Audi A6 C4 Avant: Bose Subwoofer Pinout, Connecting to Delta CC Radio & Rear Speakers
kosta1984 17166 3
  • #1 11262529
    kosta1984
    I need a scheme or description of pins in the audi bose subwoofer plugs. For the original delta cc radio, I want to connect the original subwoofer with the amplifier. The subwoofer has two cubes. Red for communication with the radio (4 pins), the other for the rear speakers and power supply (6 pins).
    The rear speakers are in the active system, each has its own amplifier. I will not. I want only the subwoofer to work.
  • #2 11262712
    Ireneo
    Help: 747
    Rate: 2469
    Without a schematic you have power, control and signal from two channels and output to the rear speakers. Nothing complicated.
  • #3 11262820
    kosta1984
    Yeah. Only what?
    subwoofer cables:
    Outputs delta cc:
    3.1.16. Publishing entries containing a question / problem notification for which a correct answer has already been given. Before publishing the entry, the User is obliged to check by means of the Forum search engine whether the given problem has already been addressed.
  • #4 11264660
    kosta1984
    No one has access to such a scheme? Maybe some of you have this a6 model with a barefoot system. Picture of the plug on the radio (yellow mini iso) and subwoofer plug will suffice :)
