Central heating riser vent – can an unscrewed cap cause flooding?
prezesonline 70422 15
Can an unscrewed cap on an automatic central-heating air vent cause flooding when the heating is turned on, and should I close it myself?
Yes—if the air vent is left unscrewed/open and starts leaking, it can slowly flood the apartment below when the system is pressurized or the heating is started [#11292783] Automatic air vents are meant to work continuously and normally should not leak water; their job is to let air out of the installation [#11293506][#11292733] If water is coming out even with the cap loosened, the vent is likely faulty and should be replaced [#12788230][#12788288] For protection, forum users suggested fitting a ball shutoff valve under the vent or relying on the foot valve below it so the vent can be removed without draining the whole riser [#11292795][#12788400][#12789359]
  • #1 11292712
    prezesonline
    Rate: 19
    A few days ago, the cooperative replaced the central heating installation - new pipes and radiators. In the apartment on the top floor, the pipes going over the ceiling to the condenser on the cage have been removed, and in return I have 3 unsightly vents in the premises.
    At the top they have something like this:
    except that for me, this tiny cap at the top is red.
    In one of the rooms it is quite unscrewed, in another it is twisted.
    Is it possible that the team has not tightened something and there is a risk of flooding when they start heating for the first time in the season in my absence?
    A short leak test was carried out, but the gentlemen ran so quickly, then others fell in and twisted something, etc. near the radiators and plumb, that I wonder if they tightened something. Can I just close these tapes myself? Then, however, they will not jump and release air, as it was during the test.
  • #2 11292733
    Inicjusz
    Rate: 22
    Unscrewed caps on the vents allow for venting the installation.
    If they stopped snorting, they should be curled up.
    However, it is worth unscrewing them from time to time. This allows for the discharge of air from the installation if it still accumulates in the body of the vent.
    A vented installation heats better.
  • #3 11292740
    prezesonline
    Rate: 19
    And if someone forgets to turn them off, water can flow through them?
  • #4 11292783
    dzarek70
    Rate: 9
    Yes, it can flood the neighbors downstairs, they installed it for me too, and when the heating plant released the heating without warning the residents, it flooded, I personally watered my neighbor, it doesn't go very fast, but after a few hours there is a bit of it and it leaks through the radiator in the ceiling.
  • #5 11292795
    wawrzeczko_t
    Heating systems specialist
    Help: 199
    Rate: 1033
    I suggest installing a cut-off valve (ball) between the pipe (riser) and the vent.
  • #6 11293506
    Inicjusz
    Rate: 22
    It is assumed that the vent should work continuously.
    Unfortunately, the efficiency of operation varies.
    There was already such a topic on the forum The reliability of the automatic air vent .
    How it works was also discussed Automatic air vent .
    As a general rule, the automatic air vent should not leak water, and its operation is shown in the video
    http://www.youtube.com/watch?v=OdH2DjXnYh8&feature=related.
    Unfortunately, there is a construction difference, but the principle is similar.
  • #7 12788230
    mikolaj86krot
    Rate: 12
    If this red cap is turned off, the o-ring seems to be ok and the water is leaking out anyway, does this vent need to be replaced?
  • #8 12788288
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    Probably yes.
  • #9 12788333
    mikolaj86krot
    Rate: 12
    what is this breather professionally called? how much it costs?
    automatic air vent?
    can it be replaced if the heating season has already started without draining the water?
    it is located on the last floor in the residential side, the entire riser is vented.
  • #10 12788400
    William Bonawentura
    Help: 190
    Rate: 619
    Usually complete with the valve is the so-called foot valve. So below what you can see in the photo there is still a hexagonal element and only the thread of the installation screwed into it. If this is the case, you can unscrew the valve.
  • #11 12788414
    mikolaj86krot
    Rate: 12
    1.that is, even though the water is now coming out (in small amounts) ... when unscrewing the vent, this foot valve cuts off the water supply and you can easily screw a new one ...?
    2. is there any chance that after removing this valve it can be resuscitated somehow and it will work again? (clean, blow)?
  • #12 12789359
    serwisant73
    Help: 188
    Rate: 1260
    It should be like that. This is what the so-called footer.
    Rather faint. Anyway, the cost of a new one is low, so why?
  • #13 12790426
    mikolaj86krot
    Rate: 12
    thank you all for your help.
  • #14 12792418
    andrzej lukaszewicz
    Help: 626
    Rate: 2121
    Buy a decent branded, e.g. afriso for PLN 20-25, and not a Chinese for PLN 10-15, because the cheap ones are leaking from new products ...
  • #15 20406426
    Aldik
    Rate: 57
    I have loose nuts and so it's been a year :)
    My question is can they be covered? build over? Can they break down and start pouring water, which I will not see because they will be covered!?
  • #16 21065757
    gamingmix076
    >>11292740
    At my house I once forgot to turn off and before a few days the pressure from the furnace was dropping and the floor was a bit wet
The discussion revolves around concerns regarding unscrewed vents in a central heating riser, particularly the risk of flooding when the heating system is activated. Users highlight that unscrewed caps on vents allow for air venting, but if left open, they can lead to water leakage, potentially causing damage to lower apartments. Suggestions include ensuring the vents are properly tightened and considering the installation of a cut-off valve to prevent flooding. The reliability of automatic air vents is also discussed, with recommendations to use quality brands to avoid leaks. Users express concerns about the possibility of water escaping if the vents are not adequately managed.
