Understanding UTP STP Cables: Copper-Plated Aluminum (CCA) vs 100% Copper (CU), RG6, NS50, NS100
byku1407 20376 4
  • #1 11293166
    byku1407
    Hello and welcome
    When looking for a UTP STP cable for my network, I found some cables that are quite cheap - 150 for a 305m CCA 24AWG cardboard box, i.e. copper-plated aluminum. Compared to pure copper, there is a difference in signal quality, interference, cable durability because if I put it under plaster, it will lie in 30 years ;)
    Somewhere on the forum I found a topic that a cable below PLN 1 for 1mb is trash.
    The second thing I don't know about is the labeling of coaxial cables. I don't know what are the RG6, NS50, NS100 markings. What do you recommend.
    I am waiting for info and best regards ;)
  • #2 11293216
    mbo
    Help: 2333
    Rate: 845
    Buy a copper one.
    The labeling of coaxial cables goes hand in hand with their parameters - what is the cable to be used for?
  • #3 11293271
    byku1407
    mbo wrote:
    Buy a copper one.
    and there is a big difference on these cables, I am asking out of curiosity
    mbo wrote:
    The labeling of coaxial cables goes hand in hand with their parameters - what is this cable to be used for?
    I mean TV / RTV / SAT house wiring.
    Well, I do not know if he can write a new topic in the appropriate section, but using the opportunity that you recommend a multiswitch for such a home network: 3 TVs, QUAD converter for 2 PVR tuners, radio + digital terrestrial TV
  • #4 11294804
    PeteSh
    Level 30  
    Help: 95
    Rate: 71
    byku1407 wrote:
    ... because if I put it under plaster, it will lie in 30 years
    Don't save. Buy for PLN 300.
