synchronization
  • #9 16366109
    raffal12
    I checked block 4 this way: AUDI A4 1.9 TDI 100HP uneven engine operation after firing on a cold engine
    in the latter it fluctuates to 4.4 if such a norm is still acceptable or should it be corrected somehow ??? Possibly how to do it ??? I ask for advice
  • #10 16366443
    patryk44gks
    Help: 11
    Rate: 74
    Synchronization is out of the norm the manufacturer recommends around 0, and how to do it you will find on the internet after entering the synchronization camshaft 1.9 tdi
  • #11 16366449
    raffal12
    so that would be the main reason?
    patryk44gks
    Help: 11
    Rate: 74
    Not necessarily, but it's worth setting it up as it should, so you can exclude it if you have any idea, you'll set the angle in 20 minutes if you have an interface
  • #13 16373498
    raffal12
    The problem seems to be solved. The reason was incorrect camshaft synchronization was 3.9 to 4.4 I adjusted to 0.0 and now it fires nicely. Thanks for the advice.
✨ The discussion revolves around the issue of uneven engine operation in an Audi A4 1.9 TDI 100HP after starting a cold engine. The user reports that the problem persists for a few seconds post-start, despite replacing glow plugs and fuel filters. Diagnostic checks indicate high injection pump values, prompting suggestions to inspect and potentially replace pump seals, camshaft synchronization, and to check the timing settings. The user later confirms that adjusting the camshaft synchronization from 3.9 to 0.0 resolved the issue, leading to improved engine performance.
