Leaking automatic air vent in the central heating installation
Magik48 7203 3
  • #1 16680855
    Magik48
    A few days ago I noticed that the automatic vents were leaking, so I decided to replace them with new ones. Unfortunately, the problem repeats in cold water, and as if it was not enough, the mini valves at the manifold also leak. After heating the water, the problem disappears. I have a closed system with an expansion vessel on the DHW heater, a blue expansion vessel on. Where to find a solution to the problem ??
    Added after 41 [minutes]:
    Sorry, this is an open circuit with an expansion vessel.
  • #2 16681205
    gersik
    Help: 164
    Rate: 639
    When heated, the problem evaporates. Literally. The material may also expand under the influence of temperature and seal for a while. Replace the air vents and re-fold or tighten the mini valves.
  • #3 16681258
    Magik48
    Today I replaced all the vents with new ones and nothing helped. And when they were completely closed, there was sweating on the mini valves.
  • #4 16682280
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    Maybe it was better to replace the air vents with manual ones. They are more reliable (tighter).
