Peugeot 308 1.6 VTI Engine Repair: Torque Specs for Piston Connecting Rod Bolts?
l.jola 16230 8
  • #1 16426037
    l.jola
    Rate: 17
    I'm completing engine repair of the Peugeot 308 1.6 VTI 120KM vehicle - engine designation EP6
    Unfortunately, in all databases I have, I do not have this year.
    I was looking on the Internet and I haven't found it either
    Does anyone know what torques to tighten the bolts on piston connecting rods? these screws are M7 so relatively delicate - I don't want to tear it off.
    thank you.
    zaxdamian
    Help: 14
    Rate: 67
    Hi
    If you have autodata bases, see the N13B16 and N15B16 engines from BMW. The crank system on this Paugeot is the same.
  • #3 16426137
    l.jola
    Rate: 17
    There are no these engines, the newest I see there is the N40, but I will search the internet after marking what you wrote to me, it's always a new lead. I searched all night without success. And the car needs to be slowly finished today ..
  • #4 16426143
    oktawian89
    Help: 52
    Rate: 444
    If you don't have such basic data, how do you check the fit of eg Panewek?
  • #5 16426185
    l.jola
    Rate: 17
    I do not check. I have all the pit from a different engine. only what I mentioned rings. Generally, these engines are one big poop.
  • #6 16426188
    oktawian89
    Help: 52
    Rate: 444
    how did you measure the cylinders? Oh, let alone the locks on the rings ...
  • #7 16426248
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    But what you only replace the shaft with the bushings, why do you even fumble in it ..... plasticine?
    I only had it and the repair costs after the valve timing were higher than the whole car worth.
  • #8 16426263
    zaxdamian
    Help: 14
    Rate: 67
    Connecting rod foot
    1.5Nm + 15Nm
    2. 180 degrees
    New screws
  • #9 16426361
    l.jola
    Rate: 17
    I just got back from a friendly workshop.
    5nm
    10nm
    130 degrees
    Autodata data
The discussion revolves around the torque specifications for the piston connecting rod bolts of the Peugeot 308 1.6 VTI engine (EP6). The original poster is seeking accurate torque values, as they have been unable to find this information in various databases. Responses suggest looking into similar BMW engine specifications (N13B16 and N15B16) for guidance. A specific torque value of 1.5Nm + 15Nm followed by 180 degrees for new screws is mentioned, while another response cites values of 5Nm, 10Nm, and 130 degrees from Autodata. The conversation highlights the challenges of sourcing reliable repair data for this engine model.
