Port NT Driver Opening Error in Windows 7 x64 After Installing Pro 100 Program
mateo1b 21374 4
  • #1 10534388
    mateo1b
    Rate: 27
    I have Windows 7 x64 bit
    After installing the pro 100 program, such messages pop up:
    Error
    Error opening the "port_nt" driver!
    OKAY
    Error
    Driver opening error "port_ntüü
    OKAY
    Error
    Driver opening error "port_ntŘů
    OKAY
    Error
    Error opening the driver "port_ntLţ
    OKAY
    Error
    Driver opening error "port_ntpů
    OKAY
    Error
    Driver opening error "port_ntđ ÷
    OKAY
    Error
    Driver opening error "port_ntl ÷
    OKAY
    I care about this program very much and nowhere in Google I can find it
    I am asking for help, thank you in advance
  • #2 10538044
    mateo1b
    Rate: 27
    ok, I have run in compatibility mode with windows 95 versions of PRO100 4.16 on others also works
  • #3 10573945
    eurodom
    Hello, Could you describe how you started this program step by step.
  • #4 10574861
    mateo1b
    Rate: 27
    1. Install Pro100
    2. Copy CRACKA
    3.Put it in the folder with installation (Apparently) C: \ Program Files (x86) \ PRO100
    4. Get into the folder (drv NT) and install the wheel.
    To download here http://chomikuj.pl/agent1932/Programy+do+projektowania/Program+do+projektowania+mebli+i+aran*c5*bcacji+wn*c4*99trz/PRO100/drv+NT
    5. Try to run the program, if you get an error, please follow point 6
    6. After installation on the desktop, you have the PRO100 icon, right-click it and enter the properties,
    then the compliance tab and run in compatibility mode with Windows 98 / ME.
    Now there should be no problems.
  • #5 21820872
    jusufkapetan27
    >>10534388 Hello i had this same issue here i dont know if its helpful knowing how much time has passed but what fixed it for me is going into the properties of the program pro100 and running it in compactability mode windows 98/windows me .And thats what fixed it for me!
