Satel Integra 128 WRL: No DTR Signal on RS Port with ETHM-1 Module
plociarz 36441 6
  • #1 11174939
    plociarz
    Help: 10
    Hello, I have a Satel integra 128 WRL control panel. After connecting the ethm-1 module to the control panel with the rj/pin5 cable, I keep getting a message as above. I can normally connect dloadx to the control panel via rs232, but I can't connect via ethm-1. Options marked in tel. options:
    -remote modem
    -external modem
    -ISDN/GSM/ETHM modem
    and still nothing, has anyone experienced this problem? Satel claims that the cable connecting the PBX to the ethm is faulty, so I bought a new one and still the same problem, also it is not the cable's fault. Thank you very much for any help.
    Notice .
    Read also:
    Satel Integra - system configuration - selected issues selected issues Selected most interesting topics concerning the configuration of the Satel Integra system
    Outputs (programmable and non-programmable) of control panels
    How the control panel alarm outputs work
    Connecting any detector to any control panel - a tutorial
    How to connect a siren to any control panel - tutorial
    Types of Integra control panel outputs that we use for home "automation"
    Cool furnace. - integration with alarm (e.g. Satel Integra)
    ETHM 1 Plus/ Integra Control. Selected issues.
    We invite you to learn more about the read other guides, featured topics, articles, in the field of security systems such as intercoms, gate and barrier automation, alarm systems, cameras, access control:
    Tips on. Security Systems
    If you do not find an answer to your question in the above topics, please visit the forum:
    Security systems
    We also encourage you to visit the General Guides section, where you will find material from the other sections of the forum, including for those starting out in electronics:
    General Guides
  • #2 11176479
    kropka73
    Rate: 10
    The reason for such a message may be a damaged RS port in the ETHM-1 module. In my case, an "expert" connected the RS port of the ETHM-1 with the SW port of the VOICE Synthezer, which resulted in damage to the ETHM module. After replacing the module with a new one and connecting it with the RS port of the control panel (RJ connector), the communication runs correctly. The faulty module is also faulty when connected to another PBX (no DTR signal on the RS port). So try replacing the ETHM module with a new one and everything should work fine.
  • #3 11176689
    plociarz
    Help: 10
    Mate, I think we must have been working with the same specialist, because he connected me in the same way, but the rs port is theoretically working on the ethm-1 because it updates the software without any problem.
  • #4 11176789
    fred4u
    Help: 94
    Rate: 198
    plociarz wrote:
    Kolego I think we must have the same professional because he wired me the same way but the rs port is theoretically working on ethm-1 because it updates the software without any problem
    The software update may not use flow control, thus the lack of DTR may not interfere with this.
    Of course this doesn't mean the DTR is messed up, it's best to just check with a meter what it's putting out there (it should be -12v or +12v depending on the condition).
    M.
  • #5 11179637
    kropka73
    Rate: 10
    On my ETHM module everything works except communication over RS. You can log in to the module via Guarda and view the PBX, but you cannot via DloadX from the LAN. Only the control panel lets you know that there is no signal. I will try to connect it under the meters and see where the fault is. Maybe it is possible to fool the control panel by simulating the presence of a DTR signal.
  • #6 11432975
    xckrzysin
    Rate: 28
    Your control panel and ETHM module are operational. The cable which is used to update the software in the ETHM module is not suitable for connection to the control panel (although it has identical plugs). The cable for connection to the control panel must be interleaved on pins 2,3 and 4,5. In addition, from newer software versions we do not enable the option: "Reply - modem" only "Reply ETHM/GSM".
  • #7 13532662
    synology1
    Help: 10
    Rate: 146
    xckrzysin I confirm what the colleague above wrote,today at me the same message connectivity with Mobile KPD and connection with Dloadem X is missing at me it turned out that after replacing the plug for RS everything returned to normal.
The discussion revolves around the issue of a Satel Integra 128 WRL control panel not receiving a DTR signal on the RS port when connected to an ETHM-1 module. Users report that despite successful connections via RS232, the ETHM-1 fails to establish communication. Possible causes include a damaged RS port on the ETHM-1 module, incorrect cabling, or software settings. Suggestions include checking the DTR signal with a meter, ensuring the correct cable configuration, and verifying software options. Some users have resolved similar issues by replacing faulty cables or modules.
