No Water or Air When Bleeding Radiators—Possible Causes and Next Steps?
tomaszek187 25689 18
Why do some radiators have no air or water when I bleed them, and how can I fix the problem?
Your system most likely has too little water pressure, so top up the installation to about 1–1.5 bar and then bleed the radiators again [#10535145][#10534820][#10537792] If a radiator still gives no air or water, the vent hole may be clogged with mud or scale, and the vent should be cleaned or replaced [#10533383] To do that safely, close the radiator’s supply and return valves first, then unscrew the vent screw or remove the manual vent and clear the hole with wire [#10533383] When bleeding, only loosen the screw enough for air to escape, usually about half a turn; do not unscrew it fully because pressure can push it out and spray water [#10533383] If you cannot identify the fill valve or pressure gauge on the boiler, check the boiler manual or ask a service technician [#10537792][#10537703]
  • #1 10532965
    tomaszek187
    Hello . I have a problem with the radiators at home. Recently I found out that there is air in them and they do not heat properly, i.e. they are cold at the top, which makes it cool in the house. I found instructions on how to bleed them (I don't know anything about it at all). I bled them by unscrewing the screws with a flat screwdriver in the upper corner of the radiator. In two of them you could hear the air escaping and water started flowing and now they are fully heated. However, in the next two, after completely unscrewing the screws, neither air nor a drop of water came out, and after turning on the heating, you can clearly hear the sound of water flowing inside. What else can I do? Is it possible that the vent hole is clogged inside? It seems to me that no one in this apartment has vented the radiators for a long time. Thanks for the help in advance
  • #2 10533010
    zybie
    Level 30  
    Help: 133
    Rate: 754
    Maybe you just need to top up the water in the installation
  • #3 10533041
    duddy
    Help: 56
    Rate: 186
    Just like the thing with circulation pressures :) ??
    PITSTOP
    Piłkarska 21, Gorzów Wielkopolski, 66-400
  • #4 10533383
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    This hole in the vent may be muddy or clogged with scale. It is better not to try to open the vent under pressure, but if there is a valve on the return, you can turn off the supply and return of the given radiator and then, for example, completely unscrew the screw closing the vent (if it is a manual vent) and clean the hole with some wire, or simply replace the vent . In general, when bleeding air, you should only loosen the screws (unscrew them only enough to let the air escape, usually 1/2 turn is enough), and not unscrew them completely, because if they were already on the last fragments of the thread, the pressure could then push them out of the breather and it would geyser in the apartment.
  • #5 10533539
    tomaszek187
    While bleeding other radiators, I noticed that the more I unscrew the screw, the stronger the water flows, but I can't say it's a geyser, rather a dripping, but in two radiators, after completely unscrewing the screw, nothing comes out at all. Unfortunately, I don't know how to check the pressure or how to check whether you need to add water and how to add it. I have always had a coal stove at home, and now in the recently rented apartment we have gas heating and operating it is black magic to me.
  • #6 10533968
    duddy
    Help: 56
    Rate: 186
    Do you have your own cauldron? You should have a pressure gauge on it
    PITSTOP
  • #7 10534681
    tomaszek187
    there is a Junkers Bosch gas furnace in the basement
  • #8 10534820
  • #9 10535101
    tomaszek187
    this is what the stove looks like
  • #10 10535145
    duddy
    Help: 56
    Rate: 186
    Pump the pressure, it's almost 0
    There is no pressure at the top of these radiators, even though it shows a little, it is only a column of water.
    Allow approximately 1-1.5. Bleed and check again.
    PITSTOP
  • #11 10535459
    tomaszek187
    But how to do it, I have no idea
  • #12 10537365
    Bogdanbenek
    Help: 21
    Rate: 78
    Is there no valve in the furnace for filling the installation and the furnace?
  • #13 10537667
    tomaszek187
    There are several different valves under the stove, but it is not written what they are for and I don't want to spoil anything. I think the best solution will be to call a service technician. Unfortunately, it will probably cost a lot, but if it is to reduce gas bills and make it warmer, it has to be done.
  • #14 10537703
    pdzran
    Rate: 21
    Take a look at the stove's instructions.
    Mine clearly describes which one is used for what.
  • #15 10537726
    tomaszek187
    Unfortunately, I don't have the manual and there is no model on the stove to find instructions for it, so I think I'll leave it to the professionals
  • #16 10537792
    pdzran
    Rate: 21
    Hmm, I have valves under the stove: admitting water, closing the entrance, closing the outlet, gas.
    The gas valve is yellow.
    Blue water release.
    Closing the inlet and outlet are standard ball valves.
    Closing the entrance or exit when the stove is turned off should not spoil anything.
    Admitting water should be visible on the manometer (pressure increase), but it must be done slowly so as not to create air in the system (that's what I read in the manual of my furnace) and not to activate the safety valve (if the admission valve suddenly opens).
    Another issue is the pressure drop in the installation, it had to come from somewhere...
  • #17 10537981
  • #18 10541522
    Bogdanbenek
    Help: 21
    Rate: 78
    Show more photos of this stove - especially the bottom, where there is a water connection, drains to the radiators, water inlets, water outlets, etc. When water is admitted, the ball valve will have a blue color or a red handle, when you unscrew it, you should hear something and the pressure will increase on the manometer. It may be a valve with an inclined filter that protects the system against garbage in the water. The directions of water inlet and outlet may be marked on the furnace casing on the furnace parts. Ask the owner if you are renting an apartment from him, he should know, maybe there is this type of furnace on a frame or casing somewhere? .
  • #19 10553208
    tomaszek187
    Thank you to everyone who tried to help me solve my problem. Yesterday, a specialist from Junkers arrived, added water, performed maintenance on the furnace and now everything should be fine. Regards
The discussion revolves around a user's issue with radiators not heating properly due to trapped air. The user successfully bled some radiators but encountered problems with others where no air or water escaped. Suggestions included checking the water pressure in the heating system, ensuring proper bleeding techniques, and potentially cleaning or replacing clogged vent holes. The user mentioned having a Junkers Bosch gas furnace but lacked the manual for guidance. Ultimately, a specialist was called to add water and perform maintenance, resolving the heating issue.
