How Many kW for 60m2 Apartment With Induction Hob, 3-Phase, Multiple Appliances?
kielbu 51802 12
How much electrical power should I apply for when renovating a 60 m² apartment with a 3-phase installation, induction hob, and several household appliances?
About 12 kW is enough for this apartment; if you want more comfort and less worry about simultaneous use of appliances, 15 kW is the safer choice [#9633408][#9633426] One reply suggests 20A pre-meter inserts for about 12 kW, while 25A inserts give about 15 kW [#9633426] The practical advice is to add up the rated power of all devices, including the induction hob and future appliances, and then choose power based on whether you want to avoid overloads or accept that some devices will not run at the same time [#9633572] It was also noted that with 3-phase supply you should plan the installation with reserve, for example 10 mm² or even 16 mm² cable, rather than undersizing it [#9662164] Before applying to the utility company, get written consent from the building administrator and then submit the request to the utility, preferably with a qualified electrician involved [#9662391][#9661727]
  • #1 9633376
    kielbu
    Rate: 22
    Hello everyone.
    I have just become the owner of an apartment with an area of 60m2. The apartment is undergoing major renovation, currently I do not have electricity in it because the meter has been removed after the eviction of the previous owner. There will be 2 TVs, 2 computers, fridge, washing machine, dishwasher, oven, electric kettle in the apartment. I am also planning to buy an induction hob. The standard power that is supplied to the apartments in this block is 5kW single-phase. Taking advantage of the renovation, I will replace the installation with a 3-phase one, but I do not know what power to write about, how many kW is enough for me, I ask because each 1kW costs about PLN 180. Please reply urgently.
    Best regards and thank you in advance to everyone for your advice.
  • #2 9633408
    maystero
    Help: 58
    Rate: 204
    This chart should bring some "light" to the problem.
    I think 12kW is enough for you. Well, unless you intend to connect 3-phase motors ...
  • #3 9633426
    czesiu
    Help: 454
    Rate: 840
    It would be appropriate to have 25A inserts on the pre-meter protection, it gives a power of about 15kW.
    The more economical version is 20A inserts and a power of 12kW.
    Take a look at the example table in this post:
    https://www.elektroda.pl/rtvforum/topic1785081.html
  • #4 9633438
    kielbu
    Rate: 22
    Hmmm I was thinking about 7-8 kW
  • #5 9633443
  • #6 9633484
    kielbu
    Rate: 22
    Gentlemen, if I let go of the topic of the induction hob, what power is enough for me, maybe then it is worth staying with a single-phase heater? In general, I got a little lost in all of this (a layman if you want electricity)!
  • #7 9633572
    zbich70
    Help: 1171
    Rate: 6666
    Buddy, there is nothing to get lost. Each device has a specific rated power and usually gets such power. First, add it up (also the future ones not yet purchased) and see how much it will be. If you want the 'comfort' version, take that power and you don't have to worry about a possible back-out. However, in the 'economic' version, take into account that you will not be able to simultaneously use some power-hungry devices, which can also be troublesome (especially women like to turn on everything at once ;-) )
  • #8 9634235
  • #9 9661651
    kielbu
    Rate: 22
    So I can raise the power to 7.3 kW from the current 5.3 kW, then I will have 32A and the board will work on one phase
  • #10 9661727
    elpapiotr
    Electrician specialist
    Help: 1015
    Rate: 3530
    Provided that ZE gives you such a power allocation.
  • #11 9662015
    kielbu
    Rate: 22
    I have to apply for conditions.
  • #12 9662164
    pavulon
    Help: 34
    Rate: 73
    Buddy, the power you want, you will take it, but remember that it should be 3f and that the power cord has a lot of reserve, e.g. 10mm ^ or even 16mm ^.
    You will not overpay much and you will certainly save yourself "spitting in the chin" in a few years.
  • #13 9662391
    zbich70
    Help: 1171
    Rate: 6666
    Yes. Only first to the building administrator for (written) consent, and then to the ZE. If you didn't know ;-)
    And in general, if you are a layman in the field of electrics, you will not forget to hire a professional. So it's best you do it right now.
The discussion revolves around determining the appropriate electrical power allocation for a newly renovated 60m2 apartment. The user plans to install multiple appliances, including TVs, computers, a fridge, washing machine, dishwasher, oven, electric kettle, and an induction hob. The standard power supply in the building is 5kW single-phase, but the user is considering upgrading to a 3-phase system. Responses suggest that a power allocation of 12kW is advisable for comfort, allowing for simultaneous use of multiple devices without overload. Recommendations include using 20A or 25A inserts for pre-meter protection, which correspond to 12kW and 15kW, respectively. The importance of hiring a professional for installation and obtaining necessary permissions from the building administrator and energy provider is also emphasized.
