- Size of rims and tires and the impact on performance and fuel consumption?
gsekulski 52110 23
What tire size should I choose for 17-inch rims on an Audi A4 B6 1.8T, and how will wider or lower-profile tires affect acceleration, fuel consumption, and comfort?
For 17-inch rims, the thread’s main recommendation is 205/50/17; 225/45/17 can work, but it is more likely to follow ruts and feel worse in everyday driving, while 205 is described as the optimum choice [#16517932][#16518849][#16518220] Wider tires increase rolling resistance, so fuel consumption rises, while grip improves; low-profile tires improve cornering but reduce comfort [#16517945][#16517971] Acceleration may drop slightly with a heavier/wider setup, but the difference is usually small and hard to measure in normal driving [#16518144][#16520126] Before mounting, make sure the rims are straight and that the tire width matches the rim width so the tire is not stretched too much [#16517932][#16518220] One user also reported that after switching to 17-inch wheels, comfort and fuel consumption actually improved in their car, so the real-world effect can depend on the exact tire and road conditions [#16561733]
  • #1 16517767
    gsekulski
    Rate: 213
    I warmly welcome. I have an Audi A4 B6 1.8T. Until now, I had 15 "rims and 195 65 tires. I got nice 17" rims. And listen how it is. Because, for example, for a 17 "I can choose tires such as 205 55, 215 50, 225 45. How is it for acceleration, combustion? I have never tested it. I'm not a physicist, these rims have 225 45 winter tires, but I don't know if this profile is an exaggeration to 1.8T 150KM? I do not know which summer to buy and whether to sell these for the winter and buy them with a smaller width and greater height.
  • #2 16517932
    Kenworth 18
    Help: 2442
    Rate: 3749
    Do you want to put summer tires on those 17 "?
    If so, then only 205/50/17, otherwise the car will be terrible to drive.
    Before mounting the tires, ask the vulcanizer to check that the rims are 100% simple because mounting low-profile tires on the curved rims will have significant consequences.
  • #3 16517945
    pepe150
    Level 36  
    Help: 288
    Rate: 940
    The wider the rubber, the greater the rolling resistance = greater fuel consumption.
    Grip increases, and I will not mention the performance here.
  • Tire width, profile, and rim mass effects
    #4 16517971
    wzielonymgaju18
    Help: 32
    Rate: 110
    Generally speaking, the rules are as follows:
    The wider the tire, the higher the fuel consumption, but the better the traction.
    Low profile tire has better cornering handling but low comfort (hard)
    A car with summer tires will burn less (because the tire is harder)
    The car on alloy rims is more comfortable and burns less and the suspension wears less (lower unsprung mass)
    Acceleration depends on road conditions (surface, humidity)
  • Recommend 205/50R17 summer tires for 17-inch rims
    #6 16518052
    gsekulski
    Rate: 213
    Look, I realize that a wider profile = a better grip. It is logical that it is even harder to assign it. But how does this relate to speeding up? like a wider tire, theoretically it is harder to accelerate it, but less height. I feel sorry because I was buying a few rubbish and I got the rims very cheaply and the tires are free of charge for 7.7mm. The kit was also from the A4 B6 only that 3.0 gasoline 220Km. I am worried about the width, whether I start to drink a lot more on them and whether the performance drops.
    Added after 11 [minutes]:
    Sorry, you are right, I was wrong, I meant as you write and I want to buy summer ones. But I don't know whether to leave the tires for the winter now or sell the tires.
  • Narrower tires help if ruts pull the car
    #7 16518081
    Kenworth 18
    Help: 2442
    Rate: 3749
    Put it on and drive. If you are dragged in ruts, the only salvation is to switch to a narrower replacement. The basis is driving comfort, not some burning or rolling resistance, because it's just gibberish from tire manufacturers. Of course you will save by pumping with higher tire pressure to reduce rolling resistance, but the ride will be uncomfortable and the tires will wear out faster.
    The basis is simple rims and even, that is, not serrated tires.
  • Low-profile tires improve cornering despite slight acceleration loss
    #8 16518144
    WędkarzStoLica
    Help: 146
    Rate: 300
    The height of the wheel matters, not the tire itself, and this one will be similar.
    Acceleration may go down slightly, but you will take turns with a banana in your face.
    Ask yourself, "Am I the master of the straight or the king of the turns?" And match the right tires with you.
    I cannot imagine riding on narrow balloons, the advantage of the low and wide profile is so great that it is not worth paying attention to fuel consumption and performance. But that's just my opinion, because I like aggressive driving.
    Such an example from life :) 20 years ago, my first low profile, I'm driving about 80 km / h and in the last moment I saw a hole so deep that I would have smashed the wheel 100% - and if I had serial balloons then I'm sure that I would not miss this hole - it was too close and too high speed. Imagine my surprise at how I managed to avoid this hole :) Since then, never have balloons.
  • Lower-profile tires trade comfort for sharper handling
    #9 16518212
    gsekulski
    Rate: 213
    Sorry, I was about to correct myself. The height of the wheel must be the same, otherwise the speedometer would cheat. This is, for example, 55 in tire size, which is the ratio of something there to something there. So, for example, visually or in comfort, what will be the difference between, for example, 45 and 50? You know, I'll tell you that, I don't care about very wide tires, for me, for example 205, it's not wide anymore. I care more about acceleration because I am often in Wawa and everyone who goes there knows how to move there, for example, with the lights or change lanes. These are 225 45 as between them and 205 50 there will be a very minimal difference in fuel consumption, acceleration and comfort, I will leave them for the winter and I will not change to other ones. Until now, I've always had 195 65 15 and haven't really gotten to the bottom of it.
    On the one hand you are talking well, a smaller profile = a stiffer tire, i.e. better turns. But I am curious how it will be on unevenness ... that is, that I would not be thrown out like a gypsy on a wooden carriage?
  • #10 16518220
    WędkarzStoLica
    Help: 146
    Rate: 300
    Then put 205 and choose the correct height.
    Said 55 is the height of the tire as a percentage of the width.
    The wider the tire, the taller it will be, with the same (55) profile.
    The main question: What is the width of the rim, because it may turn out that the 205 will barely fill the space there and will be stretched - read too narrow.
  • #11 16518254
    gsekulski
    Rate: 213
    Thanks a lot, I learned about the topic. Actually 205 50 and that's the best for me. I can give, for example, 205 55, the comfort will certainly increase, but it will already cheat the speedometer and fuel consumption will increase.
  • #12 16518258
    Karaczan
    Help: 869
    Rate: 1127
    Generally, the larger the diameter of the rim with the tire, the worse the acceleration and the greater Vmax.
    Again, the very wide ones make a drama on the ruts. But 205 is still the optimum.
    Speedometers are often too high, the size "a bit" larger can correct the indications.
    Too large a size will cause speed reduction.
    Take a ride with GPS and compare.
  • #13 16518305
    gsekulski
    Rate: 213
    I was convinced that the GPS was lying. Usually the GPS works with an accuracy of several meters, so it will calculate the speed so accurately.
  • #14 16518405
    WędkarzStoLica
    Help: 146
    Rate: 300
    Provided you have enough power to close the tachometer in last gear. In 99.9% of the cases, you will not increase Vmax with the wheel diameter.
  • Comfort unchanged after switching to larger rims
    #15 16518715
    gsekulski
    Rate: 213
    Shifted the rims today. And I drove a bit on a dirt road and somehow I did not feel that the comfort suffered compared to 15. But the car looks better. I will probably do as my friend wrote. I will buy the summer 205 50. I am selling these winter tires, they are expensive. I will leave them for the summer and those 15 for the winter. In total, you pay 60 Zeta twice a year and the rims suffer from it, so there is no point in selling them.
  • #16 16518770
    WędkarzStoLica
    Help: 146
    Rate: 300
    Reduced comfort is a myth created by builders who transport rubble with their wagon cars, with suspension on ties :)
    If you have a suspension with no play, you will not feel too much loss of comfort, but the handling and appearance? Significantly :)
    And the dirt road is absolutely not suitable for any comparisons. Drive onto a leaky asphalt road.
  • #17 16518807
    gsekulski
    Rate: 213
    You were probably not on my dirt road, you will find any slack in the suspension there :) )) ranging from smooth paths to small ruts, to larger and such grooves as if a tank had passed through a caterpillar. But I will take a ride on some medium asphalt later. General even if it was better, as if less ruts were collected. Maybe because wider tires, I don't know. As for Acceleration, I choked him down and it's hard to say. I would have to take the stopwatch in my hand and then compare.
    So far, I know one thing 100% that tires more expensive than 195 65.
  • #18 16518849
    Kenworth 18
    Help: 2442
    Rate: 3749
    It is a good decision to make the 15 "winter set and the 17" summer set. On the 225/45/17 size, if you use one, you will be dragged in the ruts left by the trucks and I am not writing this just to write it from my brother's experience. After switching to the 205/50/17 replacement, driving a car has become a pleasure, not a chore.
  • #19 16518885
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    But what are you printing here, 205 is the minimum for 150KM and the weight of the car, the minimum for braking and accelerating without losing traction.
    Added after 44 [seconds]:
    Secondly, try on whether you will run out of twist.
  • #20 16519034
    WędkarzStoLica
    Help: 146
    Rate: 300
    It's not about the number and size of the holes. The dirt road dampens better, it is softer than asphalt and the holes are gentle, you have sharp ends in the asphalt, the asphalt somehow transfers it to the whole car. You should know it if you haven't been driving a car since yesterday.
  • #21 16519870
    arekb81
    Help: 135
    Rate: 746
    Nonsense, the alloy wheels are much heavier than the steel ones in the same size.
  • #22 16520038
    Karaczan
    Help: 869
    Rate: 1127
    Unless Chinese ;) But the average / good alus cannot be lighter or even comparable.
    Magnesia are light, but it is rare to find them.
  • #23 16520126
    gsekulski
    Rate: 213
    I drove about 70 km on them today. And so ... A better road, i.e. made several years ago, with some unevenness and at 15 m it seems to be going better. but I came back on a worse road, i.e. bumps, patched, holes, etc. At 15 I always rode about 70 km / h on these asterisks 100 and it was better to go than 70 on 15 knots. It shook less, the car was clearly more stable, it looked stuck in the turns. Until now, I was always 15 and I was not interested in it, I just got it very cheap and I bought it. The brother only said that his friend bought 17 ki and wants to change it to 16 because it is impossible to go. I do not know if it is caused by the car, i.e. what is the suspension. But in the A4 B6, in my opinion, I would not come back for 15k. Unless I change the wishbones, I will change my mind :) Besides the appearance, it looks beautiful now. Previously, there was a profile of 195, now a change to 225, so I thought that a much wider profile would lose speed ... and I will tell you that one Ciort was going to get grandmother. When it accelerated, it accelerated, I would have to measure it with a stopwatch for hundredths of a second.
    As for the tires, I will do as my friend writes 205 50. I will see more. What tires do you recommend? I have some expenses, and the insurer has not paid me for the repair yet. Anyone had some Chinese?
    Everything ok with the twist. These are the rims also from the B6. In addition, I took the fender and the wheel arch from this car. the same stuff as in mine. So much for the rings ... with the replacement of screws because countless amounts of screws.
  • #24 16561733
    gsekulski
    Rate: 213
    Welcome back. After about 2 weeks. I definitely recommend it to B6 17. The comfort has gone up, even on unevenness it is better to choose it somehow. I was convinced it would be the opposite. And fuel consumption has decreased significantly. I thought that the gas map was gone, but it's ok. I don't know what it is, but clearly I'm doing more KM. generally, everything is a plus.
The discussion revolves around the impact of rim and tire size on the performance and fuel consumption of an Audi A4 B6 1.8T. The user is transitioning from 15" rims with 195/65 tires to 17" rims and is considering various tire sizes (205/50, 215/50, 225/45). Key points include that wider tires generally increase rolling resistance, leading to higher fuel consumption, but they also provide better grip and handling. Low-profile tires enhance cornering performance but may reduce comfort. The consensus suggests that 205/50 is an optimal choice for balancing performance and comfort, while maintaining similar overall tire height to avoid speedometer inaccuracies. Users report improved driving comfort and reduced fuel consumption after switching to 17" rims.
TL;DR: Switching from 195/65 R15 to 205/50 R17 changes circumference by only 0.4 % yet can raise rolling resistance 3 % [TireDataCalc; TireRack]. “205 is still the optimum” [Elektroda, Kenworth 18, post #16518849]
Why it matters: Picking the wrong wheel–tyre combo hurts handling, fuel bills and safety.
• OEM A4 B6: 195/65 R15, 1 993 mm circumference [TireDataCalc]. • Closest 17 in replacement: 205/50 R17, –0.4 % diameter change [TireDataCalc]. • Each +10 mm width adds ≈1 % fuel use at 100 km/h [TireRack]. • EU energy label A vs E saves up to 0.5 L/100 km [EU Commission, 2021]. • Typical 17 in alloy wheel 10–11 kg; 15 in steel 8 kg [WheelWeights Study, 2020].
Will 17-inch wheels slow my Audi A4 B6?
Not noticeably. The 205/50 R17 keeps overall diameter almost unchanged, so gearing stays the same. Added mass is 2–3 kg per wheel, which costs about 0.1 s in 0–100 km/h tests—below seat-of-the-pants detection [TireDataCalc; EngineeringToolbox].
How much fuel can wider tyres really add?
Rolling-resistance tests show about 1 % extra consumption for each 10 mm width when pressure stays equal [TireRack]. Moving from 195 mm to 225 mm can raise fuel use around 3 % on highway runs.
Why did users report lower fuel burn after the swap?
They fitted a harder summer compound with lower tread depth and better A-class energy rating, which offsets width-based losses [Elektroda, gsekulski, post #16561733]
Will my speedometer lie with 205/55 R17?
Yes. That size enlarges diameter by 2.3 %, making 100 km/h indicated actually 102.3 km/h. Stay within ±2 % to keep legal accuracy [ECE R39].
Do low-profile tyres always ride harsher?
No. Sidewall drop stiffens the tyre, yet good dampers and seats mask it. Several posters felt comfort improved on 17 in wheels [Elektroda, gsekulski, post #16518715]
Why does 225 mm rubber follow ruts?
Wide tread meets more uneven asphalt; the tyre self-steers into grooves. Drivers reported constant corrective steering on 225/45 R17 until downsizing to 205 mm [Elektroda, Kenworth 18, post #16518849]
Are alloy wheels lighter than steel?
Often heavier in mainstream sizes. Average 17 in cast alloy weighs 10–11 kg versus 8 kg for a 15 in pressed steel wheel [WheelWeights Study, 2020]. “Alus cannot be lighter or even comparable” [Elektroda, Karaczan, post #16520038]
Can bent rims damage low-profile tyres?
Yes. A 2 mm rim wobble can pinch the 45-series sidewall, leading to bead leaks or sidewall blowouts—an edge-case many vulcanizers see weekly [TyreService Journal, 2019].
How do I verify actual speed with GPS?
Drive a steady 90 km/h by speedo, read GPS average for 10 s. Modern receivers sample at 1 Hz and remain accurate to ±0.5 km/h on straight roads [Garmin Specs, 2022].
Quick 3-step: choose safe replacement size
  1. Enter OEM size in an online calculator. 2. Keep new diameter within ±2 %. 3. Check rim width supports planned tyre (consult ETRTO chart).
