Consequences of Excessive Ignition Delay: Potential Damage and Power Loss
dragilla 57015 20
What happens if ignition is delayed so much that it becomes a large retard rather than an advance, and can it damage the engine or prevent ignition altogether?
If the ignition is delayed too much, the engine will lose power and run richer in fuel consumption, and in extreme cases it may not ignite in the cylinder at all [#11329384][#11329541] With a very large delay, the mixture can still burn out in the exhaust or even cause backfiring into the intake/exhaust, so it is not equivalent to simply “no spark” [#11329429][#11329541] One reply also notes that normal operation can already involve more than 30° of advance depending on load, so a 50–60° retard is extremely large [#11329589] The thread says valve overheating is mainly associated with a too-lean mixture, not timing alone, but burning late in the exhaust is still undesirable [#11329384][#11329429] Another concern mentioned is dynamic fatigue of the crankshaft and possible fuel entering the crankcase if ignition is absent or ineffective [#11329974]
  • #1 11329342
    dragilla
    Rate: 15
    I have a theoretical question. What will happen (what could happen) if we delay the ignition so much that it becomes a "lag" rather than an "advance".
    I suspect it will result in a loss of power, but despite appearances, that's exactly what I'm after. The question is whether there may be any negative effects, e.g. overheating of valves or other damage.
    Will ignition take place at all with a very long delay?
    best regards,
  • #2 11329384
    markslew
    Help: 73
    Rate: 478
    When ignition is too early, knocking combustion occurs, power loss occurs, when ignition is too late, the engine will run softer, but power will drop and fuel consumption will increase.
    Overheating of the valves occurs mainly when the mixture is too lean.
  • #3 11329389
    dragilla
    Rate: 15
    But I'm talking about a long delay, let's say 50-60 degrees. I heard a theory that combustion will then take longer (expanded mixture) and may last until the exhaust phase, which in turn may overheat the exhaust valves... Does this make sense?
  • #4 11329429
    robokop
    Help: 1763
    Rate: 6372
    Yes, the mixture will burn out in the exhaust.
  • #5 11329440
    kortyleski
    Help: 957
    Rate: 3860
    As long as it fires up at all...
  • #6 11329448
    vodiczka
    Help: 1185
    Rate: 4311
    May I know what the purpose of such a delay would be?
    neither ecological nor economical. :D
  • #7 11329521
    dragilla
    Rate: 15
    What purpose? Big to write. In the leather - traction control.
    Theoretically, this would replace cutting off the spark, which would greatly simplify the system. But I understand that this is not the best solution and it is better to kill the spark than to delay it "to hell"?
  • #8 11329537
    robokop
    Help: 1763
    Rate: 6372
    NO. Better to delay.
  • #9 11329541
  • #10 11329557
    dragilla
    Rate: 15
    Can you elaborate? I do it for high-performance vehicles - without a catalytic converter, so it is not a problem for me that the fuel without ignition will be spat out into the exhaust and burn, making a "boom" :) In the event of a spark, there is probably nothing else that will threaten me...
    And if I delay the ignition too much, I can harm the engine, right? Because I realized that I can damage/overheat the valves?
  • #11 11329589
    robokop
    Help: 1763
    Rate: 6372
    And why delay the ignition by as much as 50-60 degrees? A significant loss of power can be noticed even when set to "0". Note that during normal operation of the KWZ engine it can even be over 30 degrees, depending on the engine load. With an on/off spark ignition system, you won't make any money on either exhaust or intake.
  • #12 11329597
    dragilla
    Rate: 15
    And I didn't want to go into the topic... The spark is to be beaten once every Chinese year, when the delay itself is not enough (i.e. when the slippage deepens). So I'm looking for a solution to kill the spark or eliminate its effects. Whipping complicates the arrangement, so I'm asking if I delay it long enough:
    a) it won't spoil anything
    b) the effect will be the same as killing the spark
    best regards,
  • #13 11329626
    carrot
    Moderator of Cars
    Help: 1315
    Rate: 3603
    A two-stroke with delayed ignition likes to "rebound" and then rotates in the other direction :D
    In 4T turbocharged sports engines, there are special maps with an ignition delay to maintain the turbine revolutions
  • #14 11329877
    Błażej
    Help: 1923
    Rate: 3627
    Maybe you could expand on this.
    How is the engine powered - carburetor or injection? Because if this is to limit the engine's power, you can cut off the injectors and the engine will not have problems with the fuel pumped into the exhaust exploding.
    Cutting off the spark is very simple. There are several ways to do this. Even mechanically.
  • #15 11329899
    dragilla
    Rate: 15
    This is not an option. The question is quite clearly defined: is severely delayed ignition harmful (can it be harmful) to the engine? How much?
    Is it better to kill the spark or delay it by such an angle that the ignition will not affect the power (the effect is the same as killing the spark).
    We assume that the equipment has an open exhaust and it will not harm the exhaust
  • #16 11329909
    Błażej
    Help: 1923
    Rate: 3627
    But what EXACTLY do you want to achieve and with which engine?
  • #17 11329929
    dragilla
    Rate: 15
    In every engine - it is supposed to be a universal solution. Only that it's petrol. For simplicity, let's assume without a turbine.
  • #18 11329950
    Błażej
    Help: 1923
    Rate: 3627
    "Gasine" engines do not exist.
    There is no universal solution for all engines. Depending on the engine generation and the type of power system, this can be done in different ways.
  • #19 11329959
    dragilla
    Rate: 15
    Approx. Sorry for the grammar, I've already corrected it.
    Błażej wrote:
    ...this can be done in different ways.
    I don't know what you want to do. I know what I want to do, in fact I'm already doing it. I'm just asking what long-term effects it could have and what would be better, or in other words, what would do less damage - a long delay or killing the spark.
  • #20 11329974
  • #21 11330007
    Błażej
    Help: 1923
    Rate: 3627
    So "I'm doing something, but I won't say exactly what, and you tell me if I'm doing something right."
    If you want help, explain the problem.
Excessive ignition delay in internal combustion engines can lead to significant power loss and potential engine damage. A delay of 50-60 degrees may cause combustion to extend into the exhaust phase, risking overheating of exhaust valves and dynamic fatigue of the crankshaft. While some users theorize that delaying ignition could simplify traction control systems, the consensus is that both excessive delay and cutting off the spark can be harmful. Delayed ignition can result in unburnt fuel emissions and increased risk of fuel entering the crankcase. The discussion emphasizes the need for careful consideration of ignition timing to avoid detrimental effects on engine performance and longevity.
