Is the STR-421 signal secure when transmitted over Category 5e UTP twisted-pair cable?
tomek_k123 3159 5
  • #1 11228656
    tomek_k123
    I’d like to ask for your opinion on whether it would be safe to send a control signal (approx. 2 s) via a Cat 5e UTP twisted-pair cable: from the doorbell switch to the STR-421 (two-button: http://www.fif.com.pl/pub/File/download/INSTR...ers/FF%20STR-421%20230V%20A080526%20pdf.pdf)?
    I’m thinking of shorting it to earth (<1mA), twisted pair cable length: approx. 5 mb.
  • #2 11228856
  • #3 11230961
    tomek_k123
    The roller shutter motors (Somfy) are 230V, the STR-421 controllers are 230V, and within 5 metres of the distribution board there are junction boxes with twisted-pair cable for controlling the blinds; the plan to use RM85 relays has changed – there isn’t enough space in the cabinet for the RM85s now...
    P.S. Perhaps twisting two pairs of twisted-pair cable would ensure it can safely carry a transient current of max. 170V | 1mA? Does anyone have experience with this – is anyone using such a solution?
  • #4 11231066
    pm.001
    Electrician specialist
    Help: 81
    Rate: 49
    tomek_k123 wrote:
    P.S. Perhaps twisting two pairs of twisted-pair cable would ensure it’s safe to run a brief current of up to 170V | 1mA through it? Perhaps someone has experience with this – is anyone using such a solution?
    No one in their right mind would use such a solution, as it’s not just about the current-carrying capacity here, but also the voltage for which the cable is designed (insulation resistance). I’ve already asked a rhetorical question on a similar matter before. Do you think the wide variety of cables available on the market is driven by manufacturers’ desire for profit?
    Best regards
    pm001
  • #5 11232622
    tomek_k123
    Could you please advise which are the narrowest miniature relays for a DIN rail mount – with a 12V coil – that can switch a current of 1mA and a voltage of 230V?
  • #6 20059369
    krzys-iek
    Help: 9
    Rate: 83
    This control system has been working for 10 years now, and nothing’s gone wrong. There are fuses just in case...
    QUESTION: Some of them have already failed; the thermal imaging camera shows that they’re warm (the ones that have failed) – their temperature is clearly higher than that of the neighbouring ones. Has anyone taken apart and repaired an F&F STR-421?
