Choosing the Right Home Network Cable: Bitner Copper, FTP 5e, Category 6, or Alternative Options
k2006 20985 17
What type of Ethernet cable should I choose for a home network renovation: UTP, FTP, Cat 5e, or Cat 6, and should the outdoor run be gel-filled and shielded?
For a home installation, plain UTP is usually enough, and for the outdoor section you can use a gel-filled cable that can also be buried in the ground [#16403806] It is better to choose Cat 6 UTP than FTP 5e, because if you use FTP you must keep the whole path compatible with the shielded standard, including sockets, patch panel, switch, routers and RJ-45 connectors [#16406016] Wi‑Fi should be treated only as an extra option for mobile devices, not as a replacement for cabling [#16406016] For cameras, a standard twisted-pair cable is sufficient, and the same cable can be used for PoE/PoAs power and data [#16405509] If a network cable runs alongside 230 VAC power, some advise keeping distance because unshielded cable is not recommended in the same channel, although others report they have no problems in practice [#16405571][#16405509]
  • #1 16403798
    k2006
    Hello, I need urgent help regarding the choice of a home call, as I have to make a purchase later this week. After Christmas, I start renovating my home. At the beginning, the whole installation at home was to be made in category 6, but I asked the installers at work and stated that it does not make any sense, I know them a little and know how they work, so I do not believe them to the end, so please verify whether I chose well. Internet at home will probably be some radio in the countryside or (unfortunately) TPSA.
    I've searched a little bit online and decided on the Bitner copper cable:
    # inside the house:
    * in a tunnel made of GK plates with a current cable (point light) I want to let go:
    - FTP 5e BITNER twisted pair cable, http://allegro.pl/polski-kabel-skretka-ftp-5e-bitner-miedz-100m-i6761435063.html, I read a little about the need to ground it but I think the installer will know what to do.
    # outside of the house:
    * here I have doubts, for sure gel-jelly only with or without screen?
    - UTP 5e UTP cable, BITNER gel, http://allegro.pl/polski-kabel-skretka-ziemny-utp-5e-zel-bitner-100m-i5937785266.html
    - FTP 5E twisted pair cable, Bitner gel, http://allegro.pl/kabel-skretka-ftp-5e-zel-bitner-cu-miedz-polski-i6760380996.html
    Under the camera, I can also make a twist with the screen, so far I do not plan but I prefer to have a ready cable.
    Regards, Krzysiek
  • #2 16403806
    LucekB
    Help: 143
    Rate: 137
    in home conditions, you can use UTP twisted pair.
    Gelled on the outside and you can also give it in the ground.
    The cameras will also be OK.
  • #3 16405154
    k2006
    Hello, thank you for your quick response. Due to the fact that the cable will be next to the current or not better to give the twisted pair with the screen, the cost of a small and then there may be a problem with the substitution. Outside without a screen? Only twisted pair is enough for the camera, and how does it power it?
    I also need a box in which I would hide all connectors etc. something like "Multimedialna Skrzynia Mieszkaniowa" http://allegro.pl/multimedialna-skrzynka-mieszkanio-obudowa-530-i6582516330.html any suggestions for stores with such accessories?
  • #4 16405509
    Rafq25
    Help: 9
    Rate: 22
    Rather, there should be no problems, in one of the companies I have to put ordinary UTP cables on the power cord with high voltage and there are never problems.
    As for cameras, all you need is a twisted-pair cable, you can use the same twisted-pair cable to power up PoE from PoE or PoAs.
  • #5 16405571
    yogi009
    Help: 848
    Rate: 2655
    In theory, it is not recommended to let UTP wires together with 230VAC power cables in one channel. For example, the American Panduit for category 5 (unshielded) ordered a distance of 20cm between these lines. The topic generally applies to long, straight wire sections, in these conditions it is easy to interact.
  • #6 16405616
    marianm68
    Help: 19
    Rate: 85
    Have you considered making a Wi-Fi network next to the "cable"? You will reduce the amount of cable (you will reduce costs and the number of working hours) and you will get a more flexible system. Because I understand that twisted pair is mainly needed for cameras.
  • #7 16405804
    yogi009
    Help: 848
    Rate: 2655
    Nowadays, however, there are also desktops, it makes no sense to buy WiFi cards for them, since they have built-in wired cards.
  • #8 16405849
    marianm68
    Help: 19
    Rate: 85
    But I think it is difficult in these times to have a computer without USB sockets (even stationary). You can buy a network card just on USB, price from a dozen or so zlotys. And it's cheaper than laying a cable. and certainly easier / simpler. The issue of coverage (antenna quality): but here you can find cards with external antennas. And there is no problem when the concept of furnishing the room changes or the place of setting such a computer changes.
    And nowadays, most devices have the ability to communicate over Wi-Fi. So why not give yourself "bigger possibilities"?
    "It's important that the cons will not override us."
    I do not have everything equipped with Wi-Fi but I think that it is possible to use wireless connection where it is possible because it is cheap and convenient. Unless there is a need to ensure high data / network security and vulnerability to burglary.
    Yogi009 it is probably easier to equip a desktop computer with Wi-Fi than a tablet with an Ethernet port ;-)
  • #9 16406007
    yogi009
    Help: 848
    Rate: 2655
    marianm68 wrote:
    You can buy a network card just for USB
    You can. You can also rely on the classic network card. In the first case, you do not pull the cables, in the second there is no trouble with the signal from behind several walls, etc. All this to the author's decision.
    Former construction norms in the so-called States (just in the case of office buildings) clearly defined the number of sockets per floor area :-) With us, we will probably never see such standards.
    What to choose: ethernet / wifi is a smooth thing. Apparently comfortable, like satellites also enter, and yet behind the western border they cable everything as it flies. Preferably a copper-free cable :-)
  • #10 16406016
    hermes-80
    Help: 1177
    Rate: 743
    Do not think about it in my life - Nothing can replace the cabling - wifi is just an additional option for mobile devices and for it to work well, you need to purchase a branded AP, not budget equipment - unless you like to constantly bury the network.
    Bitner is such a medium quality cable. When using FTP cables you need to remember about the whole equipment (sockets, patchpanel, switch, routers, RJ-45 connectors) - which is compatible with the FTP standard.
    I think it would be a better solution to use UTP 6 a cable than FTP e5 - as already.
    And if outside you do not have overhead lines and everything goes in the ground, UTP should also check.
  • #11 16406147
    marianm68
    Help: 19
    Rate: 85
    I understand this point.
    That's why I asked: "Were you going to do a Wi-Fi network next to the" cable "- I used the word" next to the cable "instead of" instead of ".
    The topic applies to the network at home. And that's why I let myself speak on this topic. A few years ago, during the renovation of the apartment, I "walled up" about 100m of twisted pair which I hardly use today. Almost everything goes on Wi-Fi and I do not "bury constantly on the web" - my needs satisfy quite well, I do not complain.
    Of course, the author of the topic will choose the best options for him. I only presented my point of view.
    "not good, but what good."
  • #12 16406220
    yogi009
    Help: 848
    Rate: 2655
    hermes-80 wrote:
    Do not think about it in life - Nothing can replace cabling - wifi is just an additional option for mobile devices
    And I agree with it 100%.
  • Wired Ethernet remains preferable for heavy concurrent traffic
    #13 16407351
    rosak
    Car dashboards specialist
    Help: 142
    Rate: 559
    I also. Despite having a rather high-end router, the cable is necessary for me. I can not imagine killing the router with a 2x 30mbps video stream, operating several cameras while simultaneously uploadzie large files on FTP and a smooth connection of a dozen or so devices.
    Added after 42 [seconds]:
    marianm68 wrote:
    it's probably easier to equip a desktop computer with Wi-Fi than a tablet with an Ethernet port
    Your friend is wrong here ;)
  • #14 16407601
    yogi009
    Help: 848
    Rate: 2655
    This can be briefly summarized: wired connection gives stability and wifi convenience. It's best to have both :-)
  • #15 16442998
    k2006
    Hello, thank you all for your answers, I did not say anything because of leaving and "slipping down" with renovation (starting after Mayday). Coming back to the topic of wi-fi, however, it will certainly be where I would like to pull the cable. You write that the Bittner cable is average, what companies do you recommend?
  • #16 16443143
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    What do you give it in the gel while on the inside of the house shielded twisted pair, and as for the class and interference it should work on every class.
  • #17 16443195
    yogi009
    Help: 848
    Rate: 2655
    Buy a cable in a stationary store, on which RJ45 plugs tighten well, it is usually enough. Well, classic, on the walls twisted-wire, or patch-cord is a cable.
  • #18 16444792
    k2006
    Thanks, I've looked for such answers, best regards.
The discussion revolves around selecting the appropriate home network cable for a renovation project, with a focus on Bitner copper, FTP 5e, and Category 6 cables. The user initially considered Category 6 but received mixed advice from installers. Responses suggest using UTP twisted pair cables for indoor installations and gel-filled cables for outdoor use, emphasizing the importance of grounding and compatibility with network equipment. The conversation also touches on the balance between wired and wireless networks, highlighting that while wired connections offer stability, Wi-Fi provides convenience. Recommendations for brands and alternatives are sought, with Bitner being described as medium quality. The need for proper installation practices and equipment compatibility is also discussed.
