Kormoran Tires: Michelin's Lower-Cost Option for Citroen Xsara 2 HDI (195/55/R15-85H) - Worth it?
wosiekpl 64674 14
Are Kormoran tires worth buying instead of Michelin tires for a Citroën Xsara 2 HDi in 195/55 R15 85H?
If the price gap is small, the thread leans toward buying a branded tire like Michelin rather than Kormoran, because users say you usually get better safety and longer life for only about 10–20 EUR more per tire [#11074146] At the same time, several people report good personal experiences with Kormoran and would recommend them as a budget option, so they are not considered a bad choice outright [#11073275][#11084841] One user also notes that Kormoran tires are produced in Serbia, not by Michelin as such [#11084906]
  • #1 11072732
    wosiekpl
    Rate: 35
    I warmly welcome
    Returning from work today, I had an unpleasant incident. While driving, a screw hit my right front wheel. When I was trying to pull it out, air started coming out of the tire so I didn't move anymore and drove slowly home. On the way, I stopped by the tire workshop to see the prices of new tires. In my car (Citroen xsara 2 hdi) I assume Michelin 195/55 / R15 -85H tires and new ones cost about E 120 per item. By the way, I saw that our Cormorants sell, so I'm curious what their opinions are. According to the seller, Kormorany is a Michelin product, only of lower quality. In the factory where he works, a lot of Tirovs come and quite a lot have either Kormorans or Stomils.
    Worth buying them? I know Michelin is better but I have to keep economy in mind. Finally a crisis in Spain :D
  • #2 11072744
    telbod
    Level 32  
    Help: 163
    Rate: 240
    Come to Poland, you will get them for PLN 250 with us.
  • #3 11072826
    markovip
    Help: 143
    Rate: 185
    And there is a crisis ...
    I do not know where my friend buys them, I have a promotion and the exchange for 195/65 / R15 Micheline Saver calls only 75 EUR.
    For this such a coupon. :)
    Regards
  • #4 11072866
    Karaczan
    Help: 869
    Rate: 1127
    And it is in Spain, despite the crisis, such prosperity prevails that they do not have vulcanization plants?
    What is the problem to patch the tire after the bolt? And definitely cheaper than a new tire, even with discounts ;)
    Unless it was some exceptionally huge screw.
  • #5 11072953
    wosiekpl
    Rate: 35
    The tire is already worn out, it has probably already 35,000 km and you can see that it is already slightly broken, so it's time to replace it (both at the front, one is from 2010 and the other from 2011, they put them on for me last year and I did not stop ) and it is not profitable to repair it. Every day I go back and forth to work for a total of 85 km, so the tires must be good because I drive once alone and once in five people.
    I want to exchange them in Toledo because I live here. I have not seen an offer on Michelin and it is not clear from your responses whether it is worth buying one or not?
    Regards
  • #6 11073275
    mjoy26
    You know what I used to have Kormoran tires in ibiz, they were 175/70 / R13, I used them for two summer seasons and I was very happy with them, so I personally recommend Kormoran tires
  • #7 11074146
    markovip
    Help: 143
    Rate: 185
    Last week I also punctured a tire - patching - 9 EUR.
    I founded the Michelin Saver at the end of 2007 and I still drive (~ 50km daily).
    However, I would recommend branded tires. The difference is often 10-20 EUR and you will drive longer and in SAFER! According to some internal Michelin tests, they clash more slowly with the rest, hence the name ...
  • #8 11082480
    PCcepuk
    Level 19  
    Help: 18
    Rate: 118
    it all depends on the quality and price, and the brand ???? it's not quite anymore
    I bought a front for my 4x4 Goodyear Wrangler HP All Weather in the spring - apparently the best !!!
    So far compared to the tires I had michelin synchro or KUMHO All let me say this: drama!
    Like branded, like the best ...
    the tires howl as if the car had no front bearings at the present temperature. + 30'c squeaks every turn, hard and uncomfortable (the car jumps like a wheelbarrow),
    not what better braking distance, but compared to the above - I will not buy them anymore,
    so if the difference is large then buy - at least the heart will not hurt
  • #9 11084841
    aliali
    Rate: 19
    It's worth it.
    Previously I had Cormorants and they were amazing. I let myself be persuaded, for some reason, to Fulda. They wore out quickly and keeping them on the road, especially when it is dry, is a tragedy.
  • #10 11084906
    romuald-f
    A/T specialist
    Help: 407
    Rate: 1551
    To be precise, Kormoran tires are produced in Serbia, and these are not "our" tires anymore.
  • #11 11085101
    fvnl
    Help: 6
    Rate: 22
    How much did you pay for a piece and in what size?
  • #12 11086075
    karola44-81
    Help: 69
    Rate: 242
    And do these Cormorants have a model name or a specific designation?
    As with Dębica, the winter frigo according to A very good tire for me, but I like the summer tire passionately and do not recommend it.
  • #13 11087604
    aliali
    Rate: 19
    It was the 2000 model. I don't know how much it cost because I bought it together with the car. Today the model is no longer produced. But a friend who has already torn off more than one set, including those from the higher shelves, also praised the Cormorants, although a different model. So I made a good impression of them.
  • #14 11087659
    fvnl
    Help: 6
    Rate: 22
    Good tires - they cost well ... What to hide. These Cormorants are cheap, they value ~ 350 for 18 inches, I prefer to buy Toyo stimulants or similar ...
  • #15 11095264
    wosiekpl
    Rate: 35
    Finally, I opted for tires Continental and such I installed. There are two Continental at the front and Michelin at the back. I used to have Pirelli but I wasn't too happy with them.
    Regards
    PS I think we can close this topic
The discussion revolves around the user's inquiry about Kormoran tires as a lower-cost alternative to Michelin tires for their Citroen Xsara 2 HDI. After experiencing a tire puncture, the user considers replacing their worn-out tires, which have been in use for approximately 35,000 km. Responses vary, with some users recommending Kormoran tires based on their positive experiences, while others suggest sticking with branded tires like Michelin for better safety and longevity. The conversation also touches on the economic aspect of tire purchasing in light of the ongoing crisis in Spain, with some users sharing prices and alternatives. Ultimately, the user decided to opt for Continental tires instead.
