Replacing Radiator Valve: Proper Valve Opening & Drainage for Cast Iron Fin Radiators
W.ojciec.h 36942 14
How far should I open a radiator shut-off valve so the radiator heats properly without risking leakage or the valve plug being pushed out?
Open the valve fully only until the plug/disc is level with the valve body; do not unscrew it past that point, because further unscrewing can let the plug fall out and water escape from the central-heating system [#11120651] There is no fixed number of turns like a half-turn or one turn; the practical rule is to turn it evenly until you reach the stop/resistance, then leave it there [#11119092][#11120643] If the cap has a gasket, tighten the cap securely after setting the valve [#11122776][#11118718] One reply also notes that this type of valve is best treated as a service/emergency shut-off, normally left open and only used to isolate the radiator when needed [#11119047]
  • #1 11118831
    W.ojciec.h
    Taking advantage of the opportunity that the CO pipes are being replaced at the estate, I asked the handymen from the cooperative to replace the valve on the radiator, which was leaking water after unscrewing the nut (defective gasket). It is more or less a valve on the drain as in the picture found:
    http://t2.gstatic.com/images?q=tbn:ANd9GcTFke...G2nUzOJYLmCxDSKqC9mJ-co1voS1xQDI1AkuFAegeEWPA
    The valve was replaced, but it was installed in my absence from the apartment. Unfortunately, it was mounted as I bought, and therefore completely crazy. Of course, I have an allen key, but the question is: how much should the valve be released so that the radiator heats up properly and has adequate drainage? (it is a typical cast iron fin radiator) ...
    Is there a rule as to how far to open the valve? For example, is it a full turn of the hexagon or a half turn? Maybe these are stupid questions, but I am a complete layman, and I would like there to be no trouble with the radiator later in the heating season. I think that you cannot let the valve go just like that, by trial and error, during the heating season, because then the pressure can squeeze it out completely and flood the apartment, and screwing it in under pressure is almost impossible.
    I will be grateful for any tips and help. Greetings.
    Please post photos in accordance with the rules and regulations of the forum.
    Please correct.
    mod.serwisant73
  • #2 11119047
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    It's best to unscrew this valve completely. Then there will be a circulation without any resistance. This valve can be adjusted during the heating season (the pressure will not blow it), but not to do it unnecessarily (if there is such a valve at all, it should be treated as an emergency or service valve, used to cut off the radiator from the system in the event of e.g. leakage of the valve itself). radiator). Of course, disconnecting the radiator from the installation requires closing both the supply valve (usually thermostatic) and the return valve.
  • #3 11119092
    korrus666
    Level 40  
    Help: 584
    Rate: 476
    You keep turning until you feel resistance and that's it.
  • #4 11119239
    W.ojciec.h
    Thanks for the answers.
    Will unscrewing the valve to the maximum with an Allen key result in a stream of water from the valve during the heating period, after unscrewing the cap?
    To what extent does insufficient valve release affect the radiator heating efficiency?
    Zbigniew Rusek wrote:
    This valve can be adjusted during the heating season (the pressure will not blow it), but not to do it unnecessarily.
    How does it not crash? I heard that there is such a danger that by letting go of it slowly at some point the water will push it out and I won't be able to screw it back in.
  • #5 11119276
    cirrostrato
    Help: 286
    Rate: 959
    Nothing will knock it out, unscrew it to the maximum, then tighten the cap covering the valve and close the topic.
  • #6 11120643
    korrus666
    Level 40  
    Help: 584
    Rate: 476
    This cannot be wrought out. At least my valve can't be. There is resistance and it doesn't go any further.
    torus
    Help: 11
    Rate: 20
    I do not agree with my colleagues. The disc of the shut-off valve should not be unscrewed more than equal to the body. Further screwing out will cause the plug to fall out of the body and the water to flow out of the central heating
  • #9 11123234
    W.ojciec.h
    Thanks for all the answers. It turns out that the answer was not so clear-cut. I unscrewed the valve with the hexagon socket almost to the level of the nut, tightened the nut with the gasket tightly. Now you just have to remember to keep an eye on the valve when the radiators are going to be filled in the fall.
  • #10 12718692
    pooolek
    And I have a question -> Is it necessary to unscrew the valve all the way? I have a problem, because when they renovated my bathroom and installed a ribbed wall radiator, they put the gasket incorrectly in this emergency valve on the drain and when in the summer I unscrewed the cap, water dripped slightly and you could see the gasket (I turned the drain with the hexagon and I did the same with the tide because I have a heater and I did not want to heat the block in the summer). However, yesterday they posted a note on the block saying that they are filling the radiators with water tomorrow. And now I unscrewed this valve, but not quite so, there were still 1-2 millimeters left to align with the end of the thread on the nut. I did it because the water was running a little harder, 2 towels got wet. So what do you advise? It can stay like this ? When I closed the cap, nothing drips. I forgot to do it before. It turns out that this is how the year has been.
  • #11 12718718
  • #12 15289266
    Jericho24
    Rate: 162
    I will dig it out.
    I once heard that in order to save on heating costs, the drain valve on the radiator should be turned so that the flow is minimal, i.e. that 2/3 of the radiator is hot, and in the lower part it is already lukewarm, which means that most of the heat supplied has been given off.
    In my block of flats, each flat has a heat exchanger installed, which heats the water in the tap and in the radiators (controlled separately from the heating computer).
    Does the above advice apply?
  • #13 15289381
    gersik
    Help: 164
    Rate: 639
    You need to insulate the house well. It must get as much heat as it needs to warm up and no closing of the valve will help here. And in solid fuel boilers it will rather hurt because the return temperature will be too low. This is not a condensing boiler.
  • #14 15292562
    Jericho24
    Rate: 162
    I do not have a house, but an apartment in a block of flats with a heat exchanger as central heating, so your answer does not help me.
  • #15 18502369
The discussion revolves around the proper handling of a radiator drain valve during maintenance, particularly for cast iron fin radiators. Users share their experiences and advice on how to adjust the valve for optimal heating and drainage. Key points include the recommendation to unscrew the valve completely for maximum circulation, while cautioning against over-unscrewing, which could lead to water leakage. The importance of ensuring the valve is properly sealed after adjustment is emphasized, along with the need to monitor the valve during the heating season. Some users mention specific brands like Calaff and Danfoss in relation to valve issues, while others discuss the implications of valve adjustments on heating efficiency.
